Question about ASUS P5VDC-MX Motherboard
I have added 512 MB of RAM but there is no change for in my PC and when i look in basic information of my computer there is not installed...... how to added 512 MB RAM in my computer...?
  • 808 Answers
Reset ur CMOS will fix ur probem
Posted on Aug 19, 2010
2 Suggested Answers
tommya300
  • 724 Answers
SOURCE: i have added 512 MB
Memory needs to match as in a set of familiar number makings between them
How can we check that ram is working properly or not
dear atul.
if the ram is not working then your PC will not boot at all. If it is booting then there is no problems with the ram.
one possiblilty with ram not working properly is that it will show the wrong amount of RAM in the system information, like if you have installed 512 MB of Ram and it is showing 356 or less then there is a problem, but you have to be sure that you installed 512 MB of Ram. this could be due to FSB speed.
To check this goto Control Panel > System > "General Tab"
here you can see all your computer specifications like
1 Which windows are you using
2 whom is it registered to.
3 Processor, Type, Speed, RAM etc.
if it is not showing the correct amount try changing it with a new one.
Thanks
Gagan Gupta
Mar 21, 2011 | Compaq Keyboard
Is it possible to install windows vista in this computer?
No, it needs at least 1GB of RAM and a much better video card.
Jan 16, 2011 | HP Hewlett Packard Compaq D51S Intel...
My everex computer has 448 mb of ram i would like
Actually your computer does have 512 RAM. The 64 MB discrepancy is what the graphics memory uses. 64 + 448 = 512, get it?
If you want it to show full 512 MB, you need to install a separate video card. Refer to your PC's manual and see if it has a separate AGP or PCI-E slot.
If it has then you can choose from the many available in the market.
You can choose between having a low end low cost or a high end one designed for gaming. Just choose what suits you best and remember that a higher power card requires proper cooling and higher wattage PSU (power supply).
Note that no matter how much RAM is installed, some portion of it will be used for graphical operations.
Oct 03, 2010 | Everex eXplora RS2800 PC Desktop
Change ram from 512 to 1 gig bios cannot read added ram
The original 2 sticks of 256 Mb of RAM gives you a total of 512
Mb of RAM. Two 512 Mb of RAM gives you a total of 1 Gb of RAM.
With two sticks of 512 Mb of RAM are you sure you got a total of 192 Mb of RAM, this is a lot less than the original RAM total of 512 Mb?
Should this be 1920 Mb of RAM?
If this 192 Mb is correct then the RAM modules are either not compatible with the laptop or if the RAM modules are not from the same manufacturer then they may not work together.
Most laptops have video cards that use part of the main RAM for video RAM, that is why the available RAM is less than the installed RAM modules. The amount of RAM the video card grabs depends upon the type of video card and in some cases the amount of video RAM can controlled in the BIOS setting.
Nov 07, 2009 | Sony VAIO PCG-K25 Notebook
Cannot install 6940 driver
this is straight from hp
64 MB RAM for basic software installation (256 MB RAM for full software installation), 200 MB available hard disk space for basic software installation (450 MB for full software installation)
unless you get another 256mb memory it would be best for you to do basic installation.
Mark
Apr 21, 2009 | HP Deskjet 6940 InkJet Printer
Memory confusion different readings
It sounds like something isnt working right, what operating system are you using, Vista? I would take out the original 512 and see what it says after, often ram isnt compatible if it is too different in size and speeds. Also, if your motherboard supports dual channel ram and you have the extra 512 chip it wont run in dual channel mode, you would run better with just the 2 chips then the added 512 chip.
Jan 17, 2009 | Mach Speed (S755) Motherboard
Added memory but one memory card (Original) not recognised
OK, according to Crucial.com your RAM does need to be installed in matched pairs.
Here is a link for your computer information:
http://www.crucial.com/store/listparts.aspx?model=Presario%20SR1460AN
If you get another 512MB module and install both pair, it should work well.
Jan 13, 2009 | Compaq Computers & Internet
512 MB memory boards do not work in my Fujitsu Lifebook S2020
frquance is not set and it is not recommand that 2 different friquance ram is not working propaties
Jan 09, 2009 | Fujitsu LifeBook S2020 Notebook
Sdram capacity
its that 512 mb total capacity for your computer memory?? if so read this:
To find the total amount of RAM that can be added , subtract the amount of RAM currently in the computer from the maximum amount of memory the computer can hold. For example, a computer has 256 MB of RAM. If the maximum amount of memory the computer can hold is 512 MB, then 256 MB is the amount of RAM that can be added. this info from the HP website , to find out more , go to http://www.hp.com/support , enter the model number , and look for more information about your computer specs, hope this helps , please rate & thanks AJ
May 24, 2008 | HP Pavilion 8860 (P2941A) PC Desktop
ASUS P5VDC-MX Motherboard Logo
49 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
