Question about Samsung SRV-960 VCR
Hello! How can i get an user manual for a Samsung srv-30p time lapse? I want to now what the error codes mean. I can see on the display "err3 L30", and the recorder stops to record. Thank you in advance for the answer.
SOURCE: Will not playback get error message Please Check Disc
i have a r136 , have you got the dvd discs u need ? i had the wrong format .
eg, dvd+rw needed dvd-rw
if not and there re-recordables they dont work after a few recordings and u need a new disc.
Posted on Dec 29, 2007
SOURCE: write error
I think i just figured it out. Somewhere else on the web clued me in that the disc got messed up (don't know how). I put in a new disc and it works. Other disc still doesn't though.
Posted on Feb 16, 2008
  • 5 Answers
SOURCE: Samsung B/W Observation System - Model# SSC-12
Same problem here after a close lightning strike. Fuse was good, main switch was operable. Noticed a charred spot next to a heat sink which has two diodes that appeared to be burnt. One being a zener diode, the other a simple diode. Gonna replace them and see what happens. Any suggestions?
Posted on Jul 31, 2008
SOURCE: region free - Samsung DVD-VR375 DVD Recorder / VCR
I have managed to get a solution to this now. I have a region 4 as in Australia so depending on where you are you'll need to try the correct region. It worked for me first time. Point 4/ below my region code appeared in the top right corner for a couple of seconds not the top left! Once you've completed below turn the machine on again and stick in one of the dvds that would not work before.
Cheers Stewart
1/Turn machine on without disc inside
2/Press menu button
3/Enter region code (See below for list)
4/A highlighted 'region area number' will appear in the upper left corner (some players)
5/Press 9 to change the region number to multi-regional
6/Turn machine off
R1 - 29334
R2 - 38767
or, 5 7 5 3 8
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Posted on Sep 19, 2008
SOURCE: Driver for Samsung DVD Camera Recorder SC DC173U
go to the samsung.com website. their support section has drivers and instructions.
Posted on Jun 16, 2009
What does Err3 mean on taylor body fat scale?
Remove your shoes and socks and wet your feet slightly with a damp cloth if you receive the "ERR3" error. ERR3 is a contact error and your feet should ideally be bare and wet to achieve an accurate body-fat reading.
  • Step off the scale and wait for it reset. Remove your shoes and socks and wet your feet slightly if you receive either the "ERR4" or "ERR5" errors, which means your body-fat or body measurements are out of range.
  • Reset the scale if it doesn't work or you continue to receive error messages. Remove the battery and set the scale on a flat surface. Stand still on the scale for five seconds and step off. Re-install the battery and place the scale back on the flat surface. Place one foot on the scale until it displays zeros or dashes. Remove your foot and wait for the scale to turn off. Step back on the scale to weigh yourself
  • Sep 28, 2016 | Taylor Health & Beauty
    I don't see SRV and SRV' on sharp er-a320 cash register, so i have hard time to proceed master reset.
    They are unmarked positions because they are special technician service modes. They are after the PGM position as you turn the key anti-clockwise. You need the SRV key to turn to those positions. Once you are in SRV position, use the programming manual to perform service programming. One of the users has it here:
    https://the-checkout-tech.com/manuals/cashregisters/Sharp_ER-A320_programming_manual.html
    Feb 13, 2016 | Retail Supplies
    Hover OPD 714 D 7kg . What does E08 mean
    http://service.hoover.co.uk/manuals/OPH714D_1.pdf
    user manual
    http://www.whitegoodshelp.co.uk/hoover-error-8/
    here is a description of the common error your machine has
    and how too solve it
    hope it helps you...
    Mar 04, 2015 | Washing Machines
    What is err1 and err3 in elekta dishwasher?
    Electra Dishwasher Error Codes and other critical errors can occur when your Windows operating system becomes corrupted. Opening programs will be slower and response times will lag. When you have multiple applications running, you may experience crashes and freezes. There can be numerous causes of this error including excessive startup entries, registry errors, hardware/RAM decline, fragmented files, unnecessary or redundant program installations and so on.follow the instruction on the link below to find your solution http://www.saetechnologies.com/electra-dishwasher-error-codes/
    Mar 03, 2015 | Dishwashers
    What does error code E-13 mean
    Hello there
    Sounds like a 'gas sensor' (whatever that is) error. I recommend calling Samsung Support or a qualified Microwave Technician
    SMH2117S/XAA Microwave Is Displaying An Error Code If your microwave is displaying an error code, such as -SE-, E-11, E-12, E-13, or E-14, or any other trouble code not listed here, cycle the power to the microwave by either unplugging the unit, or cycling the circuit breaker for approximately 60 seconds before restoring power.
    If the above suggestion does not work,and the error code returns, your microwave will require service.
    namo_fileview.jsp?type=nfs&pid=decisiontree&did=466719&cid=5uwnecasicas@namo.co.kr&sep=%7c
    Sep 21, 2014 | Samsung SMH2117S 2.1 cu. ft....
    About 10 second upon start-up, the Cybex 520T Treadmill would abruptly stop and display in the consul is an Err3. We transferred the speed sensor of the unit to another Cybex treadmill and initially the...
    Error 3 is an indication that the speed sensor signal has been lost. Check the speed sensor gapping on the machine you were initially having the issue on. If the speed sensor worked on another machine, I would think adjusting it when you reinstall the sensor, should fix your issue. A lot of times, gapping or a build up of lint, dirt or other debris can cause the speed sensor error to occur.
    Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
    Jul 29, 2011 | RTO Cybex 520T Remanufactured Treadmill
    My Kenwood dishwasher keeps displaying error message E4 but there is no mention of this in the user manual. Can you explain what this means
    Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
    Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
    Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
    Hope this help?
    Thanks.
    Nov 02, 2010 | Kenwood KDW243A Builtin Dishwasher
    ENLIGHTENMENT ON AN ERROR CODE
    The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
    Otherwise, your best bet is to contact AEG customer service here:
    http://www.aeg-electrolux.co.uk/node137.asp
    I'd bet that customer service will not know the meaning of the code (if it's not in your owner's manual) and they will steer you to a service center.
    The service center will probably not tell you what the code means, preferring instead to repair it for you.
    Good luck.
    We're happy to help and we appreciate your thoughtful rating of our answer.
    May 26, 2008 | AEG MCC663 Microwave Oven
    Oven burner
    For service assistance and the location of the nearest Samsung service center, please call 1-800-SAMSUNG (1-800-726-7864), or go on-line to http:WWW.SAMSUNGSUPPORT.COM
    Oct 25, 2007 | Samsung MT1066SS Convection/Microwave Oven
    Samsung SRV-960 VCR Logo
    55 people viewed this question
    Jerry Greenberg
    Jerry Greenberg
