Question about GE WJSR4160DWW Top Load Washer
Coupling raises an inch after removing bolt. but then gets stuck
  • 92 Answers
There must be a coth or something which stucked in please rate my answer thank you : )
Posted on Aug 19, 2010
How to change a lightbulb in a model nn-656ba panasonic microwave oven
I may be wrong on this model, but most microwaves need the top/side panels removed to get to the. Light. Afer removing the screws raise the back a couple of inches then slide cover towards the rear in order to slide the top potion out of its retaining clips. They do sometimes get stuck with food etc.
Oct 14, 2014 | Panasonic NN-P794SF Microwave Oven
How to remove fuel tank on 48 inch husqvarna riding mower
pull the rear seat/fender assy... the floor boards ( where your feet sit ) have a couple of bolts, then the seat springs have a couple of bolts... a couple of handles might have to be removed...
Aug 26, 2014 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
How do i fix a poower window that will only raise a couple inches then stops ?
A common problem. Replace the window regulator. Typically the braided wire cable starts to fry and jams the track. Attempt to line up the window bolts with the access holes for removal. If window will not move to align bolts with holes, it's knuckle scrape time in attempting to turn the bolt from inside the door panel.
Jun 11, 2014 | Hyundai 2006 Sonata Window Regulator, Rear...
Wife's diability require raising passenger seat 2 inches
Remove one seat bolt. Get a replacement bolt 2 inches longer at any hardware store. Spacers can be made with a stack of nuts slightly larger that the threads of the bolt.
Jan 28, 2014 | Hyundai 2012 Santa Fe GLS FWD
Intructions on how to replace a gearbox on a 1987 GMC suburban
set the front wheels in straight ahead position by driving vechicle a short distance on a flat surface. raise and support the vechicle safely on jack stands.place a drain pan below the steering gear. disconnect negative battery cable.disconnect fluid lines.cap the openings.mark the relationship of the pitman arm to the pitman shaft.remove pitman shaft nut and then remove the pitman arm from the pitman shaft using puller J - 6632. remove the steering gear to frame bolts and remove the gear assembly. TO INSTALL align the flat of the flexible coupling with the flat on the shaft push the coupling onto the shaft until the wormshaft bottoms against the end of the shaft.install the pinch bolt. make sure the bolt passes through the shaft undercut. tighten the pinch bolt to 75 ft lbs. place the steering gear into position guiding the coupling bolts into the proper holes in the shaft flange. install the steering gear to frame bolts and torque to 66 ft lbs.install the coupling flange nuts and washers. make sure the coupling alignment pins are centered in the flange slots. tighten the nuts to 20 ft lbs. maintain a coupling to flang dimension of 0.250 - 0.375 inches. install the pitman arm.install the hoses. you are done except bleeding power steering system. BLEEDING POWER STEERING. fill the the power steering pump reservoir to the proper level and let the fluid remain undisturbed for at least 2 minutes. start the engine and run it for only about 2 seconds.add fluid as necessary. keep doing this procedure until fluid level stop dropping. then raise the front of vechicle so the front wheels are off the ground.set the parking brake and block both rear wheels front and rear. manual transmission should be in neutral. automatic transmission should be in park. start the engine and run it at approximately 1500 rpm. turn the wheels off the ground to the right and left lightly, contacting the stops.add fluid as necessary. lower the vechicle and turn the wheels right and left on the ground.check the level and refill as necessary. if the fluid is extremely foamy, let the vechicle stand for a few minutes.with the engine off and repeat the procedure. if fluid looks foamy. once all done.dont drive vechicle on highway until normal steering is obtain.
Apr 13, 2011 | 1987 GMC Suburban
How to replace the oil pan gasket?
Drain oil, remove oil pan bolts, drop pan, scrape remnants of old gasket off, attach new gasket to pain using silicone gasket sealer (Permatex) and reinstall & refill w/oil. Some applications require loosening motor mounts and raising engine a couple of inches to clear cross members.
Apr 04, 2011 | 2000 Ford F350 Super Duty Super Cab
How do you replace the steering rack on my 2001 Ford Windstar??
YOU HAVE TO SAFELY RAISE SUPPORT VECHICLE ON JACK STANDS.MAKE SURE YOU HAVE VECHICLE PARKED ON LEVEL SOLID GROUND.ONCE VECHICLE RAISED.REMOVE FRONT WHEELS.REMOVE TIE RODS END COTTER PINS AND CASTLE NUTS.REMOVE TIE ROD ENDS FROM THE KNUCKLES.REMOVE FRONT STABILIZER BAR.POSITION THE DASH OPENING WEATHER SEAL FOR THE STEERING COLUMN OUT OF THE WAY.REMOVE OR DISCONNECT THE FOLLOWING.REMOVE PINCH BOLT RETAINING THE STEERING COLUMN INTERMEDIATE SHAFT COUPLING.REMOVE STEERING GEAR RETAINING NUTS BOLTS.REMOVE REAR SUBFRAME BOLTS.USE WIRE TO SUPPORT EXHAUST COMPONENTS UNLESS YOU ARE REMOVING THEM COMPLETELY.SUPPORT THE EXHAUST SYSTEM FLEX TUBE AND REMOVE THE FLEX TUBE TO DUAL CONVERTER Y PIPE ATTACHMENT.LOWER THE VECHICLE SLIGHTLY UNTIL THE REAR SUBFRAME SEPARATES FROM THE BODY APPROXIMATELY 4 INCHES.REMOVE THE HEAT SHIELD BAND AND FOLD THE HEAT SHIELD DOWN.ROTATE THE RACK AND PINION ASSEMBLY TO CLEAR THE BOLTS FROM THE FRONT SUBFRAME AND PULL TOWARD THE DRIVERS SIDE OF THE VECHICLE.PLACE A DRAIN PAN UNDER THE VECHICLE AND DISCONNECT THE POWER STEERING LINES.REMOVE THE RACK AND PINION ASSEMBLY THROUGH THE DRIVERS SIDE OF THE VECHICLE***** TO INSTALL ****** INSTALL NEW TEFLON O - RINGS ON THE POWER STEERING LINE FITTINGS. PLACE THE RACK AND PINION RETAINING BOLTS IN THE GEAR HOUSING.INSTALL RACK AND PINION ASSEMBLY THROUGH THE DRIVERS SIDE OF THE VECHICLE.INSTALL POWER STEERING LINES ON THE RACK AND PINION ASSEMBLY. INSTALL RACK AND PINION ASSEMBLY ON THE SUBFRAME.INSTALL ******** HEAT SHIELD.INSTALL TIE ROD ENDS TO THE KNUCKLES TIGHTEN THE CASTLE NUTS AND INSTALL THE COTTER PINS.INSTALL STABILIZER BAR.INSTALL RACK AND PINION ASSEMBLY RETAINING BOLTS.TORQUE THEM TO 85 - 99 FT LBS. RAISE VECHICLE UNTIL SUBFRAME CONTACTS THE BODY.INSTALL REAR SUBFRAME RETAINING BOLTS TORQUE THEM TO 83 - 112 FT LBS.INSTALL EXHAUST SYSTEM FLEX TUBE TO DUAL CONVERTER Y PIPE.INSTALL FRONT WHEELS.INSTALL A NEW PINCH BOLT IN THE STEERING COLUMN INTERMEDIATE SHAFT COUPLING ON THE RACK INPUT SHAFT TORQUE PINCH BOLT TO 25 - 33 FT LBS.POSITION THE STEERING COLUMN OPENING WEATHER SEAL OVER THE STEERING GEAR HOUSING.LOWER THE VECHICLE FILL THE POWER STEERING FLUID RESERVOIR. START THE VECHICLE AND CHECK FOR LEAKS. CHECK FOR PROPER WHEEL ALIGNMENT AND STEERING WHEEL POSITION.BLEED POWER STEERING SYSTEM.
Oct 14, 2010 | 2001 Ford Windstar
Should i raise the vehicle slightly to remove the starter motor or struggle underneath(im not fat)its a transit connect not focus.how many bolts and where are they.what size are they.how long to do it.
Yes, raise the car, put some jack stands under there. Get a piece of cardboard to lay on. 2 bolts and 1 or 2 wires. The bolts are 14 mm and about 2 1/2 inches long. Not a hard job, Some starters have the bolts going up and some in the end. Pull the hot lead off the battery before starting.
Feb 24, 2010 | Ford Focus Cars & Trucks
How do you replace the alternator on a 2000ford contour
Removal & Installation
2.0L Engine
  1. Disconnect the negative battery cable.
  2. Remove air intake resonators.
  3. Remove the air cleaner-to-throttle body tube and the mass airflow sensor.
  4. Unplug the connectors and remove the cables from the alternator.
  5. Raise and support the vehicle.
  6. Release the drive belt tensioner and remove the drive belt from around the alternator.
    NOTE It is not necessary to remove the drive belt from the engine.
  7. Remove the alternator mounting bracket bolts and remove the mounting bracket.
  8. Lower the vehicle.
  9. Remove the power steering pressure hose bracket retaining nut and bolt and remove the bracket with the hose from the engine lifting eye.
  10. Remove the alternator mounting bolts and remove the alternator from the vehicle.
  11. To install:
    1. Place the alternator into position and install the mounting bolts finger tight.
    2. Install the power steering hose bracket and tighten the retaining nut and bolt to 70-106 inch lbs. (8-12 Nm).
    3. Raise and support the vehicle.
    4. Install the alternator mounting bracket and retaining bolts and tighten to 15-22 ft. lbs. (20-30 Nm).
    5. Release the drive belt tensioner and install the drive belt pulley over the alternator pulley.
    6. Lower the vehicle.
    7. Tighten the alternator mounting bolts to 15-22 ft. lbs. (20-30 Nm).
    8. Install the alternator connectors and the cables. Tighten the terminal nut to 80-97 inch lbs. (9-11 Nm).
    9. Install the air cleaner-to-throttle body tube, mass airflow sensor, and the air intake resonators.
    10. Connect the negative battery cable. To install:
Sep 28, 2009 | 2000 Ford Contour
Engine replacement 1996 Chevy Blazer
I just replaced my engine in my 1996 blazer myself. Body need not come off, but what an ordeal if its a 4 X 4.
Sep 29, 2008 | 1996 Chevrolet Blazer
GE WJSR4160DWW Top Load Washer Logo
24 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
