Question about LaCie (300770) 250 GB Hard Drive
Drive is connected, blue light shows, but it keeps giving a clicking over noise, and cannot read our mac
  • 11,800 Answers
The click of death - the hard disk inside has suffered a terminal mechanical fault. Sorry, nothing can be done to fix it, it's dead, just junk it and buy a new one.
Posted on Aug 19, 2010
I have a toshiba 500gb external hard drive and suddenly it has been making a clicking noise and not working as far as reading how can i fix this fast?
You can't. When you hear the clicking noise every time it attempts to read, the sound you hear are the read/write heads striking against the edge of the enclosure. The drive has most likely failed. The only thing you can try is to open up the case and remove the drive and directly connect to your desktop computer. Another thing that sometimes works is to wrap the drive in plastic and place in the freezer for an hour, then connect it. IF it starts working, quickly save what data you can off of it because it will fail again when it warms up. I don't think that usually works with head failure, but give it a try.
Apr 04, 2014 | Toshiba Canvio 500 GB USB 20 Portable...
My Mac can't read the Buffalo HD-PNTU3 anymore. Its show the blue light once and then yellow light on, plus somehow it is make some kind of noise inside. How can i fix it?
from what im getting from your description your hard drive is faulty if its still within warranty contact buffalo if not then you will need to replace it either way if it is faulty you have lost all of the data on the drive
Oct 17, 2013 | Buffalo Technology Computers & Internet
DVD writer after loading the disk makes a series of clunking noises as it attempts to read the disk - after about 20-30 seconds it stops and the green light goes out - fails to show up on desk top or in...
May need to clean the laser, or it may be a disc that
drive doesn't read You need specs as to what drive writes to and reads to
Nero info gives this information
Feb 15, 2011 | LaCie (300736U) DVD±RW Burner
My simpletech drive is showing on my iMac but I am unable to write any files to it. It says I can only "read" but it does not alow me to change the access.
These things come formatted for PCs--you have to go into Utilities on your mac (in hard drive click on Applications, Utilities folder, then Disk Utility, then click on the simpletech (that has the gb next to it), click on the drop down to change the format (MS-DOS if you want to read on both PCs and MAC, but MAC-OS for just Macs) re-name it on the drop down below that, then click on erase and then it's re-formatted.
Jan 17, 2010 | SimpleTech Signature Mini 160GB External...
The drive is not recognized by Windows or Mac
You should give Test Disk a try. It's a little complicated at first but if you read the tutorial it's easy.
Here's a link to their wiki page.
Nov 24, 2009 | Memorex Mega Travel Drive HDD 12GB 12 GB...
Drive won't boot
Thry this: turn your computer OFF. Gently unplug and replace the data cable connection to the computer several times. Do the same to the drive end of the cable. Leave one end unplugged. Turn on the computer and when the Mac os is set up and waiting for you, plug the drive in and see if the computer recognizes and reads the drive. The problem is usually corrosion on the contacts that prevent proper contact.
Jun 10, 2009 | BYTECC 1 Bay ME-350U2 USB 2.0 External...
SimpleTech Signature Mini (320GB) unable to find on my laptop
if you hear a constant clicking return the drive it is faulty.
Mar 27, 2009 | SimpleTech Signature Mini 320GB External...
LaCie 500GB external will not show up on mac desktop. Blue light on, whirrs as if working but no icon on desktop (not mounted)
Did you format the drive using Disk Utility? Open "disk utility" from the dock icon or applications/utilities folder. Click the drive name on the left side of the disk utility window. click the "partition" tab in the window, next click the "options" tab and select GUID Partition scheme, or any Mac compatible scheme, read each explanation of the schemes. Name and resize your partitions, click apply. This is how it works running Leopard, not positive if the same applies to Tiger. I hope this helps you
Dec 14, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Blue light clicking noise
This is known as the "click of death" among hard drives. Your external is merely a normal hard drive in an enclosure, and just as the hard drive in your computer can crash, so an the one in the enclosure, especially since it they tend to be transported a lot more. The sound you hear is the head seeking rapidly back and forth across the platters, and it isn't seeing anything.
I read the manual, and it doesn't say anything about a blue light. If the information is vitally important, there are companies that do data recovery that you can find, but it will run you upwards of $300. If it's not that important to you, buy a new hard drive and treat it nicely.
Apr 02, 2008 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
LaCie (300770) 250 GB Hard Drive Logo
80 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
