Question about Acer Aspire 7720 Notebook
Good day.i have a aspire 7720 laptop the laptop starts up but after a minute or so a everything freezes a blank screen then you get a mesage your display nvlddmkm has stopped responding but has successefully repaired its self.sometimes after that message the computer shuts down.please could you help
  • 808 Answers
Use reginout regcleaner to fix ur problem
Posted on Aug 19, 2010
Hi, when iturnon my laptop (acer aspire 7720 17')
Its better to send the laptop to the manufacturer for a repair as we find it as a genuine issue with either the board or with the monitor. There could be no issue with the OS and looks like its a genuine hardware problem. Good Luck.
Mar 14, 2010 | Acer Aspire 7720 Notebook
Laptop keeps turning itself off was running vista, was ok, then wiped and loaded xp instead and the problems started.
good day, you may try putting the vista since it has the good performance. hope this helps. have a nice day
Feb 05, 2010 | Acer Aspire 7720 Notebook
Acer Aspire 7720 shut down, no power light, battery and supply check good. Tried the power reset still no power light with AC supply. unit completely dead. Do I stick a fork in this one?
The laptop's AC power jack is probably damaged. All you have to do is put the fork aside :D, unsolder the old power jack and solder the new one in. If you are not good at soldering you can get it done by a qualified professional. Its a 5 minute Job and a pretty inexpensive repair.
Regards,
Sai.
Oct 24, 2009 | Acer Aspire 7720-6569 Notebook
Backlight on Acer Aspire 7720-6395 gone instantly
bud there is a chip in the back of the monitor which enables the back light it a fix only a pro ca do its cheap enough but monitors now are fairly cheap so i look into repair but if not then sry a new one is needed
Jul 26, 2009 | Acer Aspire 7720-6569 Notebook
Acer aspire not start
first i would check the ac adapter
if you are sure its ok, then look at the pin
inside the ac jack, if it moves at all it could be bad
Mar 14, 2009 | Acer Aspire 7720 Notebook
Acer 7720 will not boot
Do you want to try and see if a 'Linux LiveCD' boots? This is the way I test if the computer works. You burn this CD to a disk, and then boot off of it when you're computer starts. I will not modify anything on your computer as long as you go to 'Try Ubuntu with out installing'
http://www.ubuntu.com/getubuntu/download
Don't worry, I'm not trying to get you to install anything, just see if it boots into the 'live environment' (means you are running it off of the cd) If this works, that means that it is only your windows installation is messed up, and a reinstallation of windows should work fine with a Windows install CD NOT the recovery cd.
Jan 31, 2009 | Acer Aspire 7720 Notebook PC
7720 will not boot
off course it is repairable dont worry look try to install OS thru the following procedure to factory default state
Acer: When you first turn on the laptop and see the Acer logo screen, hold the ALT key and press the F10 key (you need to do this before the Acer logo disappears).
if it installs the OS ok then fine if not
pls consider changing RAM take out from beneath the laptop open the cover all screws and take out the L shaped panel then u will see the RAM in front with 2 chips one uper and one lower side try to take out both and then re fit only one in the upper slot and then try to install if hangs again , then try the 2nd chip in the first slot and repeat the procedure if it works ok only try both chips one by one if it resolves ur issue and u find the faulty one replace it with new one with sam specs
in the last case if ur system still hangs then my friend ur hard disk is giving u hard time it needs replacement
when a system boots after bios loading all that is trf from Hdisk to RAM and then OS is loaded if one have problem system will hang or freeze try these solutions and then tell me the results
pls go step by step
and pls rate me fixya if i fixed ur problem
kindly let me know abt it and tell me in detail the messages u get and the system behaviour
Jan 30, 2009 | Acer Aspire 7720 Notebook PC
Battery won't charge right
CHECK WITH ASUS FOR A NEW BIOS UPDATE. I HAD PROBLEMS WITH BATTERY CHARGING AND THE BIOS UPDATE FIXED IT.
Jan 11, 2009 | Acer Aspire 7720-4428 Notebook PC
Acer Aspire 7720 Notebook Logo
122 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
