Question about Mach Speed Zodiac MP3 Player
How to adjust the volume? - Mach Speed Zodiac MP3 Player
  • 864 Answers
To adjust the volume first hit the lower left button which is the volume/back button then you would use the right and left arrow keys to adjust the volume on this unit. for future reference you can download the user manual by clicking this link and it explains everything about your Mach speed zodiac.
If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the solution. thanks and have a great day.
Posted on Aug 20, 2010
Volume buttons on my toshiba laptop is not working
There are other ways to adjust the volume.
Right click on the megaphone located at the bottom right near the time. You can adjust the volume there.
Look on your keyboard and normally you can Press and Hold the FN function key located at the lower left portion of the keyboard then hit one of the 3 keys with the megaphone that adjusts the volume (1 key increases the volume, 1 key decreases the volume and 1 key mutes the volume).
You can adjust the volume in the Control Panel's audio or sound properties. Click Start/Control Panel and look for Sound or Audio.
May 04, 2012 | Computers & Internet
Solton ms60 keyboard... volume stuck , can't adjust sound once set
There are a number of ways to adjust the volume. 1) Normally a button or keys on the keyboard will adjust the sound volume. You might have to press and hold the FN key or the Alt key then hit the key that adjusts the volume up or down. 2) If you right click on the megaphone at the bottom right near the time you can adjust the volume. If you click Start/Control Panel and look for Sound and Audio Devices you can adjust it there. 4) If you click Start/Programs/Accessories/Entertainment you will see a way to adjust the volume.
Apr 02, 2012 | Computers & Internet
What is the code to increase the volume of Samsung C3010
Hi
By volume do you mean Ring tone volume or Handset volume?
Ring tone volume adjustments.
Press menu >settings >phone profiles
Scroll the phone profile you ares using.
Press on options >edit and select call alert volume.
Scroll right or left to adjust the volume levels.
press on select and then save.
The handset volume adjust is done by pressing on the 1st side key in idle mode.
Feb 27, 2012 | Samsung Cell Phones
LHow do I increase the volume as the phone is very quiet
Hello there,
Adjusting the volume on an HP Officejet All-in-One
Follow these steps to adjust the volume of the various fax sounds.
Adjust the rings and beep volume
1.Press the Setup button P(wrench).
2.Press the arrow buttons (Left and right) to select Basic Fax Setup , and then press OK .
3.Press the arrow buttons (Left and right) to select Rings and Beep Volume , and then press OK .
4.Press the arrow buttons (Left and right) to adjust the volume, and then press OK .
Adjust the phone line and monitor volume
1.Press the Setup button (wrench).
2.Press the arrow buttons (Left and right ) to select Basic Fax Setup , and then press OK .
3.Press the arrow buttons (Left and right ) to select Phone Line, Monitor Volume , and then press OK .
4.Press the arrow buttons (Left and right ) to adjust the volume, and then press OK .
Adjust the handset volume
When you receive a call, pick up the handset of the product, and then press the arrow buttons (Left and right ) to adjust the handset volume.
Please feel free to leave a testimonial if this works and please do not forget to click 4 thumbs.
Cheers!
Mar 22, 2011 | HP J3680 Officejet All In One Printer
How do i adjust voice volume on my jitterbug
The rubber volume button on the outside of the phone adjusts both the ringer volume and the call volume, which is how loud a caller sounds when on a call. If you are not on a call, the volume button will adjust the ringer volume. To adjust the volume of a caller, you must adjust the volume while on that call.
To do this, while looking at the inside screen, adjust the volume by using the rubber volume button, which can be found on the outside of the phone. Press the top of the button to increase the volume and the bottom of the button to decrease the volume. The inside screen will display the call volume level. You may also set the call on Speakerphone mode. If you have the Jitterbug J model, there should be a button labelled "SPKR" on the upper left corner of the keypad.
If you need additional help, you can call a customer service expert available 24 hours a day 7 days a week at 1-800-733-6632 who will walk you step-by-step through the process.
Nov 19, 2010 | One Touch Jitterbug One-Touch Cellular...
Volume on tv adjusts automaticly
is the volume of your tv adjust automatic with a volume indicator on the screen appear?if that the case clean the volume controls on the mainboard with a contact cleaner..2nd is is the volume adjust with no volume indicator on the screen?your problem might be onthe sound if section.adjust the sound IF with a plastic screwdriver clockwise or counter clockwise until the soun stabilises..adjust the IF with a power is on.
May 17, 2010 | Televison & Video
Does not ring
The Volume key allows you to adjust the volume level for the currently active audio device (handset, headset, or speaker). When no audio devices are active, pressing the Volume key adjusts the ringer volume.
Adjusting the Volume of the Ringer, Handset, Headset or Speaker
Note: By performing this function, default volume level will be replaced.
  1. Press the up or down arrow at either end of the Volume key to reach the desired volume level.
  2. When you are satisfied with the setting, press the Save softkey.
Note: When adjusting only the ringer volume, there is no need to press Save. The settings are automatically saved upon adjustment.
See the below link for user manual
http://noc.unet.maine.edu/IPT/7961_7941_User_Guide.pdf
Jun 20, 2009 | Cisco 7941G IP Phone
Having trouble adjusting the volume
  • 2 ways to adjust the volume:
    • system volume and sound card icon settings:
      • 1. click the volume icon on the system tray and a window will pull up, adjust accordingly
      • 2. click the sound card icon on the system tray and adjust it according as windows pulls up.
Apr 17, 2009 | Computers & Internet
Cit200
Adjusting the volume of the caller's voice
You can increase or decrease the volume of a caller's voice during a call. There are 5 volume levels for selection.
To adjust the volume, during a call: While the phone is off hook (i.e. dial tone can be heard), press Up or Down.
The display shows the current volume level. Press Up or Down again to adjust the volume.
Still can't find the most comfortable level?
Besides adjusting the volume on the handset, you might also need to adjust the volume on your PC in order to set the speaker to the most comfortable
volume.
To set your handset's ringing melodies and volume:
1. Press MENU.
2. Press Up or Down to select SOUNDS. Press OK.
3. Press Up or Down to select HANDSET. Press OK.
4. Press Left or Right to change the volume level. Press Down.
5. Press Left or Right to select the external melody. Press Down.
6. Press Left or Right to select the internal melody. Press OK to confirm when finished.
Nov 01, 2008 | Linksys CIT200 IP Wireless Phone
NO SOUND WHEN IM ON MAX VOLUME
There are 3 types of volume: master volume, in-call volume, and multi-media volume. To adjust master volume, press and hold the thumb wheel until the volume control comes up and use the wheel to adjust it. When in a call use the thumb wheel to adjust the in-call volume. Finally, use the thumb wheel to adjust the volume of multi-media while it's playing. One thing to keep in mind, the master volume will override the multi-media volume, so if you can't hear the multi-media after turning it all the way up, you might try raising the master volume fist.
May 21, 2008 | Motorola Mobility Moto Q
Mach Speed Zodiac MP3 Player Logo
98 people viewed this question
Top Mach Speed Audio Players & Recorders Experts
Computer Repairing
Computer Repairing
Are you a Mach Speed Audio Player and Recorder Expert? Answer questions, earn points and help others
