I have a canon MP530 waste ink pad near full. what should i do?
  • 1,219 Answers
Press the OK button.
The service call error, indicating the waste ink absorber is full,
is likely to occur soon.
Once the waste ink absorber becomes completely full, printing
cannot be done until the waste ink absorber is replaced.
To reset it:
With the machine power turned off, while pressing the Stop/Reset button, press and hold the ON/OFF button. (DO NOT
release the buttons). The COPY button lights in green to indicate that a function is selectable.
2) While holding the ON/OFF button, release the Stop/Reset button. (DO NOT release the ON/OFF button.)
3) While holding the ON/OFF button, press the Stop/Reset button 2 times, and then release both the ON/OFF and Stop/Reset
buttons. (Each time the Stop/Reset button is pressed, the Alarm LED and COPY button light alternately, Alarm in orange
and COPY in green, starting with Alarm LED.) "CANON Idle" is displayed on the LCD.
4) When the COPY button lights in green, press the Stop/Reset button the specified number of time(s) according to the function
listed in the table below. (Each time the Stop/Reset button is pressed, the Alarm LED and COPY button light alternately,
Alarm in orange and COPY in green, starting with Alarm LED.)
4 times - Waste ink counter
resetting
Hope that helps!
Posted on Aug 19, 2010
Printer says"waste ink near full"
The waste ink is a set of sponges inside the ink jet that absorb ink during the printhead cleaning.
For now you can keep printing by pressing and holding the printer's On/Off button for one second. Then wait 10 seconds and press the On/Off button again. Wait until the printer finishes cycling before trying to print again. See Canon's support page for details: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/multipass_series/multipass_mp700#ServiceAndSupport . Search for Waste Ink Full.
When the waste ink tank is full, then you will not be able to print until the unit is serviced. Canon will service this for you. (Free except for shipping if the printer is under warranty, standard $$ otherwise) However under normal use, the waste ink full counter should be reached its limit near the expected end of life of the printer. Additional failures may occur soon.
This is a messy job and may be a lot more work than you want to do. Have plenty of newspaper to absorb the ink if you try this. You need to disassemble the printer to reach them. One set is under the area where the printhead sits when the printer is idle. The other is further down in the center. You will need to remove a few small screws to access the bottom set. Once you get them out, blot off most of the ink and then run under water until the ink is completely out of the pads. Blot the areas where the pads sit of the excess ink as well. Then dry the pads (you can use a blow dryer to speed this step). Then reassemble the printer. (Alternatively, order replacement pads from Canon)
See http://www.fixyourownprinter.com/forums/inkjet/45693 for additional comments from others who have tried this.
Next you can reset the counter. (Do not do this reset before cleaning or replacing the ink pads; waste ink will smear everywhere.)
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing [Menu] then [Copy] then [#]
2) Select TEST MODE. (using + or - keys)
3) Press the [OK] key.
3) Press the [8] key. (TEST MODE)
4) Press the [3] key.
5) Press the [0] key. (INK COUNT).
6) Press the [OK] key.
7) Press the [Stop/Reset] key
9) Press the [ON/OFF]
I hope this helps.
Feb 20, 2011 | Canon MultiPASS MP700 All-In-One InkJet...
Canon mp 390 waste ink near full
Some user tried the procedure to reset waste ink tanf full on Canon MP 360 and ... Reset Ink Level for Canon MX300 · Reset Counter Canon iP1500 and iP1000 ...
tricks-collections.com/waste-ink-tank-full-reset-canon-mp360/
Dec 06, 2009 | Canon SmartBase MP390 All-In-One InkJet...
It says waste ink near full where is this waste ink located?
The waste ink absorber for this machine is on the bottom, the whole case is covered at the bottom with absorbent pads. The pads are cheap, but you need to access diagnostics to be able to reset the error code after they are changed.
Jun 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
The waste ink collector/tank is nearly full
The ink collector should be found underneath where the cartridges normally rests. Put some tissue paper on the ink padand let it absorb the ink. You might have to repeat the procedure a few times to get rid of all the ink.
May 18, 2009 | Canon PIXMA MP170 All-In-One InkJet...
How do you find the waste ink collector on a printer/scanner ?
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink tank full" error.
The waste ink absorption pads are inside the printer, in the very bottom. They are usually soaked with ink when full and are very messy.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you.
Message "wasted ink tank near full" on Canon Multipass F80
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 17, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Indicates waste ink absorber is almost full on cannon i9900 print
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
The waste ink absorption pads cannot be emptied, only replaced.
May 16, 2009 | Canon i9900 InkJet Photo Printer
Waste ink near full error
Canon's a little shady when it comes to this, since any waste ink pad I've seen never has been more than 30-40% full. You can reset that status without cleaning the waste ink out and the printer should return to normal.
1) On the printer, press Additional Functions, Scan, Copy, Scan. This will put you in service mode.
2) Select Test mode at the bottom
3) Select #8 Printer Test, wait for more options. It should say 8-2 or 8-3; push the + or - button until it says 8-3 then hit Select. The menu will now say EEPRON Clear
4) Select Ink count which is option (0) and press set
5) Press Stop/Reset, then the power button and wait for it to restart.
I hope this helps!
Apr 15, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
The printer is indicating "waste ink near full"
Hey,
The waste ink pads should generally be around the cartridge carrier, or below, possibly at the bottom of the printer.
have a look at this page for instructions on how to reset the counter after the waste ink pads have been cleaned or replaced.
http://www.allthefaqs.net/forum/viewtopic.php?t=3770
Let me know if you need anything else.
Thanks,
Ekse
Mar 06, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon Pixma MP780
Yep your printer is nearing service time. This involves changing the waste ink pads and resetting it.
you could reset the printer without changing the wate ink pads but you risk damaging it
What i do is take the pads out wash them and replace them.
the waste ink pads are the pads the cartridge rest on whan itsn in neutral position
THE SERVICE MANUAL FOR YOUR PRINTER *step by step instructions in repairing it) is here
http://www.nodevice.com/manual/Canon/page15.html
and here
http://www.nodevice.com/manual/newmans/1164257699mp750780smpdf/get13922.html
enjoy
Dec 18, 2007 | Canon PIXMA MP780 All-In-One InkJet...
1,513 people viewed this question
jasbo
jasbo
