Question about Dell Latitude D510 Notebook
I AM TRYING TO RECORD IN STEREO IN TO THE **** INPUT. IS THIS IN PUT A STEREO IN PUT?
  • Dell Master
  • 32,281 Answers
The microphone input is a mono input.
To record in stero you need a USB stereo input adapter.
Please click on this link to this WEB site to purchase :-
http://www.usbgear.com/computer_cable_details.cfm?sku=USBG-X4S&cats=121&catid=121
Posted on Aug 19, 2010
Testimonial: "the information was very helpful"
2 Suggested Answers
Basilio00920
  • 155 Answers
SOURCE: Is there a stereo input for the Dell Inspiron 1100 to record?
Yes, the input is stereo BUT you need to configure Audacity to do the stereo capture. Go to File > Preferences. Once in the preferences dialog, go to the third Drop-down menu, and change from MONO to 2-channel stereo. That is.
Posted on Apr 27, 2009
How can I transfer recordings from S725 to my pc. I have windows XP
You will need to get a 2.5mm mono to 3.5mm stereo adaptor from somebody like Maplin.
The 2.5mm end of this needs to plug into your earphone jack (mono) on your S725.
Get a ready made cable with a 3.5mm stereo plug on both ends.
Put one of these plugs into your 2.5mm mono to 3.5mm stereo adaptor.
Put the other plug of this cable into the AUX input of your PC.
If you do not see an AUX 3.5mm input, look in or around the area where you would normally
plug your headset. Try checking the manual that came with your PC. Some PCs do not have "AUX" marked on the 3.5mm socket.
Be careful not to have the volume level of the S725 too high as you are testing your setup.
You might damage the Mic input of your PC if you blast too high a level at it.
Next you will need some software like Audacity (Free) to record your tapes.
Have fun but be careful if you are not sure about the connections.
Hope this helps.
Sep 12, 2011 | Olympus Pearlcorder S725 Handheld Cassette...
When I record vocals with stereo setting it always records left more in favour of the right. Is there a way to fix this?
Your microphone is a mono input (one), therefore recording in stereo is not practical. Stereo inputs are left and right (two inputs). Whatever your recording setup or audio workstation, the track you record to from your microphone needs to mono.
Jun 29, 2011 | Samson C03U Professional Microphone
Can I record stereo via the mic input on my Dell Inspiron 2200 please? Is there any way of getting a high quality stereo recording from a line level input signal without investing in an external sound...
Try using Musicmatch Jukebox,it`s a great program for this and doesnt cost much..has to be pro version to record.You can choose both line and mic stereo recording as well as burn audio cd`s...lots of great features...good luck:)
Apr 12, 2010 | Dell Inspiron 2200 Notebook
Apr 27, 2009 | Dell Inspiron 1100 Notebook
Samson G Track USB Mic
To get sound in both channels in Garageband for a podcast using the G-Track Microphone:    select a voice track to record into    make sure the Track Info window is open (blue i button in lower right region of screen)    at the bottom of the Track Info window you will find Input Source:    Change the default setting of Stereo to Mono 1 (USB Audio CODEC)
This assumes you have gone to Garageband preferences and changed the Audio/Midi settings for audio input to USB Audio CODEC which appears when you plug in the G-Track Mike
Apr 08, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Dp02 recording music(from stero)
Sounds like you are using the DP-02's 'stereo mix' inputs here. If so, the signal input from those is only routed to the line out and headphone jacks and cannot be recorded using the DP-02.
To record from a stereo you need to take the left and right aux outs (or some other line out - like the tape outs) from the stereo and put them into the main A and B mic/line inputs on far right of the DP-02's back panel. Then assign them to two respective tracks and you can record the stereo output to the DP-02. Just make sure you use a line level output from the stereo as the amplified speaker output can overpower and damage the inputs on the DP-02. You might need a couple of rca to 1/4 inch adapters to accomplish this.
Hope this helps.
bd.
Jan 14, 2009 | Tascam DP01 All-In-One Recording Package...
AKG Perception Microphone ony recording in mono but want stereo.
I have similar problems with inputing stereo sound. How do you know your mic port on the PC is set for stereo? What kind of a cable are you using? If it is an XLR, the connection is pure mono. Maybe you need a TRS cable, which looks like a 1/4 inch jack but is really stereo. Maybe you need a stereo mini. Usually a cable mismatch is the problem. Is your phantom power supply passing stereo? All the ones I have seen are mono. You may need two. Is your sound capture set for stereo? Are the input level controls set correctly for equal volume on left or right channel? I would try the mic with a regular amplifier to insure both channels are working. Then trace the signal from mic to power supply and power supply to computer.
Dec 03, 2008 | AKG Perception 100 Microphone
2 tracks
press F4 to open device panel. there you must be able to select inputs and out puts fromyour alesis interface.
be in stereo or mono(check your alesis specifications to know how many mono and stereo inputs it has.
then when you create a new track on the right side of the sequencer window. you must see a input and uut put routing tab
so if you whant to record voice in one track select the inputs where your mic is plug
create a new track and select the other input
so for shure it will say alesis INPUT 1
alesis INPUT 2
alesis INPUT 3
and so on depending on how many inputs your devices haves.
you say it haves 2. but
are they 2 only in stereo
or two in mono
or one mono+one moni+one mono+mono
for a total of 4 inputs in mono mode and 2 in stereo mode.
i dont know witch device you have so i cant tell.
if you have any questions let me know
Jun 29, 2008 | Steinberg Cubase SX3 (502010600) for PC,...
Cant record in stereo
need more info.what are you trying to input what software do you use to repair.you could try opening volume control,properties.click recording put tick in box for stereomix.
to get to volume control ....click start.all programs ,accessories,entertainment.
Mar 03, 2008 | Dell Inspiron 1000 Notebook
Audio Input Problems
buy a creative sound pcmcia card with stereo inputs...it runs aboout 50 bux at compusa...another solution would be usb audio input, they are also available at compusa,tigefr direct...i hope this helps...
Jul 29, 2007 | HP Compaq nc6220 Notebook
Dell Latitude D510 Notebook Logo
103 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
