Question about Ovens
I need to replace the element on my westinghouse freestyle 808 oven . where can i order one how do i change the element? thanx
  • 177 Answers
Pull the unit out of the housing and rest on a suitable work bench. turn off the power and remove the rear cover you will see the grill element, ring element and the bottom element. depending on whcih one has blown they are relatively straight forward to replace.
as for where to purchase one depends on what country and area you live in. best to search for someone local on line
Posted on Aug 19, 2010
How to switch on oven westinghouse kimberly 509
If the oven does not work on bake or broil settings then there has to be a problem with the circuit, either on the control board or the thermostat. If only the bake element does not work then the element itself most likely needs to be replaced. There are ways to isolate further but takes some basic electrical knowledge and tools. Note that I am not recommending that you do the following linked procedure - merely pointing out an information source. https://www.youtube.com/watch?v=uZNyEqXCNOA
Mar 08, 2016 | Westinghouse Kimberley 509 Ceramic Oven
How do you change the oven element on a Westinghouse PAJ143W as the element is hidden
To replace Westinghouse PAJ143W oven element you need to look at the back of oven with a torch etc, and you will see the element ends go into the back through clips on each side. At the top of these clips in the middle there is a bit where you get a screwdriver to push down and lever forward and it will come out a bit you do this on both sides. Then lift the clips and element 'both sides'' together and carefully pull forward making sure you're careful with the wiring and pull out a little making sure you stop the wires slipping back while you swap elements. Make sure you put plate at front back in place to keep element up off the bottom, it has two reswts for element on it.
May 20, 2012 | Sharp Ovens
Trying to change element on westinghouse PAK806 stove with ceramic cooktop. cant figure how to lift hob.
Hi I have a Westinghouse PAK806. The oven works fine, heat and fan, but none of the plates will turn on.
Any ideas?
Jul 13, 2011 | Ovens
I have a Westinghouse 678 freestyle.the element remains on. It may be due to the setting of the clock or timer. i do not have a manual to regulate either as this was not left by the previous owner. could...
I also have the same oven, it turns itself on at random at heats up, also is the oven door easy to remove for cleaning, I dont have a manual either
Jun 29, 2010 | Ovens
Oven not igniting and heating
Without the model number I can only give you basic information. If you are refering to the Glow Ignitor located in the center bottom rear of the oven concted to the burner tube, then this Ignitor could be bad and most tech's will change it first.
Even if it is glowing does not mean it is good.
For more detailed information please include as much information as postible and the Make and Model # off the machine.
Always unplug the machine when trying to service it.
Jan 10, 2010 | Ovens
Need an instruction manual for Westinghouse freestyle 745 wall oven, preferably in PDF, having trouble setting the clock. Can you help please?
instructions-manuals.com/search.php?...WESTINGHOUSE%20FREESTYLE...FREESTYLE%20920%20DISHWASHER
safemanuals.com/index_upload.php
www.manualsnguides.com/search.php?...WESTINGHOUSE%20FREESTYLE......
You can copy and paste any of the above links in your internet address bar under a new tab to bring you to your manual
Nov 12, 2009 | Ovens
Westinghouse Freestyle 668 oven not doing anything , just blinkin
Yes I can help.Hold down the buttoms on the far left at the same and then set the time using the + and - buttons.Cheers
Apr 20, 2009 | Ovens
Westinghouse Freestyle 476 Cooktop Oven
After getting an electrician out, apparently the time needs to be set on the oven. As we're in a rental & don't have a manual/ couldn't download one, we got it to work after holding the first two buttons in (the timer buton + the one that looks like a hot pot) along with the + button at the far right, which made the tim tick on, so it could be set.
The oven works now! : )
Aug 20, 2008 | Ovens
What wire goes where for my Westinghouse Freestyle elements?
oven wiring has the same conventions as house wiring.
green = earth, outside coating
brown or white = one of core ends
black = the other end
Jul 13, 2008 | Ovens
Ovens Logo
331 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
