Question about HP Compaq Business Notebook 2230s
My laptop is locked it has a password,i cant access the recovery partition and i want to format the machine.any help pls?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 152 Answers
If is the windows lock administrator password press F5 and go to safe mode and remove password from control panel if is the bios password remove the battery from the motherboard for 5 second then put it back
Posted on Aug 19, 2010
One key recovery button doesnt work how do i factory reset bypassing it
Forgot your administrator password ? If this is the case I hope you have a recovery partition on the machine or got a recovery cd if you have a recovery partition you access it in bios
Apr 14, 2016 | Lenovo IdeaPad S10-3 Netbook
Hi every bodey i have did format my laptob it's sony vgn-cs230j/w he is an american system so the did gone i dont know how ,i just did format the laptob and i did install another windows then after time...
It seems that you have formated you laptop with CD. It has formated the recovery drives so you need to reinstall your laptop with CD if shipped with the laptop. F11 would not work in this scenario if you have already formated the Laptop with other CD coz whenever you format the drive and create partition with any third party CD it normally delete the Recovery partition from the laptop. If the case is such then you cant get back you old recovery partition. But you can create a recovery disk from the same laptop if you can find... one with any friends etc and then re-image your laptop with that disk. After that all the setting will be back. Or you can contact with SONY support for the same issue they can provide the same disk.
Apr 23, 2011 | Computers & Internet
My daughter reset the password on her webbook gateway windows xp- called the store i bought it from and they told me i have to format the thing but that all i have to do is hit F12 or someting and it will...
All modern laptops are coming with a hidden recovery partition - this way they no longer have to give you separate recovery disks so they save some bucks.
Press F12 while the laptop starts - you will be presented with an screen with at least 2 options : to boot from the install partition or to access the recovery partition - select the second one. Once you have done that it will be just like you would have used regular recovery disks - follow the instructions on the screen.
Feb 01, 2010 | Computers & Internet
Acer asire 5920 wont boot up cant get to windows to type anything in just a black screen asking for password or harddisk password. have acer aspire 5920 system disk it works asks for recovery disk 2 runs a...
For the psswords i can recomend to reset them from BIOS but to do that you must first know them. The problem with recovery disks is solvable if you boot from an XP disc and format the C: partition in NTFS file sistem and when it starts copying files to install the windows stop the installation ( F3 or press the power button for more than 4 seconds.. don't worry you will not sustain disk damage... done it myself with the same notebook for a dozen times ) After formatting the partition C: try recovery again and it will work.
NOTE: for the formatting of the partition you must set the HDD mode from AHCI to ATA witch permits the XP setup utility to "see" the HDD. If it is set in AHCI mode the setup utility for windows XP will not detect youre HDD
Jun 16, 2009 | Acer Aspire 5920-6727 Notebook
I formated completelly hdd (acer 7720g) i want to to recreate pqservise in order to have d2d recovery(recovery management).i have the dvd recovery of factory settings but the dvds didnt manage to create...
You cant access the recovery partition because you probably has deleted them accidentally. Try to delete all the partitions and use the recovery CDs that come with your computer, they could help.
Good luck.
May 23, 2009 | Acer Aspire 7720-6155 Notebook PC
I've bought a Acer Aspire 5710 and want to reset to factory setting, however i don't have the eRecovery password, is there a way to reset this? i want to restore my laptop to factory default but i forgot...
I've run into that problem before. Luckily for me I had a set of OEM disks handy, but I'm guessing you are a little more limited in options ;) That's ok, it can be worked around.
Do you still have access to the computer itself? If so then you should be able to find the password. It's kept in a file in the recovery partition. More specifically in the "\TOOLS\AIMDRS.DAT" file.
If you are able to access the recovery partition, usually the D:, then you should be able to just open that file in a text editor like notepad. If you can't view the partition then you will need to get a partition editing program just as GParted.
With GParted you burn it to a cd, restart the computer, and boot to the disk. From the interface you will want to find in list of partitions that one with a label resembling "recovery". If not then look for one that is only about 8-12GB in size. Right click on it, select "Flags" and make sure that "hidden" is not selected. after that hit the apply button at the top if it isn't greyed out, then exit the program and reset the computer. You should now have access to the recovery partition.
Hope that helps, if not let me know :)
Apr 15, 2009 | Acer Aspire 5720-4984 Notebook
Cant remove viruses form my laptop
Download, install and run Malware Bytes to do a little cleanup first (if the machine will let you).
You may need to disable your antivirus program to do your recovery also.
Feb 20, 2009 | Toshiba Satellite P105-S6207 Laptop
Cant unlock my Laptop 5315
if it is a windows password then you may need to reinstall windows into a differnet directory on the same partition without formating,
so when you login into this new installation you can access your files from here. if you think you will not be able to do it you can contact premium chat they will guide you step by step and here is one helpfull link to reinstall
http://www.windowsreinstall.com/
however there are numerous utilities on the internet for this,
further Queries are welcome
Feb 20, 2009 | Acer Aspire 5500 5570-2609 Laptop
Access IBM Button does nothing-- need it to start my comp up
The Access IBM button is F11. This lets you boot the recovery partition. It is possible the previous owner removed the recovery partition to regain the hard disk space it uses.
If the recovery partition is gone, you can order the recovery disks from IBM/Lenovo.
Also, make sure you have the BIOS boot sequence in the correct order.. the primary boot device should be the cd-rom for installing the Vista disk. It is usually F8 on startup to load the BIOS.
Make sure the Vista disk is in the drive when you startup the install.
Here's a link to all the Thinkpad R50e drivers you'll need to get it fully working in Vista:
http://www-307.ibm.com/pc/support/site.wss/MIGR-55042.html
If you have just formatted, have you let the Vista disk finish the installation? Just a thought..
Good Luck!
Chris (ziraffa)
Dec 29, 2008 | IBM ThinkPad R50e Notebook
Recovery Hard Disk Access
your recovery dics should not be a dvd, but a cd. look at all of your discs and make sure you are using the right one, if you cant find the right one call sony and ask them which one to use.
Aug 28, 2008 | Sony VAIO VGN-N130G/W Notebook
HP Compaq Business Notebook 2230s Logo
78 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
