Question about Mitutoyo Measuring Tools & Sensors
How do i reset my 329-711-10 depth mic after changeing the battery
Just purchased and Eagle Fishmark 320 used. Will not display depth reading - just shows 0'0"? I have reset to factory settings. We have had in lake,same thing. Right now in 5 gallon bucket of...
Hello! Do you have the PDF users guide for your unit? I'm looking at a copy in the troubleshooting section...I don't want to cover information you have already looked at or tried...Since I do not know if you have that manual I'll give you a few items to check...
Measure the battery at the units power connector...Must be at least 11 volts DC...In portable mode it uses 8 D cell batteries= 12 volts
Make certain the Transducer is securely connected...
Did you use the in-line fuse supplied with the unit?...
Try the Manual Depth Range...First turn off Auto Depth Range...From the sonar Page Hit MENU...Down-arrow to Auto Depth Range...Hit ENT...Hit Up-Arrow to Depth Range...Hit ENT..
And the Depth Scale Range appears...Up-Arrow or Down-Arrow to select a different depth range...Hit Exit...The minimum depth the unit can read is 5 feet...
If you do not have the PDF guide, here is the link...
http://www.eaglenav.com/upload/Eagle/Documents/Manuals/seafinder320df_0143-661_101602.pdf
Let me know how you make out....Guru....Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Sep 11, 2011 | Eagle Fishmark 320 Portable Fishfinder
My friend cant hear me but i can hear her. how do i get it so she can hear me
check your audio settings and make sure your mic level is up and get her to check her speakers are on and plugged in or her headphones are on. Also get "her" to make sure her mic is plugged in (the right socket...red one if PC) and that the mic volume is up on the internal mixer and "un-muted". This is a universal answer for an ambiguous question. For more in depth solution, please give your system details and platform plus what ever headset/mic you are using.
Jan 16, 2011 | Computers & Internet
My depth finder on my E-120 works for a minute or 2 and gets stuck. My tri data also works for a minute or 2 and then the depth portion shuts off with only lines running thru and no numbers. Other portions...
Hi! You will need to reset the unit to work normally. Try this, remove the battery and press/turn the power button for 10secs. while the battery is removed. Put in the battery and turn the unit on and see how it goes. This should reset the system and resolve the problem. Hope this helps and have a good one!
Jun 12, 2010 | Raymarine E120 GPS Receiver
Rapid depth reading variation during ascent
change the battery and use the reset button to manually reset the computer
Nov 09, 2009 | Dive Rite Nitek Duo Air/Nitrox Computer -...
My computer says i need to change my color depth, how do i do so?
You can change the color depth by right clicking on the desktop, click on properties, click on settings. You will see something as color quality, you can change it, thats also known as color depth.
Regards,
Shrey
Oct 10, 2009 | Computers & Internet
I need technical support
You need to try what it says try lowering the or color depth try 1024 X768 256 colors if that doesn't work try 800 X 640 256 colors Right Mouse click on the desktop where a Icon isn't go down to properties regular click go to settings change the screen resolution and color depth and color quality to above suggestions apply changes try your movie
Johnlgrn
Dec 27, 2007 | Computers & Internet
Color depth - video settings
What is the make/model of the laptop? You may need to re-install or upgrade the video driver.
Hope this helps :) Kindly leave a rating. Thanks..
Nov 28, 2007 | HP Pavilion zd8000 Notebook
Measuring Tools & Sensors Logo
85 people viewed this question
Top Mitutoyo Measuring Tools & Sensors Experts
Glenn
Glenn
Dragan Manojlovic
Dragan Manojlovic
Level 1 Expert
Are you a Mitutoyo Measuring Tool and Sensor Expert? Answer questions, earn points and help others
