My Samsung LCD LA32B350F1 switches itself off 1sec after switching it on
5 Suggested Answers
SOURCE: my GVA LCD flat screen TV switches itself off as
My flat screen will not turn on the green light flashes for a while then stops
Posted on Mar 03, 2010
legna
  • 53 Answers
SOURCE: tv switches itself off then back on again
It seems that the back light is malfunctioning or needs to be replaced the fact that it turns off after a few seconds indicates that is getting over heated. All LCDs, Plasmas and Projection TVs come with a shut off switch witch will turn of the monitor when a spike on the temperature is detected this is to protect the system from overheating. Now before you think about send it for repair; is it well ventilated? Does air circulates around it? Good luck!
Posted on Aug 28, 2007
SOURCE: samsung 42'' lcd keeps switching off and on
I have the same problem
Posted on Dec 23, 2008
SOURCE: i have samsung lcd la32b350f1
I have samsung lcd tv model LA32B350F1 no power & no standby
Posted on Mar 15, 2011
Visco vsc20v1 will not powers on and right back off
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 22, 2013 | Element Electronics FLX3711B 37 in. LCD TV
Changing the window switch in a 1999 Mercury villager
check whether the windows has to be reset if I am right according to some vehicles I know just sit in the car turn the ignition on, and try from your main window controller by pressing both buttons of the opposite window you changed the switch for down 1sec, up 1sec and do it up to three times and see what it comes. If it is the same check it with an electrician.
Aug 24, 2012 | 1999 Mercury Villager
My Samsung LCD LA32B350F1 switches itself picture off 1sec
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Aug 04, 2012 | Samsung Televison & Video
Tv lcd samsung la32b350f1 problem with moduletor the power supply
HiIhave a Samsung LA32B350F1 LCDTCgetsoffafterclearlightboards
Jul 12, 2012 | Samsung LN Televison & Video
Lcd flutter ln-46c610
You might want to call Samsung with the model number as I remember seeing a notice for certain models that have this issue---a jumper plug needs in those sets to be removed that is located on the power board.
Apr 30, 2012 | Samsung LN46C610 LCD TV
Turning the power on causes the screen to display ENVISION for approx. 1sec.and it goes out and stays out. Switching a display signal on through an A-B switch gives approx. a 1sec. display time that does...
Your power supply has burnt out which unfortunately is extremely common in new devices. I do agree that it may be worth fixing if it is only couple years old.
Jun 11, 2009 | Envision EN-7220 17" Flat Panel LCD...
Televison & Video Logo
Top Televison & Video Experts
