Question about SanDisk Sansa e250 MP3 Player
Dont go towards the bright white light...
I turned on my sansa this morning, and all I get on the screen is a big, blank, white light. Tried recharging the battery, resetting the sansa itself, but nothings working, does anyone have any idea whats going on?
  • Anonymous May 02, 2008
    screen is solid white
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
My sansa e260's navigation wheel lights up but the screen is blank. what do I do . It may be the battery is completely dead. Bob L.
Your battery is not dead because if it was, then navigation wheel would not be lighting up. Your screen is blank because when you touch the navigation wheel, you probably decrease the brightness of the screen. Turn the wheel counterclockwise, as this will brighten up the screen display. Press the center button when done. Reply back if this solution does not help.
Mar 04, 2011 | SanDisk Sansa e260 MP3 Player
When trying to take pictures outside the screen goes blank.
Try to manually make it so that it is set to outdoor settings. Or maybe try low brightness and no flash.
May 12, 2008 | Olympus FE-190 Digital Camera
My Sansa E260 screen is too white
go to the settings of your MP3 player and check for contrast or Brightness. Lower either or both of these to get a dimmer screen(Brightness) or a less whited out screen(contrast)
Aug 06, 2010 | SanDisk Sansa e260 MP3 Player
I have a hitachi rptv model #43FWX20B and the picture has a red tint to it. Opened back up and red green and blue bulbs light up. red bulb stays bright while blue and green go dim to bright as tv plays....
Since you don't have any white lines with the red screen/picture I would say that the red bulb (CRT) is conducting too much. There is an adjustment control for that. The 'sceen' control is behind the speaker cover and service cover. Turn red screen control slightly to the left until you get a good black and white picture.
Good Luck, Big Irish.
Nov 22, 2009 | Hitachi 43FWX20B 43" Rear Projection...
Sansa View has a "ink blot" graphic and a white background when I turn it on.
if its an inkblot you broke your screen..... the same thing happened to mine and i'm still trying to find a place to repair the screen.... if i find anything i'll tell you
Oct 11, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
Bright White Screen
just turn of the player pressing the power button for 15 seconds, then turn the hold button on and off; turn it on and it's ready to continue watching
Jan 19, 2008 | SanDisk Sansa e250 MP3 Player
A blank screen
Try going to recovery mode by enabling the hold switch then press the record button then press the menu button until you see on the player screen welcom to recovery mode. Download the update from the sandisk site then install and run it on your computer. Then perform the update. Hope that helps.
Jun 14, 2007 | SanDisk Sansa e250 MP3 Player
Sansa screen
break something under warantee and send it in
Apr 27, 2007 | SanDisk Sansa e250 MP3 Player
Blank White Screen - No Menu Showing
My Sansa has a similar problem. Sometimes when the Sansa turns on (after the Sandisk logo) the screen will either turn black, blue, or black and white stripes. The player still works, but it is hard to navigate without the screen, obviously. What I end up doing is letting the backlight turn off and then pressing any button. Sometimes when the screen comes back, the display is allright again. But sometimes it takes more than a few tries. Turning it off and on again seems to work a little better, but it is more time consuming.
Apr 01, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
47 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
