Question about Ovens
Who do we contact to service microwave oven? - Ovens
  • 177 Answers
Depends what area you live in and what country you live in.
Posted on Aug 19, 2010
Missing part
More than likely you will have to contact the company and order it from them. They have a parts order service. Miele.com
Mar 22, 2014 | Miele H4042BM Oven
Bosch wall oven turns on when mcrowave is on
Contact Bosch website and ask customer services if they have had this problem before. It may be subject to recall if there is a fault. Also have a word with the installer. If there is any leakage of radiation it MUST be stopped.
Dec 10, 2017 | Bosch Appliances 27 in. Wall Oven Electric...
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    Haier RTC1700ss digital display doesn't work. Beeps when plugging in but no functions
    Hello
    Here are a few things you shoul look at and try to correct to make your oven work properly
    Make sure the electric oven is plugged in properly.
    Check that door closes completely and its latch is aligned.
    Check that interlock switch in door works properly (required for activating oven).
    There might be a blown fuse,replace blown fuse if it's accessible, or contact a service technician.
    Inspect plastic coupling beneath tray.
    Check ring and roller assembly for misalignment or debris.
    Make sure that tray is sitting properly on turning mechanism.
    If carousel motor is broken, contact a service technician
    Make sure there's no aluminum foil or metal trim on dishware.
    Food residue or burned spots can cause electrical arcing. Clean chamber thoroughly. Replace wave-guide cover if burned or carbonized.
    Sand away burn spots, and smooth rough metal edges.
    Touch up spots with microwave interior paint if necessary.
    If chamber has burn holes, contact a service technician.
    If you hear an unusual buzzing noise, the magnetron (the component that actually generates the microwaves) or other electronic module may be broken. This is not easily fixed; contact a service technician.
    Jun 20, 2011 | Haier RTC1700SS Electric Single Oven
    I want some one to come to my residence to demonstrate, as I do not know how to start or operate the Microwave oven, Can you give me a number to contact or call?
    what city and state do you reside in ... i am a servicer in the dallas ,ft.worth texas area would be glad to make a service call to your residence if you are with travel distance...
    toll free 1-877-523-2101 monday -friday 9am to 5 pm thanks
    Jan 05, 2011 | Whirlpool Ovens
    Installation of lg over the range microwave oven
    Installing an LG over-the-range microwave is an excellent way to save space in your kitchen. These types of microwaves are ideal for smaller kitchen areas. Although the retailer where you purchase your over-the-range microwave will likely offer installation service, rest assured that you can install the microwave on your own.
    How to Install an LG Over the Range Microwave eHow
    Oct 11, 2017 | Ovens
    New oven won't work
    cobrapilot sorry to be the bearer of bad news. Some where in the oven the contacts going to the oven probe are closing. This could be wiring going to the probe missing insulation and hitting the sheet metal, or the probe socket itself closed. I usually see this after the unit is in use, not right after install. Have you tried to cook a roast or such in the probe mode to see if it will work? For the oven may work just fine then. You are correct about your last line, until service resolves this issue, you have just an expensive microwave. Also as a side note, be sure an be there when the tech showes up. They may just try to say we need a part and not actually attempt to fix your unit. I am not sure what area you are in, however try Olson Appliance Service, He has a website, he is authorized Kitchen Aide service and maybe he can help.
    Feb 03, 2008 | KitchenAid Architect Series KEMC308KSS...
    Microwave will turn on but not heat
    Test the high voltage capacitor, the rectifier diode.or the magnetron.
    If it additionally does not spin and no light, then check also the door switch.
    The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
    Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
    All locations, and description of this parts can be located using the diagram here: Counter top.
    Parts must be tested to find out what is wrong.
    Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
    A microwave energy leakage test must always be performed when the oven is serviced for any reason.
    Regarding parts, contact the seller here to purchase parts. (here in UK).
    Nov 26, 2007 | GE JTP85 Electric Double Oven
    Ovens Logo
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
