Question about Xerox Phaser 6250DP Laser Printer
Xerox 6250 - Jam at Registration Roller
I have 3 Xerox Phaser 6250 printers and they are all having the same problem. On almost every print job, the printer acts like it's going to start the job but first sheet of paper is does not get picked up by the D-shaped pickup rollers, it just sits in the paper tray. I get a "Jam at registration roller " error, but there is no paper jammed anywhere in the printer. I have followed the instructions on the other solutions on FixYa as well as the Xerox support site, checked and cleaned all the rollers and looked for scraps everywhere I could. Any ideas? Thanks!
  • virchow Jan 06, 2009
    i have the same problem.
    says jam at registration roller, but I can't find a jam. the roller does not spin freely. I don't see the d shaped tabs.
Use the bypass tray and print from it.
and replace the mechanisn and rollers pulling the paper from the bottom tray.
Posted on Mar 01, 2012
  • Chris Redman
    Chris Redman Nov 03, 2013
    A good idea for a temporary work around, got me out of a hole, thanks.
    President:
  • 2,072 Answers
Are the tabs in those D shaped rollers broke?
They will snap off into the shaft, but still be on the shaft. Not uncommon.
reach in and hold the steel shaft with one hand and see of those rollers spin freely. If so the plastic pins inside the roller have broken. It is not uncommon on that machine. Pop one off and see if there is a plastic pin inside the roller.
Posted on May 02, 2008
Ik heb een deregelijk probleem gehad, ook bij merdere printers tegelijk. De oorzaak was achteraf logisch. We hadden een nieuwe zending briefpapier waar een bepaalde film op zat waar de printer niet tegen kan. Logisch, want het kan niet zijn dat alle 3 printeres tegelijk hetzelfde mankeren.
Ander papier erin. De eerste hoeveelheid zal nog problemen geveb tot der olletjes vrij zijn van de vettigheid.
groeten,
G.Eijken te Hoorn
Posted on Nov 15, 2008
How do you reset transfer roller count on phaser 6250
I have a XEROX 6200 Printer. I tried to do the solutions above, but I did not have those options in the Maintenance Menu. I pulled out the Transfer Roller Unit and opened up the two screws on top. When I pulled the top, it was loaded with toner. I poured out all that toner in the trash and blew out the rest with a air gun till it was clean. Be careful of the two white gears on the side, when you take off the top. You don't want to lose them. Anyhow, I reassembled the unit back and stuck it back into the printer and the error message was gone. Yeayyyyyyyyy!
May 14, 2010 | Xerox Phaser 6250 Laser Printer
Jam at registration roller?
I can tell you "exactly" where your jam is !
If you open the top cover and remove the imaging unit. Look straight down, and you will see a black rubber roller about 8 inches long. this is the registration roller. If you remove the four screws (two on the left side, one in the middle, and one on the right) and gently lift up your wrinkled paper will be right there. Since your are not replacing the registration assembly you do not need to remove the two connectors that attach to the main board from the registration assembly. Just remove the paper, reseat unit, and put back screws. There is a test to see if your unit has the fix that gives the drive assembly a little more power to aviod jams in the future. This is a software fix.
I believe it's available on the xerox website as a postscript snippet. xx.ps
Mar 17, 2009 | Xerox Phaser 6250 Laser Printer
Phaser 6250
That problem is the registration clutch.
You have to order the registration assembly to get the clutch. It is located on assembly with the black and stainless steel roller, you have to pop out the imaging unit to see it.
But that WILL fix your problem. They changed the style of clutch also. It is more reliable now.
May 01, 2008 | Xerox Phaser 6250DP Laser Printer
Xerox Phaser 6250N Jam at Registration Roller
I use to have the same problem, but downloaded a fuser patch at the Xerox site:
http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi?new,kb=Phaser_6250,company=%7B5AC8CA72-62D5-4658-8D6F-D2F393C98A63%7D,ts=xo,ques=ref%28security_level%29:1,ques=ref%28Country%29:45,/,case=R1001052703
if that link doesn't work, go to the Xerox site and look in the area:
Home > Support & Drivers > Phaser 6250 > Knowledge Base
ID: R1001052703Phaser 6250 Support Knowledge Base Jam at Registration Roller (code Jam RR)
Follow the instructions and hopefully your printer problem will be resolved.
Apr 18, 2008 | Xerox Phaser 6250DP Laser Printer
Xerox Phaser 6250 started printing bad
That really sounds like the imaging unit cleaner has an issue.
If you have one try the imaging unit, I really suspect that is your problem.
Black is Faded or Missing Step 1 Clean the Laser Windows and Remove Excess Toner From the Imaging Unit Step 2 Check or Replace the Imaging Unit Gear Retaining Pin Step 3 Replace the Imaging Unit (installation instructions) ic-film.gif
See if this link works. Xerox is infameous for these not working.
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=842,E=0000000000019251353,K=6024,Sxi=13,Case=obj(19377)
Apr 08, 2008 | Xerox Phaser 6250DP Laser Printer
Xerox Phaser 6250
How Brave is Jan?
Doubt it be the fuser(100 000life), "just magenta dots".... fuser would be "all smudged" or "black marks" , "the print rubs off" , "paper is creasing or jamming"
Can prove it by stopping a print (open door) when paper is1/2 way threw machine, you need to stop it before it goes threw the hot bit, so you can tell if the hot bit (fuser) puts the marks on the paper.
Transfer roller one would expect to effect whole print Smudged/Faint,uneven density
It will be the imaging unit ( 30 000 pagelife Ouch$ ) or possible leaking toner (if aftermarket)
Remove imaging unit and inspect film you should find image of lines, dots are usually chips or sticky stuff on drum surface, carefull no oily human fingers on surface please.
When stopping machine mid print and perfecting your timing, pull out the imaging unit and look at replica of your print notice if marked and where.
Hope this helps
Nov 19, 2007 | Xerox Phaser 6250 Laser Printer
Phaser 6250 transfer roller
Hi clwest: I hope that this will help you.
Transfer Roller is at End of Life
■ Print the Supplies Usage page to verify the remaining life and Transfer
Roller install date.
■ Cycle printer power.
■ If the problem persists, follow the procedure below
Note
Look at the clear plastic window on the Transfer Roller. If toner is present in the
center of the window the Transfer Roller is at end of life and needs to be
replaced. If no toner is visible, try cleaning the CTD (ADC) Sensor.
The “Transfer Roller is at End of Life” is a warning. “Replace Transfer Roller” is
a hard stop.
Dec 15, 2006 | Xerox Phaser 6250N Printer
Xerox Phaser 6250DP Laser Printer Logo
1,566 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
