I am not able to disable touchpad for my e6400 DELL laptop. The driver does not show disable option even in administrator mode. This is interfering during typing from keyboard as the cursor moves somewherelse and starts typing at unwanted locations.
  • dn_vaidya Aug 19, 2010
    When I open mouse properties, there is no touchpad tab.
  • dn_vaidya Aug 20, 2010
    I had to update the driver from Dell web site then the tab was displayed. Thanks for your help.
    Sergeant:
  • 238 Answers
  1. Click Start.
  2. Go to Start, click Run, type main.cpl in the box next to Open, click OK.
  3. Click the Dell Touchpad tab.
  4. Click on the picture of the touchpad.
  5. Click Device Select.
  6. Click to check the box to the left of Disable Touchpad / Pointing Stick when external USB mouse is present.
  7. Click Apply, then click OK.
  8. Click the X in the upper-right corner to close the Dell Touchpad Utility.
Posted on Aug 19, 2010
  • Nilutpal Sonowal
    Nilutpal Sonowal Aug 19, 2010
    there may be a tab Hardware or Device setting (in Vista). (it depends what OS you are using).
    any way go to the last tab. you will find two devices. check properties. try disable one by one.
    Do reply
  • Nilutpal Sonowal
    Nilutpal Sonowal Aug 20, 2010
    If you are satisfied with my solution, Please give rating.
Wlan card disabled
The Dell Latitude E6400 laptop comes with an Intel Core 2 Duo processor for fast computing and an NVIDIA graphics card for video playback, gaming and Web browsing. The laptop has a built in Wi-Fi card, letting you connect to the Internet on-the-go. However, if you're unfamiliar with Dell or the laptop's factory installed Windows Vista operating system, you might not know how to enable to Wi-Fi.
Slide the switch on the side of the laptop toward the front of the laptop. This switch enables Wi-Fi connectivity on the Dell Latitude E6400. When switched into the back position, the Wi-Fi is turned off. Turn on your Dell Latitude E6400 laptop and log into Windows Vista. Click on the Windows "Start" button. Click on "Wireless," located in the Start menu's "Show" list. A list of currently broadcasting wireless networks appears on screen. With your Wi-Fi enabled, you can connect to any of these available networks. Secured networks ask you for a password when you click "Connect," while unsecured networks connect automatically.
Feb 03, 2013 | Dell Latitude E6400 Notebook
Wondering pointer
Try downloading the Touchpad drivers, then you will have that option.
Get online and got to www.google.com In the google search box type: "Dell Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Touchpad drivers.
You can disable the touchpad once you have the touchpad driver installed. Most times when it installs the touchpad will be at the bottom right near the time. you should also be able to get to it in the Control Panel.
May 15, 2012 | Dell Latitude D410 Notebook
I can not disable touchpad of INSPIRON 1545 of DELL Computers There is no option for disabling touch pad in the MOUSE option of Control Panel
Go to the Control Panel. Under the 'Hardware and Sound' options, click 'Mouse'immortal4u.png
Since you have a Dell laptop, you'll have a special tab called 'Dell touchpad' in the window that pops up. Click on the touchpad picture in the window.
In the new window that appears, click 'Device Select'
Click on the 'Disable' radio button to disable the touchpad completely. If you want to disable the touchpad of your Dell laptop only when an external device like a mouse is attached, check the last option that says 'Disable Touchpad/Pointing Stick when external USB mouse is present'
That's it. You've disabled your laptop's touchpad for good. If you don't find an option to manage your touchpad in Mouse settings, you have to install Synaptics drivers from here. Similar options can be found in other laptops as well.
Good luck ! if your problem is solved don't forget to rate
Dec 30, 2010 | Computers & Internet
How do enable presentation mode on a Dell Latitude E6400?
http://www.topix.com/forum/com/dell/TVL695GKCP6MVDLGMhttp://www.fixya.com/support/t356513-presentation_mode_off
Jun 13, 2009 | Dell Latitude D830 Notebook
Mouse touchpad, keyboard, and usb drives will not work
One thing you can try (for the touchpad)
Acer have got a function key to turn it on and iff (i thought mine was broken for a year). Hold the function key, which is located bottom left of keyboard, and then press F7. It should be F7 anyway.
Hope that helps for your touchpad
May 05, 2008 | Acer Aspire 3000 Notebook
Dell Inspiron E1405 touchpad does not work
regarding touchpad log on to this link and download touchpad drivers
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INS_PNT_PM_1420&os=WLH&osl=en&catid=&impid=
make sure you choose the operating system correct and install Input Device Drivers
you will find 3 options you have to download the third one
Dell - Driver Applies to: hiernest.gif Touchpad / Pointing Stick
run a diagnostics
turn off your system
press and hold Fn key ,power on the system, leave fn key
it will start running a diagnostic
it will give you an option to press any key to continue
press any key and you will get 4 options
express test
custom test
extended test and
symptom tree
choose symptom tree
you will get list of devicec
choose keyboard run test
it will highlight some keys you have to press
if everything works fine here
hardware is working fine
then you have to take the system back to day one or use Operating system cd to reinstall the operating system
if you are in United states call 1-800-624-9896
Apr 15, 2008 | Dell Inspiron E1405 Notebook
Dell Laptop Trackball Too sensitive!
Go to control panel. Select mouse. In the window that opens, select the dell touchpad tab. Click where it tells you.
Then, on the bottom left of the next window that opens, select "pointing stick settings." Uncheck the "tap to click" and the TouchCheck "Enable" boxes.
That seemed to work for me. you can also disable the touchcheck on the touchpad.
Aug 11, 2007 | Dell 0Y3740 Keyboard
Computers & Internet Logo
2,576 people viewed this question
David Payne
David Payne
