Question about E-Machines Computers & Internet
I need to upgrade the ram memory in my pc so how do i put the new one it
  • 487 Answers
Hi, this is quite straight forward. Either side of your memory you a little leaver, push these downward toward the motherboard. Be carefull when handling memory sticks, only hold on the edges, as they are sensitive to static. Check to see what memory type you have and once you have purchased your new memory, repeat the proceedure. You have to push quite hard to get the memory to sit in slot properly, but you will see the two small leavers come back up into the lock position. Ensure you have the memory round the right way when fitting.
Posted on Aug 19, 2010
Get black screen after upgrade Acer 3680
might be that the ram you got was the wrong ram for that laptop.not all ram work in all laptops.
May 23, 2014 | Acer Aspire 3680 Laptop
Sd card
The SD card is not counted as RAM Memory.
RAM memory is included inside the tablet and is not upgradable.
The ram in your tablet is RAM DDR3 512MB.
Tablet PC Android 4 2 Tablet PC 9 M9100
Apr 16, 2014 | Kocaso NEW MID M9000 9.0 " Android 4.0...
Hello! I have a D101GGC motherboard and I want to upgrade my memory, I mean now i have two RAMs at 250MB and i bought one DDR 1GB PC3200 400MHZ CL3 KINGMAX MPXD4. The problem is that the PC doesn't...
Please check the speed in MHZ of old RAM and New 1GB RAM.
Some times if speed wont match this problem occur.
Remove old RAMs and add only 1GB RAM and start the system.
I hope it will help you.
Thanks for using FixYa.
May 31, 2011 | Intel D101GGC Motherboard
Wont to upgrade graphic card my p.c has 2gig max ram in it wonts should i upgrade to to preform its best cheers mike
Depends on what kind of hardware you have
-Memory- 2 gb ram is "ok" if you use windows XP but if you have Vista or Windows 7 you should have a minimum of 4gb ram.
-Processor- if you have a Dual core processor you are ok, if you have a p4 or p3 you dont want to waste money on a new graphics card because it will not help you get better games, your processor and memory will slow you down instead.
So my advice is, if you have a OK computer, go ahead with buying a new graphics card if you computer is old and slow, DONT buy a new card! put your money on +2gb ram instead (cheap,and gives you more benefits) or maybe buy an "upgrade package" with new motherboard-memory-processor.
May 05, 2011 | Computers & Internet
Can i put ram from packard bell easynote into an acer aspire 5315.thanks
RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support) RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support)Max RAM: Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support) This is the kind of memory you need, no matters the branch
Dec 21, 2010 | Acer Aspire 5315 Notebook
Upgrades and advice!!!!!
2GB is the maximum amount of ram you can install in your Dimension 2400. Depending on how much ram you have in it now,.. you could get a substantial speed difference by upgrading. You can upgrade the video card if you want. If you want to upgrade to 2 GB and upgrade to a decent vid card,.. you are looking at about $180 for parts. you will need to determine if that is something you want to put into the 2400 or buy a new computer with substantial speed and performance difference for about $500 from Dell. If you have any further questions, please post a comment here and I will answer them for you.
Feb 08, 2010 | Dell Dimension 2400 PC Desktop
Upgrade on Memory Card
When you said memory cards i assume you mean the RAM. You can just take out the ram and put in new ones. Nothing else.
Nov 01, 2009 | Sony VAIO PCG-K27 Notebook
I need to replace the 512 Ram Memory card with 2 new 1 gb cards
Yes that's correct simply turn off the power OFF from the computer and to make sure unplug it from the power outlet, then remove the existing 512 RAM and put the new RAM and then turn the power back ON and that's it.....
Apr 03, 2009 | Dell Dimension 2400 PC Desktop
Upgrade ram on HP LAPTOP COMPAQ NX9010
Ok, so you just got more Hard disk space, or a new bigger Hard disk. Of course you need t upgrade the Ram memory. This computer supports Ram memory up to 1 Gb with a max frequency of 266Mhz. You probably have 256Mb or 512Mb of Ram Memory. You can go to any computer store and get it upgraded. It shouldn't be expensive. But don't forget :
Use this tyoe of RAM: DDR SDRAM (266 MHz), Upgradeable to 1GB
By the way, even after the upgrade, I advise you to run a Defrag of your Hard Disk and clean all your temp files.
There is a free and easy software to clean all temp and internet temp files: Ccleaner.
Apr 01, 2009 | HP Compaq nx9010
DELL OPTIPLES GX280 (E219542) MOBO, MID TOWER
Several long beeps means there is a problem with the memory. First of all make sure the memory is seated in the slot perfectly. There should be no movement whatsoever when you gently try to rock it side to side. If it still persists the bad news is the memory is most likely shorted out or defective. They are VERY sensitive to static electricity. I would go ahead and put the old memory back in for now and send the new defective memory back. Most vendors will issue you a replacement free of charge if you let them know it's not working.
Hope this helps!
Mar 05, 2009 | Dell Optiplex GX280 (99301) Motherboard
Computers & Internet Logo
130 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
