Question about Dryers
Kitchen aid dryer
My boy friend replaced the belt in my dryer and toke the back panel off now my dryer want start the timer is working and there is 2 blue female wire's not hocked up in the back . i was messing with the dryer and touched them together and the dryer started and it sparked . but it started i am looking for a diagram of the back wiring can you help
Thank you Christina
    Genius:
  • 1,073 Answers
The diagram that you are looking for is in the console as for the two blue wires they go to the blower fuse that is white and about the size of a small paper clip
Posted on May 02, 2008
Model #KEYS850GGQ0. dryer made bit of groaning noise on start up. Repeat next 4-5 starts, then would not start. Timer is ticking. Fiddled some with door switch. No help. Suggestions? Thank you, K C
Go to www.repairclinic.com and enter KEYS850GGQ0. With luck, you will be presented with a list of common replacement parts and may be able to view a generic disassembly video which will help you locate the source of the noise.
Jan 22, 2017 | Dryers
Tip
Kitchen Aid Dryer Belt Diagrams and Replacement
Your dryer belt has broken and you have a new belt to install, but you do not know how to route the belt properly. Here are some pictures or diagrams to help you see how the belt needs to go. Of course the belt needs to go around the drum so that is not included.
The important part is the routing around the motor and the tensioner pulley.
For models with non-removable back panels use this diagram:
Style: Flat with ribs
Installation Tips: Ribs against drum
For models with removable back panels use this diagram:
on Mar 06, 2010 | Dryers
My Malley 1050S dryer: timer is ticking away but the machine is doing nothing : (
I agree, always cut your losses, dryers are not that expensive. When my home aids break I LOOK To buy new ones now. I figure that once they start breaking they will carry on doing so
Jul 17, 2015 | Dryers
My kitchen aid gas dryer timer isn't working. The clothes dry when I run it but the timer doesn't work - Model #KGYE670BWH0. Where can I pick up this part relatively cheaply?
Hello there and welcome to fixya
This is a really easy part to replace and it is rather cheap you can purchase it online at repair clinic.com
Timer
RepairClinic Item # 528733
Timer assembly for dryer
Manufacturer Number 3405331
More
Skill Level Skill Level
$118.30
Quantity:
Oct 14, 2013 | KitchenAid Dryers
Kitchen-Aid Electric control panel buttons stopped working
This may sound facetious, so don't get offended.
Did you set your clock to the correct time?
Did you clear any and all preset timers?
If none of that helps you can usually find roaches in the strangest places. If you have no roaches, then moisture and heat are the likely culprits which means that your blister pads are simply worn out. Unfortunately these are coated with graphite and don't last forever, so a timer replacement would be your only option unless your touchpad is separate from your timer.
Mar 05, 2010 | KitchenAid KERC507 Electric Kitchen Range
Kitchen Aid Electric Dryer Model # KEYE678BALO, won't start.
This is most often caused by a bad thermal fuse or thermostat high limit cutout. Check them for continuity (with the machine unplugged, of course) They should have continuity -- replace them if open. They should be available at www.appliancepartspros.com Also, if one or both are bad, check the dryer vent as they often are damaged by high heat due to a restricted vent pipe. The website above also has diagrams to help find the parts on the machine.
Dec 30, 2009 | Washing Machines
Kitchen Aid electric dyer, will not start. I have power to the dryer and the timer runs, but the drum will not turn after pressing the start button. If the door is opened after setting the timer, there...
You have a bad thermal fuse , located on the blower box . A small white plastic piece with 2 wires going to it . May have to remove the front panel to access it . Usually caused by kinked vent hose or clogged vent .
Jul 31, 2009 | Dryers
Dryer wont start
I would check the door swith first.
Jul 15, 2008 | Estate TEDX640JQ Electric Dryer
Dryer won't start
ck your thermal fuse on rear of unit first, depending on model it might stop all function. (part number 3392519) whote maybe 2 inch thermastat located on rear wall of dryer. and yes the bnlower is LFT if needs removing
Mar 08, 2008 | Dryers
Dryers Logo
Top Dryers Experts
