Question about Nintendo The Legend of Zelda: The Twilight Princess for GameCube
How to fish the fish on fishing hole? - Nintendo The Legend of Zelda: The Twilight Princess for GameCube
    Scholar:
  • 75 Answers
To fish on the Fishing Hole just go into the small building and pay to fish, the guide will explain how to do everything. You can fish without paying, but you won't catch fish near as big or diverse as the ones while on the boat. Just get some bait off the side of the small building (the beehive - knock it down and take the larva) and fish with your own baited fishing rod. When you cast the rod, wait until the hook is tugged down by a fish, then pull it up. Btw, you can obtain a glass bottle this way, there's one in a closed off area of the pond beside the small bridge.
Posted on Jan 23, 2011
What do fish eat
The smaller fish eat algae, weed, small crustaceans, krill, plankton, each has its specialty in the food chain to minimise competition.
Medium and large fish eat other smaller fish.
The largest fish eat seals, penguins, fish, and in a few cases, krill and plankton. Again each species has a specialty.
Whales and orcas aren't fish, but have a similar diet to the large fish, depending on the specialty they have.
Dec 07, 2016 | Computers & Internet
Tip
Fishing electrical wire down a wall
I do a few measurements to determine where to drill holes,
in the attic I measure from the wall and locate top plate of wall to be fished
the bottom of the wall at the trim is where I need the wire to exit
so I attach a piece of chain to my wire
drop the wire straight down wall
use a retrieving magnet to fish wire out...
I use to try and hook a line and try and look in the hole for the wire?
although with the chain and magnet technique you can do this with your eyes closed, well almost, it just makes it easier!
after the wire is fished I can install....
hope this helps anyone wondering how this is done?
as always Be Safe, and if you are unfamiliar with the potential hazards of electricity, Please do Not attempt this.... Frederick Electrick Google
on Mar 01, 2015 | Electric Electrical Supplies
Which are the best places to do fishing?And which are best fishing rods we shuold have ?
Fish like edges or places where the bottof structure of the body of water you're fishing changes.
For instance a shallow flat with a deeper hole or ditch running through it. Or a drop off with a point that extends off of it.
if spots like the contain cover then they become even more attractive to fish. Cover is weeds, wood, rock or any other type of material that either naturally occurs of is artificially created. For instance a concrete break wall or a jetty that has bRosen rock along it makes great cover for fish. Fish also use edges, these can occur in a number of different ways. For instance where sandyou bottom turns to gravel or the edge of a weed line or where warme and cooler water meet etc. If you can locate an edge on a structural change and that edge meets cover or is the cover itself you've found potentially awesome fishing spot. The fish might not be there every day but they will use it at some point in time.
Hope this helps, good luck.
Nov 06, 2014 | Fishing
Do fish automatically sleep when the lights are off?
Like any other creature in the world fish need their sleep. When you turn the lights off the fish will start looking for a shelter for them and get some sleep. You can see that if you suddenly point a flashlight toward them the will start swimming in a dazed matter and look for a new hole to hide in.
Aug 02, 2012 | Fish
Can I feed my fish cat food?
I do not recommend feeding your fish anything other thanfish food. Fish food is specificallydesigned to be nutritious and digestible to fish. You cannot say the same about any otheranimals' food. If you are out of fishfood, you can feed fish soggy bread crumbs for up to 24 hours before theyrequire something more substantial.b>
May 13, 2012 | Fish
Rear window replacement for a 1982 Buick Riviera
We will assume that you have the glass for replacement. Fish a very small screwdriver or a stiff wire in the rubber gasket down into the bottom of the glass and back up inside. Use the hole to fish a strong piece of fishing line through the hole created by the wire. Now push or pull the old glass out while opening the gasket (spreading it apart) with the fish line. Once out, grease the gasket with vaseline, wheel bearing grease or silicone grease and insert the new glass, spreading the gasket as before. This will work, it may take some help on the other side of the glass. Try not to screw up the gasket, if you cut it, replace it while the glass is out. RTV will ensure a watertight seal.
Sep 11, 2009 | 1983 Buick Riviera
Need to change fuel line
I solved this problem by feeding a heavy weight fishing line through the hole in the tank. I then cut the fuel line at an angle, to give a taper to the end. I tied an angler's knot around the tapered end of the fuel line, and pulled it very tight to compress the line. Pull the fishing line back through the inside of the gas tank, taking the fuel line with it. Make sure you use heavy enough fishing line that won't break when you begin pulling. Reduced this to about a 30 second job this way.
Apr 07, 2009 | Poulan Garden
Reekfish
No, if you beat the fishing hole game you'll get the frog lure, good but not for the job, you must go through the hole in Zora´s Domain and talk to the "monster" there, she will give you a sketch, you must go to Kakariko village´s graveyard and show the Zora prince the sketch, he will give you an earring which will automatically add to your fishing rod, then go to Zora's Domain and fish the reekfish as if it were any other fish
Feb 23, 2009 | Nintendo The Legend of Zelda®: Twilight...
Nintendo The Legend of Zelda: The Twilight Princess for GameCube Logo
274 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
