Question about Weather King Heating & Cooling
Fan unit start but not cooling dispite attempting try been statinary for long period of time
  • Weather King Master
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Aug 19, 2010
AVE ERROR CODE 5351 WHAT IS IT?
C5351 Power Supply Cooling Fan Motor Failure The Power Supply Cooling Fan Motor Lock signal remains set to H for a set period of time while the Power Supply Cooling Fan Motor is turning. • The Power Supply Cooling Fan Motor Lock signal remains set to L for a set period of time while the Power Supply Cooling Fan Motor remains stopped.
Aug 26, 2015 | Computers & Internet
Remove c-24 errorminolta di450/500
Sir/Mam,
C0F24 Code is the code for the sensor that monitors the drum. I would remove the drum cartridge two black screws pull out the drum assy. Remove the drum be careful do not nick or harm the drum the sensor is located on the left side of the to the rear of the of the drum looks like to little eye of a bug. Dust with a brush NO VACUUM static could destroy it. Re-install drum and re-install cartridge. When the last time a PM was done Developer replaced and Drum replaced?
Dec 14, 2014 | Minolta Office Equipment & Supplies
Indoor unit fan blows, then stops etc. every 1-2 minutes
At least it is cooling properly. U might just want to call Mitsubishi and ask them if it is operating normally based on your observations.
Apr 30, 2017 | Mitsubishi 18000 Btu Mr.slim Ductless Mini...
Error code 5351
Motor Failure
stopped.
Jul 17, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
We have one of the ACC108PS air conditioners that is not cooling right - do we need freeon - if so is it rechargeable?
Start your window air conditioner troubleshooting with checking the different modes of operation to see which components operate. Turn the unit fan to on and the cool and heat modes off. If the fan does not operate, check the power supply to the unit. Check to see if the breaker or fuse for the unit is tripped. If the breaker/fuse is tripped, check to make sure that it is the proper size circuit for the unit you have. On some units, there is a current interrupter on the power cord to the unit. Check to see if it is tripped by pushing the reset button.
If the circuit is the proper size, then you can go ahead and reset the breaker/fuse. If it trips again, then you require further troubleshooting. Shut the power off and check all of the wiring in the unit to make sure that none of the connections is loose or damaged.
If the fan does not operate but the fuse/breaker is not tripped, you should check the run capacitor for the fan and compressor. If the capacitor is good but the fan motor does not operate, you can check the fan switch and the fan motor. Ensure that the fan blades spin freely.
If the fan motor operates but the compressor does not start, change the capacitor but first you should feel the compressor with your hand. If it is very hot, then you should allow it to cool.
Then, you should attempt to start the unit in the cooling mode. As you do so, listen for a clicking sound which is an indication that it is attempting to start. If the compressor starts but does not cool properly, the unit may be low on refrigerant.
If the compressor attempts to start but shuts off very quickly, the compressor could be bad. You could try installing a "Hard Start"
If the compressor does not attempt to start, ensure that the thermostat is set below room temperature. On units with a mechanical control, you will hear a click when you adjust the temperature. That is an indication that the thermostat is working properly.
Jul 12, 2011 | Whirlpool ACC108PS Air Conditioner
Fa n unit start but not cooling dispite attempting try
Check breaker and check voltage at wall
Also check compressor relay.
Go to appliance parts store for instructions on relay.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 19, 2010 | Weather King Heating & Cooling
MY unit is not cooling. fan in not turning, top
It sounds as though your outside motor has failed. If you have a long shafted screwdriver, you can attempt to spin the motor to see if the motor has seized up. Caution should be used as the motor may start if the unit is calling for cooling when you attempt this. If you can manually start the motor, then chances are the capacitor has failed.
Check it out and replace the motor if need be. That should get you back up and running.
May 26, 2010 | Goodman CKL24AR24 Air Conditioner
Have moved into a house which has a honeywell CM5000 heating system but dispite resetting the time date and temperature in each room it still won't start.Have had the airconditioner on during the summer...
dont know the square footage of your home or how many units you have. unless you are in and out of your home for long periods of time and need a digital thermostate. get rid of it. install a 30 dollar honeywell or call a prof. to f@##$%^you.
Apr 25, 2009 | Honeywell Electronic Programmable...
Roper fridge not cold
That is then the first thing you will need to insure is running. The fan can be removed and checked. Now if the compressor is not running I would believe you have another problem. You can hear or feel the compressor running and the fan is usually connected to the compressor wiring so they both should be running at the same time. I have seen the fans run for a short period of  time after the refrigerator was turned off and then back on after cooling, so if stopped and starting of the condenser fan can at times trick you to believe the fan is OK
 Hope I have been helpful, Sea Breeze
Oct 28, 2007 | Roper RT21AKXKQ Top Freezer Refrigerator
Heating & Cooling Logo
29 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
