Question about CADAC Safari Chef Portable Grill
How do i clean the grill normal scourers does not get it clean
  • 43,501 Answers
Go to the hardware and get a good stiff wire brush. That will get you cleaned up.
heatman101
Posted on Aug 20, 2010
How do I clean burnt on cloth?
Oven cleaner. Leave for 30 minutes and use a plastic brush or non scratch scourer to scrub off, being careful not to splash yourself or your eyes.
Jan 28, 2016 | Kitchen Ranges
Change rectifire out on 2007 canam 650 max/xt four wheeler
Disconnect the battery, unbolt the rectifier and then disconnet. Before refitting the new one make sure the meeting points are clean, where the rectifier meets the frame. ( scrub with a plastic pan scourer or wire wool ) Then refit is the reverse of removal.
Jan 10, 2012 | Motorcycles
What is your recommendation for cleaning the gas jets on this grill? -Andy Perry
Andy, to clean the burner orifices use canned air with a straw nozzle (like you clean your computer with) to blow them out. It normally only takes a couple of quick blasts of air to do it.
Hope this helped you. Andy. Happy Grilling!!
Jun 27, 2011 | Weber Q Grill
Gas oven lights pilot straight away but takes a long time for main burner to work has it got a thermocouple and cuold this be at fault
Sorry to read about your problem, I hope this helps you out.
I will assume you have the gas. there is no thermocouple, your oven use electronic ignition.
you may have a bad liter or you need to clean the grills
Hotplate Top Enamel or Stainless Steel
Hot soapy water, soft cloth. Any stubborn stains remove gently with a nylon scourer.
Pan Supports, Wok Cradle (some models only)
Enamel coated Cast Iron or Stainless Steel
Cif Cream Cleaner- Faberge Lever and a nylon scourer.
Dishwasher.
Burner Caps Enamel
Cream cleaner, nylon scourer. Dishwasher
Burner Trim Rings (some models only) and Burner Head
Aluminium
Cif or other cream cleaner with a soft cloth. Be careful not to be over vigorous.
Griddle Plate (some models only)
Non-Stick Surface
Allow to cool. Wash in hot soapy water. Do not use abrasive cleaners/scourers. Dishwasher.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 26, 2010 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Cleaning the grates?
grill is easy to lift, i usually soak grill like that and then whipe off, that is usually sufficient.
if you have some really bdly ingrained bits, then spray it with oven cleaner, leave for few second and then whipe off, then wash as normal. if this is coated (teflon) grill, then do not use this method! soaking only!
hope this will help, if you find advice useful, please leave your comment and vote for me, thanx!
Jun 28, 2010 | Coleman Roadtrip Grill LXE 9949-750
Dumplin husband has cleaned stainless splashback with a scourer leaving loads of scratches in all directions! Any miracle solution?
I recently had a piece of stainless bent for a customer at a sheet metal place. The guy who bent it up for me used an abrasive pad (like those green scourers) to establish the grain look where it had been removed by the bending process. Please realize this is what I observed, not something I have done myself, so you probably save it for a last resort. Good Luck
Apr 20, 2010 | Kitchen Ranges
Just bough weber Q200 grill. Is it normal that the flame burns so low and blue?Used to large flames off conventional grills. Thanks.e.
I have used the Q-series for 2 years. The blue and low flame is absolutely normal. Weber's philiosophy is of avoiding flare ups when grilling for best taste. I love this grill - very easy to clean, uses less gas and makes great food.
Aug 23, 2009 | Weber Q Grill
Kenwood Steam mop
The Manufacturer suggests you clean the hose by removing the water tank dammed if u can get it off though.
Nov 26, 2007 | Eureka Enviro Steamer 310 Stick Vacuum
CADAC Safari Chef Portable Grill Logo
98 people viewed this question
Top CADAC Grilling Experts
paulcarew
Andrew Taylor
Andrew Taylor
ray gallant
Are you a CADAC Grilling Expert? Answer questions, earn points and help others
