Question about LaCie (300728U) 250 GB Hard Drive
My Lacie hard drive keeps disconnecting every like 2-5 minutes, i pull it out and put it back in again but it just does the same thing, and it does it immediately if i try to copy anything. I think it might be the connection port on the drive, any ideas how to fix it? i really need to use it
SOURCE: external hard drive
500Gb Lacie D2 Quadra with the same problem of flashing led and not mounting on the desktop (Mac G4 Mirror), traced to the power supply (57w) going down on power, both 12v and 5v supplies are available but the main power to run the drive drops to below an adequate output, hence the clicking and whirring evident from the drive with simultaneous flashing led.
Testing with another Lacie power supply (250Gb D2) this time a 34w unit got the drive up and running, however, and this is the reason for this post, this lower power PSU failed a week later whilst waiting for a warranty replacement from Lacie (5 weeks and still waiting for the new PSU from them. they have no stock)
Message for all Lacie D2 users, check the power supplies first, test with another Lacie PSU, do not run the drive on a lower rating (34w) PSU it will fry it and leave you with another failed power supply.
If you are in a tight spot use the temporary power supply to move your data to another drive and get the correct 57w power supply before running the drive again.
Don't do as I did assume any Lacie power supply will run any Lacie hard drive, they won't, fortunately I had a second back up, but am 2 drives down and no new PSU's available to buy anywhere.
Try and purchase another spare 57w power supply, something all D2 users should do for long term security, as these do not seem to be very reliable and getting warranty support from Lacie on these is currently impossible.
The lack of 57w power supplies from Lacie and its distributors across the world is surely a warning to be noted!!!!!!
Buyers beware!
Posted on Sep 08, 2008
  • 39 Answers
SOURCE: Computer will not boot with Lacie Desktop Hard Disk connected.
You can enter the bios on bootup by pressing a special key to force your computer to go into BIOS mode. What key this is varies by computer, often it is F8, F10, sometines F11. Anyway, use the key for your computer, and change to boot modus to not first boot from USB.
Posted on Feb 09, 2009
iklln6
  • 35 Answers
SOURCE: Lacie 320 GB Hard Drive acting as if full when it's not.
Simplest solution: back up the data on the drive and repartition it (which will wipe it). Otherwise it sounds like it could be a problem with the file tree or structure of the drive, the configuration files could be corrupt, some program could have stored temporary files in a hidden place that cannot be deleted without making the program delete them, etc. If you are on a mac, spotlight Disk Utility and use it to repartition. If you are on a PC use the search thing from the start menu and find a program called disk management (or something similar to that, you'll know it when you see it.) external drives are annoying. i kick mine into the wall periodically for good measure.
Posted on Jul 15, 2009
leitusdotcom
  • 172 Answers
SOURCE: lacie 1 tb hard drive clicks and no recognition
Hi wes_unruh. Unfortunately that "click" , known as the click of death, can mean many things. It could be a head, System Area, scratched platters, etc. First, remove the hard drive from its casing. Then connect the hard drive internally to a computer. You might still get the click. Try a diferent angle and try many many times. Check the logic board for any signs of damage. Please DO NOT start swapping parts because there´s aligment, firmware issues and you can make things worse if you need to do Data Recovery. If you had important informacion, you need to take it to a data recovery company such as Ontrack or ADS, because they have the right equipment such as Deepstar, PCI3000 in order to fully retrieve your files. IT IS an expensive process. I hope this helps. Please do not forget to rate and provide positive feedback for our free support today. Thank you :D
Posted on May 02, 2010
Testimonial: "thanks for the help i seen similar answers but hoped that mine was possibly different or there was a way to fix it ill use the advice"
Geekman
  • 32281 Answers
SOURCE: Hi My hard drive lacie minimus
If your computer or laptop has a problem detecting a USBhard drive or a USB device, and another computer can detect it, then theproblem could be a RF interference problem. Try using an USB cable that is a shielded USB cable (ie. AnUSB cable that has a clear plastic covering and you can see a metallic weavewhich covers the wires) OR a USB cable that has a Ferrite core attached to theUSB cable (the ferrite core is a cylindrical object approximately 30mm long X15mm diameter and it is attached to the USB cable near the connector).
Posted on May 20, 2011
I cant see my external lacie hard drive on my mac. Was part of an ethernet network and able to use ok by 2 imacs and p. All of a sudden not visible anymore.
Just contact www.lacie.com great support. their answer for my drive was to upgrade the drive version and to reboot the drive. Maybe the last thing is enough. For me it worked.
If necessary update driver http://www.lacie.com/nl/support/drivers/driver.htm?id=10156
Follow the procedure below to reset the Network Space to factory defaults:
  1. Move the power switch to the OFF position. Wait for the drive to shut down.
  2. Turn ON the drive.
  3. Within about 3 seconds, flip the switch OFF and On several times.
  4. Immediately turn it ON
If the light flashes quickly, the unit is resetting itself. Attempt to connect to the drive again after about 1 minute using the default username and password (by default, they are both admin.)
Feb 04, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
My lacie hard disk 1tb all of a sudden isnt
Just contact www.lacie.com great support. their answer for my drive was to reboot the drive. For me it worked.
Jan 27, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
I have external hard lacie it work normal before two day but now it cannot detect
Dec 08, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Device i/o error on 500gb external usb hard drive, less than 6 mo
perhaps this? http://www.lacie.com/us/support/support_manifest.htm?id=10253&guideid=10167
Apr 01, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Data disappears from hard drive
nope...retrieve is always more expensive..i recommend an online backup, like mozy dot com to keep this from being an annual event for you.
Oct 13, 2008 | LaCie F.A. Porsche (301177) Hard Drive
Can't restart, can't connect
Please check the smps this type of problams are coming whaen smps is not working corrctley than cheack with ram slots also please verfiy the whare the problam is check one be one
Jul 21, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Lacie hard drive nonfunctional
You can try buying a new HD enclosure, then removing the HD from inside the one you got and mounting it inside the new one. Try also disconnecting completely the power cable from your computer for five minutes and then plug it back to the power and restart it. I know it sounds weird, but sometimes usb mass storage devices suffer troubles caused by electrostatic charges.
Hope
Feb 13, 2008 | LaCie Design by F. A. Porsche 160 GB Hard...
Lacie drive won't mount
I solved the problem. It was a power supply problem. It seems after searching boards on the net, this is a common problem with the lacie hard drives. Just replace the power if your hard drive is clicking and not mounting. I think many people must be throwing the drives away thinking they are lost when it is just the power supply. Try this first before trashing it or spending a lot of money on data recovery programs/
Nov 13, 2007 | LaCie 250GB Ext/Firewire 7200 250 GB Hard...
LaCie 1 TB Hard drive won't boot
I lave lots and lots of experience with LaCie Drives (I have 6 of the 2TB models). Every, every, every time a drive fails or runs slowly, it is the power supply. I have now replaced 5. They run very hot (so does the drive), and fail pretty often. It looks like the voltage drops just a smidge, and access times seem to increase, i.e., the drive "runs slow". Then it won't boot at all, and the blue light keeps blinking. Fortunately LaCie has replacement power supplies in the store. Buy a couple extra. I am married to the LaCie drives now, or I would probably switch brands. I kind of guess that they know about this because I contacted the help desk, and he wasn't surprised. Maxtor has a nice drive, and the Calvary drive is $150 cheaper. A drive is a drive I guess. By the way, if anyone is listening, how about building a QUIET, COOL drive with and INTERNAL POWER SUPPLY? GOT IT? All the cords and power supply bricks make me crazy. It might be nice to see a stackable drive where the top of one drive mates to the bottom of another, carrying network info as well as power to the drive above. Hint, hint. We all are building systems with ungodly amounts of storage. Too bad the manufacturers aren't building drives with the durability we need.
Oct 08, 2007 | LaCie (301074) 80 GB Hard Drive
LaCie Hard Drive
The hard drive has it's own power supply. If you look on the back of the external hard drive, there is a power button there to turn it off. It doesn't shut off just cause you disconnect it from the PC or turn the PC off.
Feb 01, 2007 | LaCie (300951U) 500 GB Hard Drive
LaCie (300728U) 250 GB Hard Drive Logo
1,028 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
