Question about Canon imageRUNNER 400S Copier
How to configure ip address in canon ir 400 - Canon imageRUNNER 400S Copier
If you want to configure IP adrress you have to righty clic on the LAN connection and select properties and then select internet protocol ( TCP\IP). select its properties and enter manual IP address 192.168.1.2 and sub mask net 255.255.255.0 and press OK and close dialogue box.
After that open run and enter ping 192.168.1.2 press enter if you got reply the printer is ready.
all this use when printer on and connected properly.
or call me after 8.00 P.M Cell : 9014363609
Posted on Nov 05, 2010
2 Suggested Answers
SOURCE: Canon IR 210N Network Configuration
You need to turn off the copier, wait a few seconds, then turn it back on. Make sure to select the Printer I/F button and press the setup button on the touchscreen when it comes up. Voila! Network settings.
Now, I can't get it to actually work, but that's a different problem.
Posted on May 10, 2010
How to get ip address for canon ir 1024 if
You need to enter into configuration menu. Search for :
System setting / network setting
Jun 05, 2017 | Canon Office Equipment & Supplies
Canon IR 2520 lost IP address
This is regular feature. Nothing defective here.
IP address is to communicate with the router on wire or wireless.
Dynamic IP address will assigned to your printer again when re-connected and will be lost when disconnected.
Static IP address assigned will be reserved at the router for the device even when the device is disconnected.
Apr 18, 2016 | Canon Office Equipment & Supplies
How to configure the printer on network printing
Print a configuration page. Look for the IP address under Network. Type that IP address in your web browser address and press enter. That should bring you to the printers internal web server settings.
Jan 22, 2014 | Canon iR 2022 Printer
Need to install ir 5020 onto server. Do I need any config software first like HP JetDirect?
You would need to ensure that the IR 5020 has a valid IP address (Should be located on the Network Configuration Menu from the on-screen display). When plugged into the network for the first time the printer is usually given an IP address, this would allow you to connect to the web management interface and make changes to the settings from an easier interface than the on-screen display.
If you are planning on sharing the IR 5020 out from the server to other computers then you would then need to assign a static IP address to the IR 5020 so that the IP address would not change once configured.
(Side-note - I do not recommend using DHCP on printers as it can cause issues down the road if the printer is given a defferent IP address by the DHCP server.)
Sep 13, 2011 | Canon imageRUNNER 5020 Copier
IR 22 30:HOW TO PUT IP ADRESS? i whant to
the easiest way is to print out a function list on the copier it should give the ip address on the list then open internet browser and input the ip address in the browser nd change the ip address there dont forget to make the ip address static hope you come right
Feb 19, 2011 | Canon IMAGERUNNER 2230 Copier
How to find the IP Address canon IR3570
you should be able to go through the print menu on the printer and look for something that says information or configuration and look for network settings and print this page.
ADDITIONAL FUNCTIONS>SYSTEM SETTINGS>NETWORK SETTINGS>TCP/IP SETTINGS
Nov 25, 2009 | Canon ImageRUNNER 3570 Copier/Printer
Plz send me (detail) feachar of cannon 6050 & cannon 400s on this address CHECHANI TELECOM & PHOTO COPIERS C-278, R.K.COLONY,NEAR CHOTI PULIYA, BHILWARA,(RAJ)311001 +919829045797 +919413824797
CANON IR 6050 IS AN ANALOG COPIER.
CANON IR 400 IS A DIGITAL COPIER.IR 400 IS SINGLE SCAN & MULTI PRINTS ,STACKLESS DUPLEX & ITS CAN BE USE PRINTER & FAX ALSO.
FOR MORE DETAILS VISIT WWW.CANON.COM
Mar 15, 2009 | Canon imageRUNNER 400S Copier
E677 Error in canon IR400
switch main power off and on E677
Feb 24, 2009 | Canon imageRUNNER 400S Copier
Input IP address on IR C3220 with ImagePass-C2
go to printer tab then function then print pages then configuration page. and you'll see the ip address
Feb 11, 2009 | Canon imageRUNNER C3220 Printer
Canon imageRUNNER 400S Copier Logo
847 people viewed this question
old marine
old marine
