Question about Denon Audio Players & Recorders
RCD -M37 that displays V PROT and goes into standby mode when power switched on. Have checked the normal problems that cause this - as per owners manual - but no joy.
dunnbiker
  • 8546 Answers
SOURCE: Denon RCD-M37 turns on when
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it '*****'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Aug 04, 2011
  • 323 Answers
SOURCE: Hello. I have a fairly
Try this: Press and hold the "tone" button for 5 seconds. This will reset the unit.
Posted on Apr 20, 2008
SOURCE: goes into standby mode
press the off/on buttun and keep it pressed in while pressing the standby button... it should fix it
Posted on May 31, 2009
Bulldog AV
  • 52 Answers
SOURCE: after turning ON the power/standby switch, the
Is the red light flashing at first?
The unit may be going into protect mode. Lets hope it has done the job and the receiver has protected itself from failure.
Protect mode can result from speaker wires touching each other or the Amps2_bing.gif metal case. Check that first.
It can also be caused by unstable ohm loads if too many speakers2_bing.gif are connected to any of the outputs especially zone 2.
If you can remove all speaker wires and turn the unit back on. If it stays on, turn the volume down on the main zone and zone 2 if connected. Then reconnect speaker wires.
Posted on Nov 24, 2009
dunnbiker
  • 8546 Answers
SOURCE: what type of sub-woofer can
Free or you can tempt us with $$. Your choice.
Register and download the manual for free at audio.manualsonline.com
http://audio.manualsonline.com/manuals/mfg/denon/rcdm37.html
Self-powered would work but it would have to run on full-range amplifier (from the speaker posts) or Line Level signal (from the OUT RCA jacks) because this unit has no Sub-specific output. It's no bigge as the sub would naturally discard the higher frequencies via its own amp's and speaker
Posted on Feb 22, 2011
Hi, i go into the test mode and it starts on 18 and when it gets to 14 the house electricity power trips off.Any idea what part do i need to replace?
How can I figure out why my washing machine is tripping the ...
diy.stackexchange.com/.../how-can-i-figure-out-why-my-washing-machi...
Aug 17, 2012 - 110.24872300) washing machine which up to this point has been ...Note what is happening when it trips (is it starting to spin, starting to drain, filling, etc.).... If the outlet trips when the washing machine isn't running and isn't ...
Washing machine tripping RCD « Singletrack Forum
singletrackworld.com/forum/topic/washing-machine-tripping-rcd
Switching on the plug socket that the washing machine's plugged into caused no problems, but switching the machine itself on trips the RCD. ... then its possibly the water fill solenoid as most cycles start with a water fill. ... I've always guessed it is theelectricity/water combo somewhere in the machine so err on the side of ...
Nov 29, 2015 | Washing Machines
Tip
Denon VPROT Problem.
I posted a question regarding a Denon RCD-M37 DAB, which after a repair to the sub power supply transformer, came up with VPROT after a few mins use. After very careful measurements I found that the -12Volt line coming from the power regulator board situated behind the mains transformer was measured at 10.5Volts. It is necessary to replace the LM7912 regulator. Whilst with this board out check soldering and all other components. Normal operation has now been restored. I hope this will help regards Paul R.
on May 08, 2015 | Denon Audio Players & Recorders
My IBM thinkpad T60 goes into standby mode when restarting. Normally happens when windows XP in about to start. When try to restart it displays preparing to standby. Keeps repeating the same when try to...
Sounds like problems with software. Can you boot to safe mode, enter power option settings and turn off the standby mode to test this?
If this fails, and you can access the Bios, check the hibernation/ power settings in there. i think there is an option to adjust the behaviour on reboot.
Failing that, and if you can find another hard drive, test the laptop using that one. It may be a fault with the hard drive being damaged and preventing booting. Also check the ram by swapping it out.
After that, I'd suggest getting another hard drive or re-installing windows on the old one, you can do an over the top install (saves existing files) if the info on the drive is important. to do this, wait until the installation prompts you to look for an existing installation of windows and repair at that point.
If none of the above, you have a hardware fault, that may be caused by a faulty switch (check the on / off switch is not sticking), or a fault on the motherboard
Jun 16, 2011 | Lenovo ThinkPad R51
I have a sony kf50we610 when i go to turn it on i get 3 blinking red lights. the television will not turn on. what do i do?
Normally that can be caused by an over voltaeg from the power supply.
B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Apr 04, 2011 | Televison & Video
I replaced the main board in my sony Kdl-32S300. When turn on power, the back light flashes 3 times then goes into standby mode after which the standby light flashes 12 times in sequence. What could be...
Have you set the output voltage correctly?
Mar 24, 2011 | Sony KDL-32S3000 32 in. LCD Television
Cd ejection tray
From Standby press function, whilst holding function press power (both on the main unit).
The display will show demo mode, this has now disabled the mode.
Regards Graham
Jul 25, 2010 | Denon D-M33 Shelf System
TURN OFF LOCK. I AM IN MENU MODE, BUT WHERE IS THE ON/OFF BUTTON LOCATED?
Power on…Turn the POWER switch ON.
If the POWER switch on the backside of this recorder is
turned OFF, it is not possible to use any of the functions.
Turn the POWER switch ON before operation.
Power off…Turn the POWER switch OFF.
Standby Mode and Display Shut Off
If the recorder is stopped for 5 minutes or longer during recording or playing, it goes into
Standby (power-save) mode, and the display shuts off. To exit Standby mode and turn on
the display, press any button.
Locking a file keeps important data from being accidentally erased.
Locked files are not erased when you choose to erase all files from a folder.
In Menu mode selection... On, OFF
On: Locks the file and prevents it from being erased.
OFF: Unlocks the file and allows it to be erased.
Feb 02, 2010 | Olympus WS-100 Digital Voice Recorder
After turning ON the power/standby switch, the unit(receiver) display comes ON (green light) then after approx.4-5 seconds the display goes OFF and the unit defaults back to the standby mode (red light). I...
Nov 16, 2009 | Denon AVR-485 Receiver
TV GOES ON STANDBY WHEN IS TURNED ON
tv might be in display mode, check with owners manual on how to diable this mode.
Mar 29, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
1,652 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
