Question about Neff 24 in. S5443X2 Built-in Dishwasher
Dishwasher S54T59X)GB/21.. Only 6 months old. Door is VERY stiff. Could it be Limescale or does it need lubrication ??
Grohe manual
These are the best quality valves you can buy and if its become stiff its likely to have an abnormal problem. The valve internals may be fine, if the lever and stem on the outside are simply limescaled up. If it does still move stiffly, spay WD 40 on all the rotating seams/levers you can, then move it both ways until it frees up. Then pour on Toilet descaler and leave for about an hour and repeat the WD40 trick to flush out any limescale
Dec 09, 2013 | Home
Tip
Mobility scooter gearbox
Is your scooter 6 months or more old ? please consider having the gearbox re-greased ? why ? well sadly most companies use something called grease however it 's awful... from going stiff to having no lubrication properties at all,,, get your gear re -greased , it will prolong the life of the scooter ...and keep the noise away.....
on Jul 11, 2015 | Miscellaneous
Kitchenaid dishwasher imperial 21
Take the kick panel off under the door and see if the technical spec sheet is there. That lists all the diagnostics that you can run
Nov 20, 2013 | Dishwashers
HI,MY DISHWASHER DOOR HAS BECOME VERY STIFF TO OPEN ALTHOUGH IT CLOSES WITH NO PROBLEM. when I looked underneath the door grip handle, there's a little white thin skittle shaped pin .,......when I push...
Hello
Open the dishwasher door and inspect the latch mechanism for obstructions or immovability.
Clean out the door latch with a stiff bristled brush, and apply lubricant. Open and close the door to see if it now latches shut.
Check the door latch and strike plate alignment. Close the dishwasher door slowly and observe the door latch meeting the strike plate. Determine whether the latch is striking the plate correctly. If not, use pliers to gently bend the latch to meet the strike plate.
Gently hammer the latch to better align with the strike plate. Hammer carefully so as not to break the latch or dislodge it from its attached point. Open and close the door to see if it now latches.
Realign the strike plate. Loosen the strike plate with a screwdriver and slightly move its positioning to better align with the door latch. Tighten the strike plate and open and close the door to see the results.
Sep 07, 2011 | Dishwashers
Dishwasher only runs for 21 minute cycle
I bought and replaced the control board in the door. $145 CAD it took 5 min saved myself $300
May 07, 2009 | Dishwashers
Drips water from bottom left
clean all the door seals there may be some food debris under the door seal at the bottom. also clean off any limescale on the seals also as these can seep water.
Mar 18, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
The hinge to the door is very stiff with limescale
clean off the lime scale with a lime away product, be very careful Limeaway is an acid. READ the products directions.
Jun 05, 2008 | Siemens Washing Machines
Dishwasher soap dispenser won't open during cycle
I had the same problem with my GE Adora. The dishes were getting cloudy and the soap dispenser would not open. Turns out the hard water deposits were causing the soap dispenser to stick shut. I purchased and used Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
Oct 26, 2007 | Dishwashers
My tablet won't dissolve.
Sounds to me like the dishwasher isn't filling up with cold water. I had a similar problem a few months ago, caused by limescale blocking the inlet and drain valves. Might be worth trying some kettle limescale cleaner solution and putting it inside the machine - and leaving it overnight then trying the machine out with no dishes etc in it.
May 16, 2007 | Whirlpool 24 in. ADP5962 Free-standing...
Neff 24 in. S5443X2 Built-in Dishwasher Logo
Top Neff Dishwashers Experts
Samohthda
Level 1 Expert
shaun taylor
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
