Question about Weather King Heating & Cooling
Fa n unit start but not cooling dispite attempting try
    President:
  • 3,773 Answers
Check breaker and check voltage at wall
Also check compressor relay.
Go to appliance parts store for instructions on relay.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 19, 2010
We have one of the ACC108PS air conditioners that is not cooling right - do we need freeon - if so is it rechargeable?
Start your window air conditioner troubleshooting with checking the different modes of operation to see which components operate. Turn the unit fan to on and the cool and heat modes off. If the fan does not operate, check the power supply to the unit. Check to see if the breaker or fuse for the unit is tripped. If the breaker/fuse is tripped, check to make sure that it is the proper size circuit for the unit you have. On some units, there is a current interrupter on the power cord to the unit. Check to see if it is tripped by pushing the reset button.
If the circuit is the proper size, then you can go ahead and reset the breaker/fuse. If it trips again, then you require further troubleshooting. Shut the power off and check all of the wiring in the unit to make sure that none of the connections is loose or damaged.
If the fan does not operate but the fuse/breaker is not tripped, you should check the run capacitor for the fan and compressor. If the capacitor is good but the fan motor does not operate, you can check the fan switch and the fan motor. Ensure that the fan blades spin freely.
If the fan motor operates but the compressor does not start, change the capacitor but first you should feel the compressor with your hand. If it is very hot, then you should allow it to cool.
Then, you should attempt to start the unit in the cooling mode. As you do so, listen for a clicking sound which is an indication that it is attempting to start. If the compressor starts but does not cool properly, the unit may be low on refrigerant.
If the compressor attempts to start but shuts off very quickly, the compressor could be bad. You could try installing a "Hard Start"
If the compressor does not attempt to start, ensure that the thermostat is set below room temperature. On units with a mechanical control, you will hear a click when you adjust the temperature. That is an indication that the thermostat is working properly.
Jul 12, 2011 | Whirlpool ACC108PS Air Conditioner
Diplomat intergrated dishwasher error code FA
FA is a problem with the tubidity sensor. By holding down the power button, it stops, but just repeats everytime you try a new wash cycle. So keep doing it and you can atleast use it. If you want to go one step further and find a permanent solution try feeling around in the sump (where the filter slots in) being careful for any broken glass. Other than that it will probably be a strip-down job to examine the internal hoses and the pump; not a DIY job to be honest.
Feb 03, 2008 | Dishwashers
Fan unit start but not cooling dispite attempting try been statinary for long period of time
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 19, 2010 | Weather King Heating & Cooling
My Fujitronic FA-1310S Air Conditioner makes banging sounds when it's in cooling mode. How can I fix this? Thanks.
if the banging noise only happens when the compressor turns on or off then check the compressor shock mounts .. the compressor is mounted on rubber or spring mounts . if they are out of place or damaged then the compressor will hit the sides as it comes on or turn off .. if the unit was stored upside down or on its side then there is a good chance that the shock mount is out of place ..
Aug 15, 2010 | Fujitronic FA-1310S Air Conditioner
MY unit is not cooling. fan in not turning, top
It sounds as though your outside motor has failed. If you have a long shafted screwdriver, you can attempt to spin the motor to see if the motor has seized up. Caution should be used as the motor may start if the unit is calling for cooling when you attempt this. If you can manually start the motor, then chances are the capacitor has failed.
Check it out and replace the motor if need be. That should get you back up and running.
May 26, 2010 | Goodman CKL24AR24 Air Conditioner
After the re-tune session today there is no Chan
Look at the bottom of the channel list 800 onwards and you may find it there. I have not found a way of moving them to the correct channel numbers yet still trying.
Sep 30, 2009 | Televison & Video
Need to replace Cooling fan, can't figure out uninstalling the fa
You can go to autozone.com and register for free. Then you will have a full free online repair manual with illistrations and much much more
Aug 17, 2009 | 1995 Mercedes-Benz E-Class
FA 1300 NOT COOLING WELL. IT SEEMS TO KICK ON BUT THEN TURNS OFF AND IS NOT BLOWING COLD AIR
Hi there. If unit just starts to get cold then the compressor shuts off and if the compressor comes back on after 3 to 5 minutes, the system has a freon leak or the compressor is over heating.
If you are technically inclined, search for leaks using soapy water at all tubing connections.
For overheating compressor: Clean the condenser with compressed air or vacuum cleaner. If still overheating, start switch or start capacitor may be bad.
Thanks
Paul
Jul 12, 2009 | Fujitronic FA-1350 Air Conditioner
Have moved into a house which has a honeywell CM5000 heating system but dispite resetting the time date and temperature in each room it still won't start.Have had the airconditioner on during the summer...
dont know the square footage of your home or how many units you have. unless you are in and out of your home for long periods of time and need a digital thermostate. get rid of it. install a 30 dollar honeywell or call a prof. to f@##$%^you.
Apr 25, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
John Tripp
John Tripp
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
