Question about Lexmark 2381 Plus Matrix Printer
I need a manual for IBM 2831 Plus printer. Need to print bar codes from AS400 on Epson LX-1170ii
4 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: fix page printing
Not Familiar with this printer particularly But if you reduce 'paper' size presumably the printer will reduce the image to fit. Did you try that?
Posted on Aug 27, 2007
Mrvica
  • 167 Answers
SOURCE: Install the epson LX -300 printer
here is link for driver if you need!! Just do what Benimur said!!!
Good luck
Posted on Jan 25, 2008
printech
  • 159 Answers
SOURCE: Epson LX-300+II, the font problem
yes you can change the font tray to print the printer internal setting tray that press and hold any key by tarn the printer off then on after you tarn the printer on release the key
Posted on Sep 06, 2008
Im using a windows 98 SE OS and using Epson LX-300+ii and when i try to print either from MS-DOS or Windows the output is still garbage. need help
I'd check the printer emulation. One of the choices in the printer's internal menus is which kind of printer commands it uses. In this case, the choice is between Epson's own "ESC/P" commands or the IBM 2380's.
Find the instructions under "Using the Control Panel" in the manual, which you can download here.
Another possibility is a bad cable. A USB cable will probably either work fine or not at all, but a parallel or serial cable could have one broken wire inside and cause the printer to put out garbage.
Mar 10, 2011 | Epson LX-300+ II Matrix Printer
My epson lx-300 printer tear off is now off so i want on this fucation . plzz tell me soluation . i want reset my epson lx-300+2
1. In the Finder window, click on Go on the Title Bar and select Utilities.
2. Open the Printer Setup Utility.
3. Click on Printer Setup Utility in the title bar.
4. Select Reset Printing System.
Jan 27, 2011 | Epson LX-300 Matrix Printer
ZEBRA printing issues via AS400
*SAME
*WSCST
ZEBRA
*LIBL
*NONE
'10.27.9.21
Jun 26, 2009 | Zebra 105Se Thermal Printer
Setting custom size (tear off) paper
I have some problem, but now have solved
1. replace your original epson lx-300+II driver by IBM ProPrinter II from windows installation driver.
2. in control panel-->printer and fax-->choose IBM Proprinter II ---> click File-->server properties--> click form tab--> chek create new and fill new paper size and don't forget give a name (ex. 8.5x6)--> save form
3.In printer and faxs right click IBM Proprinter II-->choose properties--> click device setting tab --> change tractor feed, manual paper feed and upper paper tray feed to new name (8.5x6)
4. Good luck
Jun 18, 2009 | Epson LX-300+ II Matrix Printer
P62 DC Pgm not valid
Our IBM 6400 came with a bunch of manuals.
Do you have manuals on yours?
If you need to purchase or download manuals, here is one place you might start to figure out what they cost & where to get what you need.
http://publib.boulder.ibm.com/infocenter/printer/v1r1/index.jsp?topic=/com.ibm.printers.printerinformation/ic5g2mst159.htm
Oct 27, 2008 | IBM 6400 Matrix Printer
Epson lx300+ii with serial port to fujitsu pc
use the com1, and use a baud rate like 9600, with 8 and 1 bit stop. dont. be sure that is in ESC/P or IBM as you requiered. if your software use directly the serial port, be sure that the bios set up is properly. i think that the lx300+ have less buffer than lx300+2
and if you use high speed, could loose info.
Jan 28, 2008 | Epson LX-300+ II Matrix Printer
Draft Printing with EPSON LX-300 with custom page 10x6 inch in windows xp sp2
You have to install the printer through it installer, it that way the advanced features of the printer will be activated and can be manually configured to what you want.
Click the link to get your driver. download here
Don't forget to rate me, "Fixya"... thanks.
Jan 27, 2008 | Epson LX-300 Matrix Printer
Fix page printing
Aug 27, 2007 | Lexmark 2381 Plus Matrix Printer
Printronix p5010 with AS/400 IBM server
I can get the P5010 printing on your AS400... But, there are to many things to check without knowing a little more about your environment.
If you can't ping the PTX P5010 from the AS400 or a PC, then you have a printer configuration problem.
Take the printer offline and hit the Print Config button. and then the enter on OPs Panel. Then post top or first paragraph of the config. so I can look at...
__________________________________________________________
If you can ping the printer from the AS400...
You will need to create a remote out que on AS400... command is crtoutq then hit F4...
if you can't post the printer config here... Fax it 972-233-7306, Attn: P5010, Toby
Dec 12, 2006 | Printronix Line Matrix P5010 Printer
Lexmark 2381 Plus Matrix Printer Logo
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
