Question about Sony Playstation 3 (PS3) Console
My playstation 3 is not working correctly. i had an hdmi cable hooked up to it, and it came unplugged. i plugged it back in, and there was no picture, but here was sound. i tried to turn it on without the hdmi cable, and there was no picture and no sound. i think it needs to be reconfigured, and i can't do that without being able to see the playstation menu. i need someone to get on theirs and tell me what to press to get to the configuration for the hdmi. thanks.
    President:
  • 1,139 Answers
Ok follow these steps to cure your problem :
Step 1. Turn your PS3 into standby mode (red light on)
Step 2. Press and hold the power button. When you first press it it will beep, then it will beep again 5 seconds later. When you hear this second beep release the power button.
Step 3. Wait for the PS3 to restart
This basically resets the video output back to standard definition. You should now be able to set your video up properly with the PS3 menu.
Hope this helps and thank you for using FixYa
Posted on Aug 19, 2010
Playstation 3 works fine useing the av hook up but won;t work with hdmi cable hook up.
First, make sure your TV is on the appropriate input for the plugged in HDMI cable. Once this is completed, turn your ps3 on. If the screen comes on and is black, turn the ps3 to standby (red light is on) and hold the front power button until the console beeps a second time. This will usually force the ps3 to recognize the hdmi input and will bring up the menu to configure the AV settings.
Aug 13, 2014 | Sony Playstation 3 (PS3) Console
My ps3 is hooked up though HDMI to my emerson lc195emx. but the tv says its an unsupported format. why? is it because the tv only has 720p out put??
Try turning off the power to your console using the power switch in the back (first shut it down properly). Unplug the AV cables (if applicable) and the plug in the HDMI cable. Turn on the system and switch your input on your Television to HDMI. (Keep in mind that there may be a few inputs; HDMI1, HDMI2, etc.) The HDMI connection takes a few seconds so be patient. If that doesn't work, re post or ask to chat.
Feb 05, 2011 | Sony Playstation 3 (PS3) Console
When entering a game I hear sound but no picture. Plugged in correctly and TV set to HDM11.
If you are sure that you have your TV on the correct input, you can try resetting the PS3's video settings using the following procedure:
  1. Before changing cables, make sure the PlayStation 3 is turned off using the main power switch on the back of the PlayStation 3 (the 0 side is pressed down).
  2. Unplug the power cord of the PlayStation 3 and television (or display) from the wall socket.
  3. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PlayStation 3 system.
  4. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  5. Plug the PlayStation 3 and television (or display) back in to the wall socket.
  6. Turn the main power switch on the back of the PlayStation 3 back on (the line on the power button is now pressed).
  7. While the PlayStation 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  8. Turn ON the PlayStation 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
If that does not resolve your issue, try the other steps here:
http://us.playstation.com/support/answer/index.htm?a_id=262
Oct 25, 2010 | Sony Playstation 3 (PS3) Console
Hooked up hdmi cable for playstation 3 an the
You need to to set the playstation back to scart lead in the settings.
Apr 07, 2010 | Sony Playstation 3 (PS3) Console
Hi cant connect my playstation to play online
Try making sure that all your cables to your Playstation are correctly connected.If it is a Playstation 3 then make sure that your HDMI cable or three way cables are hooked up.If it is a Playstation 2 make sure that your brodban cable is plugged in and that it is also plugged into the phone jack.Hope it helped
Nov 02, 2009 | Sony Playstation 3 (PS3) Console
Console will not work
you should never unhook or hookup anything hot. shut your stuff down and then plug unplug whatever it is you are doing
good luck cullen
Jul 28, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3
try using the composite cables as well.....with your tv set to the composite input go back into the settings and select the HDMI output switch your tv's input back to your HDMI input and remove the composite cables....it should work fine...
Jan 11, 2008 | Sony Playstation 3 (PS3) Console
PS3 no longer communicating with TV
All: Try this -
P
erform the following steps to reset the Video Output Settings.
  1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
78 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
