Question about Dryers
Dryer door latch broke cant find where to get new door or handle
  • Dryers Master
  • 3,740 Answers
I see someone actually offered to give you and answer for money.... ( I am appalled) I am going to post this as a solution but I do need your model number. If there is anyway I can point you to a parts source and usually I easily can... with a good make and model number please. Thanks for choosing FixYa.
Kelly
Posted on Aug 19, 2010
Sping in Emco storm door latch broke
I found a video that may help you listed below.
Best Regards my friend!
Mar 04, 2014 | EMCO Door. 300 Series 32 in. Bronze...
Back door won,t open on my 02 avalanche
door handle broke depends on what door handle it is.if door cant be open on out side out side door handle broke.if cant open door on inside inside door handle broke.door handle clip that connects to latch rod broken.when you try open door handle not engage to latch rod.door not going open.have to replace door handle with new clip holds latch rod in place.
Jan 09, 2013 | 2002 Chevrolet Avalanche
Door handle broke
This is not an identical one but is another LG that has the same latch setup. Hope these pics help.
Mar 07, 2012 | LG WD-16115FD Front Load Washer
2000 pont. gr am pass door only opens when you use door key to unlock and pull handle at same time , the door lock are auto. you can hear it unlock but cant open it normally
there has been lots of problems with the power door lock actulator on this model . you will need to remove the door pannel and then remove the door lock latch assembly and inspect to see if the actulator is broke . If it is broke then you will need to replace the latch assembly as i dont belive that the actulator comes seperate from the latch . but check with your local parts store or dealer
Mar 04, 2011 | Pontiac Grand Am Cars & Trucks
Left drivers door will not open from inside it does open from outside how to repair
you will need to remove inner door panel, either the handle itself broke where the rod connects,or the rod fell off or broke at the door latch, or the door latch lever bent or corrodded, the outer and inner handles use the same door latch but not the same mechanisms or rods to operate the latch. Once you remove the door panel and the inner dust shield with the window up look in the bottom of door for clips or a rod or broken parts. and note latch and handle for boken or bent and missing pieces. once you start looking it all becomes self explanatory.
Jan 15, 2011 | 1999 GMC Suburban
We broke the door handle on our Malber 1000 Can we order a new one and can we fix it ourselves?
Mike, in Washington D.C., again. Of course you can do it yourself. First call Joel (Malber in NY) at 800-600-8913 or 516-294-6660 . Tell him which model machine you need a door latch for (if you aren't sure, check label in rear). Once you've received your new latch assy (about $20): Open door, and notice white plastic "ring" around glass is actually 2 pieces (front and rear) snapped together - with a seam around periphery. Unsnap (separate) them by either getting your fingernails into the seam and pulling them apart - or prying them open with a spackle knife or thin screwdriver blade. Once it starts coming apart, just work the opening all the way around. Remove front "ring" and set aside. Using a 1.5mm Torx screwdriver, remove 2 small screws holding broken latch assy. Note the way the ends of the spring go under the 2 screws. That's the way it has to go back. Slip new latch assy into place, pressing vertical "hinge pin" and ends of spring into slots (near screw holes). Replace 2 screws. Test latch with door open - is it working? Try closing door. All good? Replace front "ring": Open door and, while pulling out on latch handle, slip the ring over the latch handle and get it into approximate position. Let go of latch (it snaps into "closed" position) and adjust ring so it doesn't bind the latch handle (meaning it's free to move). Now, beginning anywhere on outside edge, begin snapping rings together - and continue all the way around. Test that door latch still operates smoothly and that door latches shut properly. FYI: There is no adjustment for this latch assy - it just fits precisely where it's supposed to. Good luck and God Bless ...
Sep 26, 2010 | Malber WD1000 Front Load Washer/Dryer
Need a new door opening handle?? the handle broke
You should be able to order one from Splendide. In the meantime, try using a screw driver to manually push the door release button.
Michael Lee
Thor Appliance Company
www.thorappliances.com
Sep 22, 2010 | Splendide 2000S Front Load Washer / Dryer
Front soor latch broke
replace latch. Most are rivited however.Handle is screwed from inside door though
Mar 09, 2010 | Supra Washer Dryer Combo Portability Kit...
Dryer door will not stay latched and causes dryer
ew whirlpool duet steam dryer door will not stay latched and causes dryer to stop
Dec 20, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Door latch broken
Look in yellow pages if you are in the U/K, and ring Hotpoint service, who are the service agents for Ariston.
Please rate my solution.
Thanks.
Jul 19, 2009 | Ariston Technologies AWD120 13 lb. Washer...
Dryers Logo
51 people viewed this question
Top Dryers Experts
