Question about Acer Aspire One A150-1006 Notebook
How do yo get to the memory and can I add 1GB to the existing1!GB or do I have to purchase a 2 GB memory...thanks
  • Acer Master
  • 32,281 Answers
Most laptops have 2 memory slots, if you have 1 Gb of RAM using two 512 Mb RAM then you need to replace them with two 1 Gb RAM modules. If you have one RAM module 1 Gb then you only need to add another 1 Gb RAM module. Try to use the same make and speed RAM.
Posted on Aug 19, 2010
Testimonial: "Thank you so much , now I just need to know how to get to the memory slot."
  • Chris Hingee
    Chris Hingee Aug 20, 2010
    The memory module is located on the bottom of your laptop behind a panel which is held in place by a screw. The RAM module is a small circuit board approx 68mmX32mm with gold plated contacts along one edge. The RAM module is locked into the slot by a spring clip on each end of the RAM module. If you need to remove the existing RAM module, push each clip away from the RAM module and the RAM module will pop up with the edge still on the socket. Then remove the RAM module by sliding it away from the slot.
    To insert a RAM modulr, place the RAM module in the slot and push it fully into the slot and then press the RAM module down until the spring clips click into place on the edges of the RAM module.
    Replace the panel and secure it in place with the screw.
Hi there. I am a RAM rookie. I have GAteway MX7118. are there two memory slots or one. It comes with 512 does that mean there are two slots and I can add a 1GB for A total of 1.5GB ?
Hi, defending on your cpu board usualy there are two slots, also if your board capable to 1 gigabytes memory, if your memory is DDR u can add 1 GB up . if your memory is SD you cannot add higher than 712 MB. if your memory is 512 and you want to add 1GB the total should be 1.5 you are correct in your calculation. thanks
Apr 29, 2011 | Gateway MX7118 Notebook
I have 512 mg of memory. Would there be a big difference if I add a 1 gb stick and keep the 512 mb , as oppose to removing the 512 mb and replace with two 1 gb sticks?
The performance of your laptop will improve if similar memory is placed in each of memory slot.If 1gb memory and 512mb memory are placed in available slot you will only get the performance of a single 1gb memory.but two 1gb memory are used performance will be similar to a 2gb ram or more.
May 30, 2010 | Acer Aspire 3003WLCi Notebook
Can I upgrade memory to only one gb of memory or install 2 512 mb on a toshiba satellite m35x series
http://www.shopping.com/xPF-Toshiba-Toshiba-Satellite-Notebook-PC-M35X-S114
Looking at the specs, the max is 2gb for your Toshiba. According to this website, its only a 256mb ddr sdram. So my guess is you only have 1 slot for the ram. I'd go with a 2gb ram if you can afford it, 1gb just don't cut it in todays technology.
I believe its the PC2700 model, so find a 1gb or 2gb PC2700 @ 333mhz and you should be set.
Sep 09, 2009 | Toshiba Satellite M35X-S114 Notebook
I need to add space to my compaq presario desk top. i don't know how to on this computer. the model# SR5034X
If you want to increase cpu speed so you need to increase RAM memory.
You can fix it on motherbord of desktop cpu.
But if you have low space on disk storage partition so you can add space to desktop with 2 method.
(1) you can add harddisk to desktop cpu with sata or IDE .SATA harddisk is best if your motherbord support SATA.
You can add harddisk as you like for example 80 GB or 160 Gb.
(2) If you want to add RAM memory for speed reson you can purchase new RAm and fix it in memory module slot on motherbord.
There is 2 type on
RAM in currently.
DDR1 and DDR2
you can add RAM memory like 512 MB or 1GB or more.
Aug 07, 2009 | Compaq Presario 5000 PC Desktop
Asus P5VDC-MX question about ram .
Hi
You can add one more 1GB ram module.
Max Supported RAM 2 GB Memory Type DDR2Supported RAM Speeds 400 MHz · 266 MHz · 533 MHz · 333 MHz
Jul 06, 2009 | ASUS P5VDC-MX Motherboard
Want to add memory to Gateway 700x
Max memory is 2GB, i.e. 1GB per slot(DIMM), so you will need 2 X (SimpleTech 1 GB PC3200 400MHz DDR RAM). {Always use matched pairs only}
Visit this link : http://www.simpletech.com/upgrades/gateway/700x/700xddrintelp428ghz/
.................sodeep
Mar 31, 2009 | Gateway 700 X PC Desktop
Upgrade ECS FSB800 memory from 1 GB to 2 GB wont work
This board will support up to 2gb as shown below extacted from the website product page.Don't forget that if you have ddr 333 memory installed originally, you can only add the same clock speed memory, i.e. ddr 333. If you add ddr333 and ddr400 you will have problems as the clock speeds do not match. If you are matching clock speeds, the try bootin the system with the new piece of memory on its own to see if there is a problem with that stick, trial an error of both sticks individually, will give a positive result
MEMORY ecs_buttom_03.gif Single-channel DDR memory architecture ecs_buttom_03.gif 2 x 184-pin DDR DIMM socket support up to 2 GB ecs_buttom_03.gif Support DDR400/333 DDR SDRAM
Nov 02, 2008 | EliteGroup ECS P4M800-M Socket...
I want to purchase the TM 3270, but it only has 1GB. I'd really like to have 2GB, but can't afford the extra cost, seems to be 300 more . So, I wondered how you add 1 GB to the 3270??? Cost of doing...
Okay, I don't believe someone wants 300 more for an extra GB. You can upgrade it to 4 GB for just over $100, 2 GB is around $52. On the bottom of the laptop will be a compartment with one or maybe two screws in it. There should be a little picture of memory next to the screw(s). Loosen the screws and remove the door, there is your memory. You may have to remove a chip to install the 2 GB chip or, if it already has a 1 GB chip in it and one slot is free, then you can just purchase another GB and install it.
Jul 03, 2008 | Acer Computers & Internet
High density memory
need low densisty on ebay 35 buck eash 1 gb ok works on picky mobos way better
Feb 07, 2008 | Dell (E210882) Motherboard
Type of memory for e210882 motherboard
the memory you're about to purchase will not work. the maximum gig that the computer can handle per stick is only 1 gig. this system is not designed for 4 gig barrier.
hope this helps.
thanks.
Feb 05, 2008 | Dell (E210882) Motherboard
Acer Aspire One A150-1006 Notebook Logo
344 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
