Question about Canon imageCLASS MF6530 Monochrome Laser Copier/Printer
Paper is jammed, and cannot get a tech out to fix it
Paper is hung in the wheels of the copier, and can't reach the paper.
Any suggestions on how to get it out!
    Genius:
  • 3,587 Answers
Hmm..well...you may need to partially disassemble the sides, to get to those traction rollers..or you might be able to open up the back section, and see what's trapped in there..
Posted on May 02, 2008
I've got a 4 by 6 photo paper jam in my Lexmark S405 all-in-one printer.
Please follow the steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Try to reach for the paper jam.
3. If paper jam can't be reached, open the printer cover to access the cartridge area. You may be able to get a better hold of the paper jam in the cartridge area.
4. Remove the paper jam and make sure not to tear or leave any torn piece of paper in the printer.
When paper jam is clear, try to print a document again to verify that the problem is fixed.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 01, 2011 | Lexmark All-in-One Printer with PictBridge
I have a transfer paper jammed and can't reach any
Try to open the printer where the cartridges are. You might be able to get a better hold of the paper jammed in there. Otherwise, I suggest you contact Lexmark Technical Support for further assistance. Thanks
Jul 16, 2010 | Lexmark X2600 InkJet Printer
How can i fix a paper jam
The simple answer is to tell you to remove the paper jam. Make sure you get the entire page out of the printer.
There are two types paper jams.
1) An actual paper jam.
2) If paper does not reach any of the paper path sensors in the time allotted to reach it, the sensor reports a jam because something prevented the paper from reaching the sensor.
A quick test would be to place some marks on the top sheet of paper then initiate a feed cycle. If the paper stays in the tray, then you have a paper pick problem and more than likely you will need to have the printer serviced.
Don
Dec 14, 2009 | Dell 924 All-in-One InkJet Printer
Paper jams when folding 8 1/2 X 11 ivory paper; less often with white. Tech says it's a paper issue - so whose colored paper (brand) will work - or is it a design flaw?
Is this paper the same weight/thickness as the white paper?
Are you specifying the settings properly as far as the weight and type?
It sounds like the sensors are detecting a double feed(?)
Try different settings for the tray, and even try a different brand of stock to verify.
Apr 29, 2009 | Konica Minolta bizhub C450P Laser Printer
CONTINUING PAPER JAM. I OPEN DOOR, CLEAR THE JAM, AND PAPER STARTS TO FEED, THEN AGAIN ANOTHER PAPER JAM, AM I USING WRONG PAPER?
I know the problem, Its the Exit paper sensor! if u make a short circuit on the pin 2 and 3 of the CN2 when the paper reaches the sensor it wont jam. Chainging the sensor resolves the continous paper jam or try to clean it!
Apr 08, 2009 | Samsung CLP 315 Laser Printer
Epson cx11nf paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 03, 2009 | Epson ACULASER CX11NF All-In-One Printer
Help
H5-01 indicates tha the paper sensor is defective in the fusing unit. The only way you can try to reset that one is buy turning the power off, wait 30 seconds and turn the power back on.
If the error code returns the fusing unit will have to be fixed to take care of the paper sensor.
Jul 20, 2008 | Sharp AR-M237 Digital Copier
How to clear internal paper jam on CLX-3160FN Samsung Multifunction Printer
Get rid of it. Your problems will only get worse. Mine is going to the landfill.
May 18, 2008 | Samsung CLX 3160fn All-In-One Printer
Paper jam
After the fuser, problably near the exit rollers, there is going to be a switch/sensor, that has a problem. It could be hung up, out of position, ect, but you have a typical exit sensor problem.
Feb 24, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Canon imageCLASS MF6530 Monochrome Laser Copier/Printer Logo
96 people viewed this question
old marine
old marine
