Theres a mechanical noise coming from the water pump area during running, the potterton gas central heating boiler is over 5 years old, someone suggested it may be a pressure problem
    Master:
    Sergeant:
  • 449 Answers
Need more info
Posted on Aug 19, 2010
  • alanflavell Aug 20, 2010
    My question related to a gas central heating boiler.
  • Ralph Cronenberg Aug 20, 2010
    do you have a B@g pump your pump coupler my need to be replaced
Lost manual for towerstat RF
try googling "towerstat rf"
Sep 21, 2014 | Water Heaters
Puma 80 potterton hot water on and off
Boiler compartment ventilation will not stop you getting hot water . Its sounds like you have problems with a sensor or the water section on the boiler .
Apr 20, 2017 | Water Heaters
Loud gurgling noises (air and water) from around the boiler and expansion tank (nothing from the rads/pump area) just after the heating is switched off. The system will not come on without a reset. The...
Could be a number of things, none of which can/should be done by homeowner. If unit was installed by a certified P&H installer, call them. They can fuss with warranty stuff and order parts. Also the Potterton Promax HE 24 is same as Baxi.
Nov 20, 2017 | Honeywell Heating & Cooling
Hi. We recently moved to a rented property. We have a ST7100 Central heating and a Potterton Profile 50e boiler. However even though I have set the times on the ST7100, the heating ligth comes on, but the...
You definetly have a control issue. However trying to diagnose the exact problems that you have would be very difficult without actually seeing the wiring. You defintely have a wiring/control issue but I cannot tell you exactly what it is without more info. Sorry, I would love to help you more...
Nov 13, 2009 | Honeywell Electronic Programmable...
Potterton Suprema status light.
Are you getting Hot water and Heating?
The reason i ask is because I don't think you have a problem.
On this boiler it has a 'pump over run' thermostat incorporated into it, this ensures heat escapes from the boiler by using the pump to cool it down.
If you are getting hot water and heating, leave it well alone, if you reset the boiler this can have adverse effects on the boiler and evenually cause malfunction.
However, if you find that you are not getting Hot Water or Heating, then the most common fault on this boiler is the PCB (Printed Circuit Board) it is the 'brain' of the boiler and the most common fault on this make. (£160 + vat)
I hope this helps,
Steve
Jul 06, 2009 | Broan-NuTone 658 Central Heating System...
No central heating back boiler
back boiler run from a gas fire? check the instructions to operate the gas heat to the back boiler not just the fire
I presume that this a fully pumped system - air lock doubtful There maybe on/off valves on the pipes to and from the back boiler [situate close to cylinder] make sure they are on - anticlockwise turn
or there could be a blockage in the outlet from header tank usually in the loft. or If there is no water in it maybe the mains cold feed it is off.
Note if no water in it DO NOT USE the back boiler
May 03, 2009 | Bosch & Power Vent Water Heater
The hot water and central heating wont work together
what size of gas line is going into boiler and water heater? is it black iron ? natural gas or propane? have you checked gas pressure at water heater and furnace ? if they work fine individually then you have a problem with incoming gas pressure. Call gas company and ask them if they would come out and check gas pressure.
Feb 03, 2009 | Water Heaters
Gas boiler
hi sounds as though the system is sludged up & needs power flushing.the reason is that the water cannot circulate so over heats & pumps into the header tank.
expect to pay approx 350 400 pounds to have it properly cleansed, it will restore the system efficiency.
The other area worth considering is that it could be a faulty pump os that when th eboiler fires it cannot circulate so in turn expands & vents into the tank.
My advise is to arrange for a corgi engineer to sort it out for you.
Kindly
Richie
Dec 17, 2008 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Heating & Cooling Logo
102 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
