When i do a wash it stops half way through and gives the FP code and the clean pump light stays on. I have just moved and it was working fine before the move. Can you help me?
is there any status lights blinking indicating an error code ... open top console and remove tech sheet each indicator light blinking has a numerical value add each indiacator light together per tech shheet and that will give a total number and read error code
first does the water drain in the machine or stays if so it can be your pump that sucks the water out or cloged check, next if its electronical screen it could be screen problem ,or even door lock somtime s pops half way will need to be change ,check step by step,, if helpful plz rate.
Error code E20 relates to the pump/filter blocked.Drain the water either manually through the filter or drain hose.Check that filter is clean and pump can turn by hand.
fp indicates a pump failiure so either clean the pump filter, or if the pump filter is clear then you will need to replace the pump as this is indication of a knackerd pump
Check the pipes actually work first. Is there a hidden drain filter that is partially blocked? Dissasemble the pump and check it works and the blades inside are clean.
The problem is pump is either broke or there maybe something is caught up in the impellor, easy to fix, remove front cover undo spring for door seal unplug electrics, remove both hoses on pump and undo bracket, then check pump, had same problem myself it was an elastic band and coins got it fixed myself saved a fortune hope this helps.
