Question about Nokia 6303 Cell Phone
When I want to install applications on my Nokia 6303 classic, I see the message: "File is too large to be installed" while I have my sd memory inserted with enough space! Can you help me in this?
  • 46 Answers
In which type of file u want to installed in mobile.
Posted on Aug 19, 2010
  • monsoon Mar 19, 2012
    I too have the same problem..Im trying to install .jar file type
Files large
mobiles use there internal memory first, you will need to send directly to your sd card or send your d/l files already on phone to your sd to make space
Dec 26, 2013 | Nokia Cell Phones
Sir i have nokia 6303 classic mob which phone memory crrupted by virus so pl tell me process for formating phone memory
This is the best and 100% guarantee solution.
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 6303 file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment. thanks for visiting fixya. Good luck.
Aug 18, 2011 | Nokia 6303 Cell Phone
DUE TO SOFTWARE PROBLEM MY NOKIA 6303I CLASSIC IS SWITH OFF HOW TO INSTALL NEW SOFTWARE
Here is the best solution.Best of the best.
First download and install Pheonix. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 5130 flash file or Nokia flash file and install it to C / programme files/pheonix..after finished this installation open pheonix clip_image002.gifInside the interface at the> left top <there you see "File" click there and choose "open file" and then select the approprait Product type i.e"which is written in the back banel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there when you click there you'll see three icon just select the "Firmware Update" again you'll see another interface.Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Botton and choose the code which is written in the back side of your phone.e.g CODE:0000000.if the same code does not found just take one.After this you can see "Dead phone USB flashing" click that box.Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead,unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" after this, a message will prompt you "press power botton" press it and wait untill the phone will Restart automaticlly in normal mode 10-15 minutes.If you cannot understand just make a Reply thanks for visiting fixya.Good luck.If you could not do please contact me.
Jul 22, 2011 | Nokia 6303 Cell Phone
How to reject incoming calls from a number in Nokia 6303 classic
You can visit getjar.com website;
mention your cell model;
select application
download the .jar file on your PC
attach your mobile to PC and copy the file on a selected folder
remove cell from your PC
check mobile folder and click on the file;
try and install it
run and let me know if it works!!
Take your time and give me ratings for the suggestion! Richee
Jun 10, 2011 | Nokia 6303 Cell Phone
I cant save files direct to sd memory all data is going to phone memory direct..how to activate sd memory as my default memory in E5 nokia mobile?
1. To save files received from bluetooth on sd card: Open messaging. Go to settings. Scroll to the end and select other settings. Change the default memory to Memory card. It will ask to copy or move the messages and file from phone memory to sd card. Select move to memory card.
Now all files will go to sd memory card.
2. To save all applications to sd card, open ovi store, go to settings, change installation preference from phone memory to sd card
Jun 07, 2011 | Nokia E5 Cell Phone
Restriction code for nokia 6303classic
Try restriction codes here http://www.mobileunlocksolutions.com/nokia-6303-classic/rs1wp9/ 1 - Switch on your Nokia 6303 Classic without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6303 Classic.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6303 Classic would then display the message "SIM Restriction Off" and will be unlocked!
Aug 12, 2010 | Nokia 6303 Cell Phone
How unlock the kigston sd memory card 2 GB in nokia 6303 classic set.
The steps to unlock a password protected memory card of your mobile phone, is described below. Please follow the steps:
1. To unlock your mobile memory card, you need a file explorer. You may use FExplorer. To download FExplorer, http://fexplorer.en.softonic.com/symbian/download#pathbar
2. After finished downloading, install it to your mobile phone.
3. Insert the mobile memory card into your mobile phone. Remember, don't access the memory card through phone at this moment.
4. Run FExplorer and open the following location C:\system.
5. From the location C:\System, you will see a file named as mmcstore. Rename this file as mmcstore.txt.
6. Copy the file mmcstore.txt. and paste it to your computer. Now, open that file in notepad.
7. When you finished the above steps, you will find the password of that file
Rate me if this is helpful. Good Luck :)
May 21, 2010 | Nokia Cell Phones
How to remove password from micro SD card in nokia 5300
Hi there, I have a micro sd card from Nokia 5300 phone.But when i use the same card in Nokia 3120 Classic, the memory card has been locked but i did not set any password for the memory card...Can this issue be solved in nokia 3120 classic phone.Can the password be unlocked in nokia 3120 classic.........Please advise.....
max2010
Mar 10, 2010 | Nokia 5300 Grey Cellular Phone
Nokia 6303 reformatting method?
Hi! Go to Menu - Settings - Restore fact. settings- Restore all. (if you`re prompted for a code, try 12345 or 00000).
Dec 03, 2009 | Nokia 6303 Cell Phone
Nokia 6303 Cell Phone Logo
74 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
