Question about Homelite Garden
Chain keeps coming off - Homelite Garden
My stihl ms-180-c chain saw will not keep chain tight. you tighten chain rev. engine chain will just about come okk -tighten chain rev. engine same thing.
you have to use the tension screw to move the cutter bar to tighten the chain then you do up the bar mounting nut to keep it tight
May 12, 2017 | Stihl Garden
If the chain is tensioned properly then you may have a burr or burrs on the driver links. It makes the driver link to fat to fit in the groove of the bar.If you can fin the bad link or links grind off the burr. If they all have burrs it is easier to get a new chain.
Jan 27, 2014 | Craftsman sears 18" Chain Saw Chain (...
Roper snowblower drive chain keeps coming off
sounds like you have either stretched chains or worn sprockets. Also check the outer bearing that the shafts fit into for wear. If they wear then the chain can't retain it's tension properly, get sloppy and then derail itself. Most likely your bearings is the problem.
Dec 02, 2013 | Craftsman 16" High Garden Tractor Snow and...
The chain keeps coming loose
If the chain keeps coming lose it can be down to a number of things, inadiquate oil to the chain, incorrect type of oil in the tank, poor quaility chain, worn sprocket and or guide bar.
May 14, 2012 | Garden
I'm having trouble keeping the chains on my John Deere Tractor. I put them on exactly how the diagram said. They seem pretty tight but they keep falling off when I get out there during snow removal. ...
you need to make shure the chains fit the tire snug and then you need to put a rubber tension band (they usually don't come with the chains) you can get them at a walmart or auto parts store, about $2 for 2 of them and come with little s hooks that you secure to the chain, instructios are on the package, the rubber band you put on the chains on the outside of chains and it keeps tension on the chains so they won't be lose and fall off. hope this helps.
Jan 12, 2011 | John Deere 22 In. Rear Tire Chains
Open the chain guard.Once there look for a bolt that hold the chain plate.The chain plate has a large groove and the bolt.djust the chain by plull to the front until the chain is tight,but not too much,just test by hand if is move freely but tight.Reverse the procedure.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 21, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chainsaw Chain Keeps Coming Loose I bought a brand new husky saw 235 and the chain keeps coming loose its about an inch under the bar after bucks up 3-5 logs in a row, the oiler is working but im not sure...
No problem.Is because the chain get streched.So open the side of the chain saw where there is the adjust bolt.The chain plate holder has a groove long enough to adjust the chain.But do not do it too tight.When adjusting try to test it without power,just by move the chain with hands.
Nov 16, 2010 | Husqvarna Garden
The chain keeps coming off of my daughters MX500. Is there a way to tighten the chain or the chain tensioner. Is there something else that could be causing it to come off?
The chain usually comes off because it is not tight enough or the chain is not aligned correctly with the sprockets. Check the chain tensioner to see if it is keeping the chain tight and not moving even though it is tight, if it loosens, replace the tensioner. Check the chain for any broken or worn spots or links, if any are found replace the chain.
Jun 15, 2010 | Razor MX500 Dirt Rocket
I have a remington electric chain saw and the chain keeps coming off while I try to cut with it I keep the chain tight and keep the bar nut tight but it still seems to want to come off the sprocket anyone...
Your chain should not be tight ... only snug. If it keeps throwing the chain, your bar is not on correctly and/or the clutch needs replaced. Do not use old chain with a new clutch.
Mar 08, 2010 | Garden
Garden Logo
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
