Question about Whirlpool Washing Machines
Whirlpool white magic top loading machine water over flow with out control in rinse mode
Water keeps reducing to below half while machine is in the wash cycle. Kindly explain the reason and what is the solution for this.
Posted on May 18, 2013
  • 92 Answers
It have been soaked too much please rate my answer thank you
Posted on Aug 19, 2010
Grinder works fine. Water pump sounds normal but no water flow when in rinse mode, brewing coffee or in hot water dispense mode. Something is clogged???
Run a simple cleaner through your system without coffee. Pour in white vinegar 4:1 ration. Brew this maybe up to 3 times. Should clean your clog.
Feb 02, 2016 | Saeco Magic Comfort Plus Espresso Machine
I have a top load Whirpool Washer. It either never fills with water but tells me it is going thru the cycles or it gets water but doesn't wash and rinse or just doesnt spin out. The control panel always...
Check the water supply by disconnecting hoses @ the machine & use a bucket to check the flow. If there is a good flow of water,then check the screens inside of the inlet valves for debri.
Feb 13, 2018 | Whirlpool Duet 4.0 cu. ft. Washer
Washer won't fill
check to make sure your clothes are not covering the middle of the drum it has a sensor there for the water to come in
Feb 02, 2013 | Whirlpool WTW57ESVW 4.0 Cu. Ft. Top Load...
The water level selector of my whirlpool white magic-splash washing machine is causing problem..it does not stop the water at the desired level..the water keeps on flowing into the tub and then overflows...
PRESSURE SWITCH
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to "make the switch" stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Water inlet valve
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Mar 09, 2011 | Whirlpool Washing Machines
Washing machine displays an LF error code. Started last week during whitest whites cycle in rinse. I cancelled and just did rinse to finish my load. All other cycles worked and yesterday all started...
LF = Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Is water supply connected and turned on?
Are hose screens plugged?
Is water entering the tub? If so check pressure hose connection to machine/motor control.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Very slow cold water flow at the beginning of wash and rinse cycl
There might be some debris in the cold water valve screen. Remove cold water hose and check the valve screen, clean as necessary. BTW some hoses have screen inserts too, so check the hose as well.
Good luck,
Vladimir
First Choice Appliance
Jul 02, 2010 | Whirlpool LSR5132PQ Top Load Washer
The water fills very slowly on rinse
You probably have a cold inlet valve with restricted flow, either because the filter on the inlet valve is clogged or because the cold valve is failing......If you wash on "warm" you have both hot and cold water mixed. On rinse there is probably only cold water used....Check water flow for HOT and COLD settings and you'll probably see the difference...Good luck...Nomess
May 23, 2010 | Whirlpool LSR5132PQ Top Load Washer
At the end of the rinse cycle, water and suds will
Does water empty on spin? if not to check for blockage remove waste pipe from drain, place as low as possible into bowl, if water flows then fault likely to be on pump, if no water flows then pipes blocked and need to be removed to clear them. Good luck
Feb 12, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
WHirlpool Waser model LSR8133HQ0 - tries to fill for rinse cycle
hellow my name is joyce and It sounds like you have a issue with your cut off valve that controls the water flow to your machine in between cycles, this is controled by your timer switch you may want to call technichian to repair. sounds like the only problem you have with the timer is on the rinse cycle not the wash cycle, but it defently needs to be fixed. if I can help you find a repair person please let me know.
thanks you and let me know if I can further assist you.
joyce
Feb 06, 2009 | Whirlpool LSR8433K Top Load Washer
Washing Machines Logo
75 people viewed this question
Dan Webster
Dan Webster
Sal De
