Question about Hotpoint Ultima WF860 Front Load Washer
HOTPOINT ERROR CODE H20
  • Bev-La May 19, 2008
    Water is definitely entering the machine. Even if I select a spin only (which surely doesn't take in water?) this error still comes up and the machine does nothing but whirr.
    Taps / hoses etc all fine
  • Anonymous Mar 14, 2014
    Hotpoint aquarius wmf560 won't start up error code H20 shown
Either a blocked filter or tap not turned on
Posted on May 02, 2008
Problem with a hotpoint wmf760 aquarius + error code h20 coming up
You may have soap & grease in the pipe that leads to the pressure switch. Remove and flush through and/or replace. dry before refitting.
Thus constant high would give pump faults (thinks machine still contains water). Constant low may cause over filling. If you have a plug that suddenly moves, that can cause the above errors.
Jan 02, 2013 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint aquarius wmf 740 has error code h20
Just had same problem with my hotpoint wmf740 showing h20 and found an easy fix was to clean out the detergent draw thoroughly and just behind it.to remove tray was easy and it does say to do this regulary in the manual
Jul 16, 2012 | Hotpoint Ultima WF860 Front Load Washer
Jandy AE-TI H20 error message - pool not heating
just looked at the manual for this unit. It does not list an H20 code. Is this all it says on the screen?
Nov 13, 2010 | Jandy Ae2500t 115,000 Btu Heat Pump
Indesit Evolution W16s washing machine H20 error code
if there a advance cycle button push it an see if the timer will advance to spin if not turn the power off to washer an wait a couple mintue an the door will open
Apr 24, 2010 | Washing Machines
Error code
H20 indicates incoming water supply problem.
Check that the water is fully turned on.
Check the inlet hose/s for kinks or restriction.
Make sure there is a good pressure of water to washer.
Please rate my solution.
Thankyou..
Jan 31, 2010 | Hotpoint Ultima WF860 Front Load Washer
H20 error
Hello
I used to get this when i lived with my mum & dad and i can honestly say that it was the water pressure with this machine only a small drop in pressure makes the H20 error code appear you can always add additional water when it comes on so that the cycle can continue. You could find out from your water board if the drop in pressure is a leak in your area?
I hope this helps i had to persist with this problem for 18 months untill a leak around the corner was eventually found and fixed.
Regards
Wendy
May 27, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error code h20
hi sounds like a faulty fill valve easy fix
Sep 17, 2008 | Hotpoint Ultima WF860 Front Load Washer
H20 error messages
h20 is normally a water valve problem please check these regards jason
Jun 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Ultima WF860 Front Load Washer Logo
788 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
