We need Tally T6140 Printer driver for Solaris 10 for our process in an urgent basis.
  • 10,319 Answers
This web site will let you know if the needed download is available
http://www.sun.com/bigadmin/hcl/
Posted on Aug 19, 2010
Tally erp 9 working slow
you have not mentioned the networking involved .?
how are the clients networked to the server ?
Are you using a switch or a hub ?
Are you using a fast ethernet connection 100 Mbs or 1000 mbs into server from a network switch ?
How fast ? 10 mbs will cause problem on five client machines sharing 10 mbs into a server
Jul 07, 2017 | Microsoft Windows 7 Home Premium 64BIT...
Tip
I need Postscript drivers for Lexmark printer T630.
Hi.
This printer supports Postscript, PPDS, and PDF emulation only on systems up to Windows 2000, on Mac OS X up to 10.6, and on Solaris.
Windows 7and Vista are not fully compatible with this printer, and the printer will not have full functionalities on this systems.
If you have Win XP, Win dows Server 2003, Win 98, Win 2000 or Mac OS, then all you have got to do is installing full factory driver software.
If you have Windows 7 or Vista, then you should upgrade the printer to get full features. Lexmark has opted for not updating this printer software. Full software release for Windows Vista and Windows 7 does not exist.
The drivers and software for this printer can be downloaded from Lexmark website, using the links below:
Lexmark_AAG_WinXP_PS_Driver- Post script driver.
System PCL Driver for Microsoft Windows XP and Server 2003
System PCL Driver for Microsoft Windows 2000.
PCL6 driver for Microsoft Windows 95, 98 and Me.
Printing solution for Mac OS X v.10.6.
Print driver for Sun Solaris 10 x86 systems.
Network print support for Linux.
Here the full driver installation procedure : How to install a Lexmark printer without the driver and software disk.
The printer may still work on Vista and Windows 7 using the built in drivers, but it will have limited functionality. See: Windows 7 Information.
Regards.
on Mar 24, 2010 | Lexmark T630 Laser Printer
Good day. Need a driver for SMC Sun PCI Quad Fast
Please be informed that any Driver Software depends upon its Hardware make and Operating System support. You need to know all these information to get started working with that particular hardware. You can find the driver software inside the disc provided to you at the time of purchase.
As per your query i have checked a lot of technical sites and even Sun microsystems,but I found that this network device can not be installed in a windows platform as this only supports Solaris Operating System.Please find the detail here http://docs.oracle.com/cd/E19113-01/quad.fast.sbus/804-6116-10/804-6116-10.pdf
The Sun Quad FastEthernet SBus adapter is supported on systems running the Solaris operating environment, versions 2.4, 2.5, 2.5.1, 2.5.1 Hardware releases, and 2.6. The Sun Quad FastEthernet PCI adapter is only supported on systems running the Solaris 2.5.1 Hardware releases and Solaris 2.6.
Nov 24, 2011 | SMC Sun PCI Quad Fast Ethernet Card (p/n...
Pls i need printer driver for Tally T6045 on window xp platform
Here you go:
download driver to the link below http://drivers.downseeker.com/download/22177/tally-t6045-printer-driver/
thanks for using Fixya
Jun 08, 2011 | Tally Line Matrix T6045 Printer
Need Tally T6140 driver for solaris 10.
You can use an Epson FX driver which should be build-in in Solaris. Then you just need to select the Epson Emulation in the printers menu and save your configuration afterwards.
Aug 20, 2010 | Tally Line Matrix T6100 Printer
Ms word does not print properly on tally 2250 printer
you need to create a forms for your specified paper size.
1.open printer and faxes in win xp.
2.file...server properties...create a new form(check)
3.type a name for forms
4.type a size in below boxes...(like 10 x 12 paper , width is 10 inch, height is 12 inch)
5.save it
6.close
7.rht click the printer...device setting tab... select a form name in the tray .
8.it will work
Feb 26, 2010 | Tally T2250 Matrix Printer
Can't add my aficio ap3200 to a solaris box
Check this link.
http://www.ricoh-canada.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/p32/p32en.htm
regards
Nov 28, 2008 | Ricoh Aficio AP3200 Laser Printer
TOSHIBA B SX4 thermal barcode printer and Solaris 10
First of all change the escape caracters used to define the tpcl commands.
(2) parameter
code auto to {|}
Substitute in your code ESC ={ Lf = | and Nul =]
The printer will ignore the other control caracters
May 07, 2008 | Toshiba TEC B-SX4 Thermal Label Printer
jasbo
jasbo
