Question about EuroTech Washing Machines
Hello, I have an old Eurotech TL700 washing machine (top loading). After a move to a new house the machine is not working properly. It seems that during the water intake phase the water enters the drum as it should but then goes straight out the drain again. The drum, therefore, doesn't receive enough water to move to the next phase of the cycle. The pump seems to work well (it operates). What device stops the water from the drum flowing straight to the drain pipe? Does the pump push the impeller out and block the drain pipe? Any answers/help much appreciated!
Jimster
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
  • 1314 Answers
SOURCE: Kenmore Front Loading Washer - Water in drum
please hold my rating till were done i need your model number to give you the proper procedure for checking your drain pump as i believe something in it is restricting your drain flow and three different companies build kenmore
Posted on Jan 11, 2008
SOURCE: Washer continuously fills but drains at the same time during rinse cycle.
Fixum 1 is correct. I had this same problem and by trial and error found this to be the problem. I never thought that the syphoning effect could occur, but it does and can be costly if you aren't minitoring your washer (ie water usage).
Posted on Mar 09, 2009
  • 236 Answers
SOURCE: LG WD-1049C Front Load Washing Machine Pump impeller sloppy
probably better change the pump if you feel any up and down slack in the impellor. you may have an ingress of water through the seal.
Posted on Mar 13, 2009
SOURCE: GE Profile wpre6100gowt, wont agitate or spin
same problem
Posted on Sep 06, 2009
Where to buy the bearing and seal for drum on front loading EWF272EL washing machine
It seems no bearing kit for this model. The drum bearing is hard to replace and seal it properly if you do not have special tool to do it.
Oct 22, 2013 | EuroTech Washing Machines
How old is the Whirlpool washing maching model # LSQ9549PWO...ser CR3028092?
July 19, 2004. go here and you can tell how old any appliance is by putting in the model,serial numbers and brand name.http://www.appliance411.com/service/date-code.php
Jan 24, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
My eurotech washer is making a horrible noise during the spin cycle...it wont drain or spin what do i do
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 28, 2010 | EuroTech EWF172 Front Load Washer
I've just moved house and my machine is not
Hello Friend, I think your machine will work properly if you add a water line splitter. You would connect to the single cold water tap and on the other end you would have two water hoses . Connect one hose to the cold water inlet of your washer and then connect the other hose to the hot water inlet. You can get these at Home Depot. Happy to help, Tim.
Jun 29, 2009 | Whirlpool Washing Machines
Grey Stains on my whites
Need ot check the main seal and the main bearing. You can do this by accessing the rear of the unit.
Feb 13, 2009 | EuroTech EWC177 Front Load Washer / Dryer
Manual for Eurotech MLD110
(copy and paste this link in your address bar)
http://www.ersatzteilonlineshop24.de/suche_ger2.php?model=MLD110&hersteller=Eurotech
Feb 01, 2009 | EuroTech Washing Machines
Eurotech front loading washer, noisy on spin cycle with load.
Hi, could be one of at least two things - if the inner drum can be moved up and down by hand more than an inch when you grab it through the open door it could be the drum bearings that have failed - not good. Usually accompanied by a grinding noise and dirty specks on the clothes.
If the outer drum is really loose in the casing - check with machine unplugged and top removed - then one or more of the very strong springs at the top or the telescopic dampers at the bottom might have come off or broken from it's mounting.
Hope this helps!
If it doesn't, please hold off the rating button and add a comment with more details so I can try to help you further. Cheers, D
Mar 26, 2008 | EuroTech EWF172 Front Load Washer
Urotech EWC177 Combo
Same problem here and mines brand new. Seems the dryer consists of only a heating element. There's no circulation of dry air. You may as well hang your clothes inside a steam room.
Mar 10, 2008 | EuroTech EWC177 Front Load Washer / Dryer
Machine vibrates excessively during spin cycle
Open washer's cover and look for a released or a malfunction shock absorber. Good luck!
Nov 08, 2006 | Maytag MAV4755A Top Load Washer
TD700 malber front load
I'm not familiar with that particular brand, but it looks like a eurotech, and we sell those pulleys by the truckload. They are made of a similar material and break if you look at them funny. You may however, check that the inner tub does not move up and down if you reach inside the wash area and push up on the inner tub. If it does, you have bearing problems and are going to need some serious work, otherwise replace the pulley and it should be fine. Hope this helps!
Oct 20, 2006 | Malber P25 Front Load Washer
Washing Machines Logo
101 people viewed this question
Top EuroTech Washing Machines Experts
shaun taylor
Are you an EuroTech Washing Machine Expert? Answer questions, earn points and help others
