When connecting ricoh aficio 1045 printer to my laptop it asks for properties and then refuses to connect how do i connect it?
  • 64 Answers
The best thing to do is goto Ricoh's site and download the drivers. Install the drivers first, then plug in the printer. This will likely resolve your issue. -Ravi Shanghavi
Posted on Aug 19, 2010
My computer does not recognize this machine for install.
Go to Ricoh site
look up your printer: Ricoh Aficio SP-C210SF Printer
then download drivers that are same operating system compatable as in XP vista etc then click on the install files where they load to as in C drive Driver folders etc
click on setup file ..Somesites will ask do you want to install this file Say yes BUT disconnect the printer first form the computer then connect after download and install them reboot PC or laptop
easy peazy
Jun 16, 2010 | Ricoh Aficio SP-C210SF Printer
RICOH AFICIO 1045. ANY BUTTON AT RIGHT OF THE ...
turn off and unplug remove two screws on top near the glass jn order to remove the control panel slide panel toward your tummy bottm side has wiring harnesses check these connectorsare tight also look fer cracked solder joints on right side for numeric keypad if you know how to soldera pcb new control panel is about 800.00
May 21, 2010 | Ricoh Aficio 1045 Black and White Copier
Do i need any driver if i connect Aficio 1035 to my pc. n wat do i need for it to be connected to my pc. tq
Does your machine have the Printer Option installed? Or the Print / Scan Option installed? If so, there would be a NIC input on the left hand side of machine towards the back....and print and scan buttons on the left side on your control panel. Type 1045 Printer option is what needs to be installed for the machine to be able to print. Drivers can be downloaded from this link to Ricoh.
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/x1035_45/x1035_45en.htm
Just choose your operating system.
Oct 22, 2009 | Ricoh Aficio 1035 Copier
Trying to get my Ricoh Aficio 1035 networkable
This is all you need to upgrade your copier to a network printer/scanner and fax.
Good Luck.
32MB Memory Unit Type B 400516
Postscript 3 kit type 1045 410713
64MB Memory Unit Type B 400517
Fax Function Upgrade Type 185 410284
Print Unit Type 1045 410706
Printer/Scanner Unit Type 1045 410699
Network Interface Board Type 1045 410714
Fax Option Type 1045 410680
Fax Stamp Marker Type 30 334049
Jul 08, 2009 | Ricoh Aficio 1035 Copier
HOW to configure ricoh aficio 2032 on nework and install it on more than 1 pc. this printer is connected via ethernet cable to dlink switch, where my other pcs are conected. but i cant connect it on any...
You install driver for the Aficio 2032 on all computers where you want to be printed from it.
Then you will go to Printer driver properties and then need to be created port TCP/IP and write the address from the printer it's same as connecting a computer on network
Jun 30, 2009 | Ricoh Aficio SP C210 Laser Printer
Ricoh aficio 1045 error e990 please help it
This is a software performance error; However it is most often caused by a deteriorating drum unit. There is no exact solution, but 9 times out of 10, a new drum unit, and fresh developer will solve it.
Outside of that, it is likely a board problem -possibly BICU
May 26, 2009 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1045 User Key
Someone locked the machine out. You can a hold of who your purchased it from to see if they can give you the key operator code to unlock it.
I can give you the service code to restore it but there are several steps involved in doing that.
If the first option doesn't work, let me know and I'll look up the service program to disable the key codes.
Sep 01, 2008 | Ricoh Aficio 1035 Copier
Ricoh aficio 1018 printer
yes you have to install the drivers and give the usb option for communication
Aug 05, 2008 | Ricoh Aficio 1018D All-In-One Laser...
How do you set a scanned document folder on a ricoh aficio 1045?
do you mean how do you creat a folder to scan your documents into ? if you have document server or scanner buttons on the key pad, then just select scan and mofidy the folder to your choosing.
Thank You,
Mikey
Apr 03, 2008 | Office Equipment & Supplies
Richo 1045
Probably cleaning to the mirrors and glasses inside the laser the problem can be solved, but this is a complicated work if you are not technician I recommend to him that she asks for technical service. Also a bad connection of the flat cable can cause this problem. The detector of synchronism defective also since code SC326 is a fault of detection of synchronism.
Jan 07, 2008 | Ricoh Aficio 450 Copier
Computers & Internet Logo
283 people viewed this question
David Payne
David Payne
