Question about Sharp R-340 Microwave Oven
I need back light for touch panel - Sharp R-340 Microwave Oven
  • 3,037 Answers
Repairclinic.com has all parts, just search with your model number
Let me know how this works out Benjamin
Posted on Aug 20, 2010
Product is GE Microwave (Spacesaver-type) JNM1731DM1BB. New surface light bulbs installed. Unable to turn them off or change from bright to dim
Bottom lights are controlled through relays on the main control board which is mounted on the back of the touch pads (control panel).You can check and see if wires are touching each other on the board but my guess is the board is defective and needs replaced.
Apr 02, 2015 | GE Microwave Ovens
Panosonic Microwave convection Model NN-8501V Touchpad appears dead
The unit has a fuse in the power board, but when the fuse is gone it does not even start up. If it starts it is not the fuse.
Look rather a problem with a faulty touchpad, or the magnetron that is not working and need to be changed.
Check also the door sensor.
Oct 03, 2008 | Microwave Ovens
Touch Screen Not Working. Have cleaned the ribbon cable contacts and still the screen lights up showing the buttons but nothing on the touch pad works. If not the ribbon cable being dirty, I guess i
Most of the time the panel buttons stop working because grease gets between the outer panel and the contacts underneath. Disassemble the door and if you need to carefully peel back the outer panel, use some paper towels to remove the heavy grease, then using a Q-tip and some rubbing alcohol clean the back of the panel and the surface contacts on the board, then re-assemble.
Dec 26, 2014 | In Microwave Ovens
What does it mean when f3 lights up
F3 usually means you have a shorted touch panel soft key. If you are aboe to clear the error by hitting cancell, you may be able to duplicate the issue by holding one of the keys on the panel till the error returns helping you to verify you need a touch panel. PleazerAppliance...
Nov 01, 2014 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
On my GE Profile Microwave the led is lighted and shows the time correctly and displays the led buttons. When I press on the led buttons nothing seems to happen. Also, after some idle time, the led panel...
The touch panel has malfunctioned, Suggest replacing microwave unless you want to attempt repair. If so you will need a replacement touch panel for it.
Jun 14, 2017 | GE Microwave Ovens
Hello. I just received a new Glass Touch ASM (WB27T10875) for my GE stove. My previous one cracked and needed to be replaced. Problem: While installing/ connecting the ASM to the stove, once I connect the...
Funniest thing. I was having the very same problem on Monday. Every time I laid the glass touch panel down on the stove, it stopped working but worked when I held it up. After failing to install the panel so it would work for 30 minutes, I walked away from it and ate dinner. Coming back later, I decided my problem was the connections on the back side were coming into contact with the metal so I placed a tightening knob in the center of each of the outside holes making sure the underside of the knob went exactly into the middle of the hole. I then lowered the left side of the panel down to where the threads started and very carefully partially tightened the left knob so none of the panel back touched the stove. I then lowered the right side until the knob touched the knob and tightened that side finger tight. I keep testing the buttons to make sure they were still working. When the out side knobs were finger tight, I finger tightened the 2 inside knobs. Success. My oven is now working.
Aug 03, 2013 | GE GLASS TOUCH ASM WH - WB27T10873
Kenmore Microwave Oven, Model#66568680891
you should change the touch panel and or the control module.check to make sure the power supplied is correct and all connections to the board are all secure.
Feb 24, 2010 | Microwave Ovens
What would cause the touch panel display screen on our model gh6177xpb3 microwave to not function - the panel lights up - the lower controls seem to function properly - Thank-you in advance for your...
It may be a glitch that can be corrected by a hard reset. Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
It may have gotten moisture, contamination, or grease inside, which can happen if one cooks on the stove top without having the microwave's hood vent fan on.
It may simply need repair.
We repair microwave control units and touch panels / touch screens for customers nationwide with our guaranteed $39.95 service.
Feel free to contact me directly.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Jul 26, 2008 | Whirlpool Microwave Ovens
Microwave came on by itself
Yes this is usually caused by the touch assy, but $278 !!!!! Thats kinda steep considering the panel assy is only around 30-60 bucks!!! It will need the touch assy and even possibly the control board, because sometimes the logic IC gets fried and causes "ghost issues" as well.
Sep 17, 2007 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Sharp R-340 Microwave Oven Logo
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
