I bought a second hand philips Plasma TV. The remote or so I thought was not working. Using the model no 50PF9967D bought a new remote (RC4312/EU) After following all instructions given my new remote still does not work the TV. The twist is that my brother in law has a very similar model and his remote works my TV. AHHHHHHH. Can anyone offer me any advice? Does my new remote need program codes? PLEASE HELP
  • 3 more comments
  • euan_mckay May 02, 2008
    This is my next course of action. My TV has more funcions which do not work using the other remote.Will post up what happens
    Thanks for that, can you please give me the proceedure for programming? Do you just key in those four numbers on the remote?
    Many thanks again.
    Yes my friend it looks the same
    My remote is a RC4312 my brother in laws remote is a RC 434301/01
    THis I will try as soon as I can
    Genius:
  • 3,422 Answers
Yes you will need the codes to program it all you can do is try out these codes first.If these don't help then the only solution is to contact the customer support and get the code.
1002, 1009, 1014, 1051, 1056, 1060, 1061, 1066, 1067, 1072, 1073, 1074, 1077, 1078, 1082, 1086, 1136, 1152, 1156, 1166, 1174, 1175, 1180
1000, 1002, 1004, 1005, 1014, 1025, 1078, 1081, 1095, 1096, 1097, 1098, 1099, 1100, 1101, 1111, 1128, 1130, 1132, 1134, 1144, 1149, 1171, 1205
CLICK HERE
for the customer support.
Goodluck,
Please don't forget to rate or accept the solution
Posted on May 02, 2008
  • Priya darshan May 02, 2008
    I got some more useful info for you.
    To program a component using the Automatic Code Search method, perform the following steps:
    1. Turn on the component you want the remote control to operate.
    2. Press and release the component button that corresponds to the component you want the remote control to operate.
    3. The illuminated ON-OFF button turns on and remains on.
    4. Press and hold both the component and ON-OFF buttons.
    5. The illuminated ON-OFF button turns off.
    6. After the illuminated ON-OFF button turns back on, release both buttons.
    7. The illuminated ON-OFF button remains on.
    8. If
      you press an invalid button during Auto Code Search, the illuminated
      ON-OFF button blinks four times and turns off. The last programmed code
      under that component button is retained.
    9. Press and release the PLAY button.
    10. If,
      after five seconds, the component does not respond, continue to press
      the PLAY button every five seconds until the component turns off.
    11. Each
      time the Play button is pressed, the illuminated ON-OFF button blinks
      ten times and a block of 10 codes is sent to your component. This
      process continues until all the codes in the Code Lists have been
      searched. If the component has not turned off after all codes have been
      searched, the illuminated ON-OFF button blinks four times, turns off,
      and the Auto Code Search Entry method is exited.
    12. When
      the component turns off, press and release the REVERSE button, then
      wait two seconds to see if the component turns on again.
    13. If
      the component does not respond, continue to press the REVERSE button
      every two seconds until the component turns on again. This will isolate
      the correct code in the last block of codes sent. Each time the REVERSE
      button is pressed, the illuminated ON-OFF button blinks.
    14. If
      the REVERSE button is accidentally pressed after the component
      responds, press and release the FORWARD button. Wait two seconds to see
      if the component turns off again.
    15. To save the new code, press and release the STOP button.
    16. The illuminated ON-OFF button turns off. You must press the STOP button to save the code.
    17. If
      some of the features of your component do not work, different codes in
      the list can be tried until you find the code that allows the remote to
      control the majority of your component’s functions.
    One more thing to program it you will need the manual it is different
    for every model but still try this out too..And please don't forget to
    accept my solution as fixya.
    To program your remote to control your TV, follow these steps:
    ON•OFF
    TV CODE
    CODE
    SEARCH
    INDICATOR
    LIGHT
    TV (BLINK)
    5
    (OFF)
    1. Manually turn on the TV.
    2. Locate the enclosed TV Code List. Find
    your brand of TV.
    Note
    : If your brand is not listed, use one
    of the Code Search methods to program
    this remote control. (See section on
    Code Search.)
    3. Press and hold the CODE SEARCH key
    until the indicator light illuminates.
    Then release the CODE SEARCH key.
    4. Press and release the TV key. The indicator
    light blinks and then remains lit.
    5. Use the number keys to enter the first
    code listed for your brand. After you
    enter a valid three-digit code, the
    indicator light turns off.
    Note
    : If you enter an invalid code, the
    LED flashes rapidly for two seconds.
    Start over at step 3.
    6. Aim the remote at your TV and press
    the ON•OFF key. If your TV turns off,
    you have found the correct code.
    7. Enter the code in the box provided on
    this page for future reference.
    8. If your TV doesn’t turn off, repeat steps
    3-6 above, entering the next code for
    your brand.
    If none of the codes work or your brand
    is not listed, use one of the Code Search
    methods to program this remote.
    (See Code Search section on page 10.)
    Your RCA Universal Remote is compatible with most brands (of infrared remote
    controlled components manufactured after 1990). Below is a list showing some
    of those brands. Check the enclosed Code List for a complete listing along with
    their corresponding popular setup codes for quick and easy reference.
    Master:
  • 555 Answers
The "EU" appendix indicates this remote is for use with the European or UK models of this television. Your unit may require a different remote spec (USA?)
I'd steal your brother-in-laws! (Or at least check the remote model number on his to compare to yours...)
  • 2,336 Answers
You can try the new remote at your brother in law TV's and see if it works.
Can you hook up a Xbox 360 (EU) to a Philips 37PF9975 37 in. HDTV-Ready Plasma
do one thing...see at the connector...there is a switch...do it normal mode...if it is in HD mode..it cant be work in ur tv..
Sep 23, 2012 | Philips 37PF9975 37 in. HD-Ready Plasma...
Blue ray disc player is working fine, but the tv is not showing any channels. We are just installing our new tv. What did we do wrong?
I just bought a samsung BD-P4600 and I tried to connect with a Philips Plasma TV. What channel do I need to put it on for it to show?
Sep 07, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Menu Screen Keeps Coming up on the screen
The most commom causes are One. There ia a stuck button on the tv itself. The Menu button. The membrane switch or the TACT switch is bad and needs to be replaced. The Main bd can also be bad.
Jul 16, 2009 | Philips 42PF9630A 42 in. Plasma Television
Ok...so the remote works...now what
If the problem is the IR sensor, then the TV will turn on and work using the buttons on TV, but wont react to remote.
If instead the TV does not turn on all all , then the TV is on protection because of an internal fault , and must be tested and fixed by a technician.
Replacing IR sensor is not complicate, but t is not an user level operation.
The IR sensor is usually located on the front bottom side of the TV, therefore to replace it you need to remove the main board completely, and many other parts.
Additionally on many models the sensor is soldered to the digital board.
If the TV goes in standby, then it is in protection mode.
You can get parts below:
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
May 04, 2009 | Philips CCC130AT 13 in. TV/VCR Combo
My 42 inch Haier Plasma has a no signal on screen it's only a year old can someone help I bought a new remote and that did not help ?
i had the same problem and i bought the new remote control and it did work at first i thought it was going to do the same thing but then i pushed the tv/use button and it worked perfectly.
Mar 13, 2009 | Haier HP42BB 42 in. Plasma TV
Philips RC4318 Remote Issue
SOLVED!!!! Make hard reset of the remote control:
1. Five seconds Mute & Menu buttons 2. Press Select untill four lights comes up, exept TV 3. Press OK That's it! Get your remote control as a new :)
Sep 14, 2008 | Philips 50PF9630A 50 in. Plasma Television
Menu
I download new software from internet and insert to TV and it works.
Apr 27, 2008 | Philips FTR-9964 Tuner/Receiver for Plasma
Plasma will not turn on
Sounds like u might have a bad power supply
Apr 05, 2008 | Televison & Video
Televison & Video Logo
122 people viewed this question
Top Televison & Video Experts
