Question about InFocus SP-LAMP-017 Projector Lamp for LP540, LP640, C16
I have replaced new lamp to InFocus LP540 projector, but it still indicating in the LED display "please replace lamp".. and LED is blinking two times as red.. Lamp door is closed properly and the safety swich goes down.. What should be done?
  • 1 more comment
  • Scott Frye
    Scott Frye Aug 20, 2010
    Hi...
    Is there anything in the manual about a "reset" button or switch?
  • b11bz Aug 25, 2010
    nope.. or at least can't find it.
    Nope theres nothing about manual reset..
    Genius:
  • 1,175 Answers
To reset the lamp timer , press the increase volume button on the remote and the increase volume button within 3 seconds
The maintenance manual is on the infocus web site
Posted on Aug 25, 2010
Testimonial: "thank you very much, works fine now :) "
Cannot Reset Infocus LP 350 Projector after replacing a bad lamp
that model has a history of bad ballasts. you'll need to replace it.
Mar 03, 2010 | InFocus LP350 Multimedia Projector
Infocus sp5000 red led blinks once indicating lamp
be sure and reset the lamp hours. Flash the software if you can. These are also notorious for the ballast cable on the inside of the lamp housing backing out when a lamp is removed or replaced. If you have the cover off push the cables back into place and hold them there as you install the lamp. Also look directely at your lamp in the center and move it side to side and up and down. If there are any cracks or frosty looking spots or bubbles in the mirror of the lamp that are visible, then the lamp is probably shot. If all this fails, most likely it is the power supply, or the lamp door has gotten mishapen from heat and the actuator on the lamp door isn't making full contact with the safety swith.
Jan 29, 2010 | InFocus SP-LAMP-017 Projector Lamp for...
Won't power up
if there are no led lit, replace the power supply.
Nov 06, 2009 | InFocus SP-LAMP-017 Projector Lamp for...
I have infocus sp5000 and the lamp has stopped working. I pulled it our of the unit and it looks perfect. I suspect it is the lamp counter, but I need a method to reset without being able to see the...
there isn't one. you need to see the menu. but what color is the led and is it blinking?
green- all is well
red blinking:
1 time- lamp not striking after 5x.
2 times- lamp has more than 3000 hrs. replace lamp.
3 times- lamp failure. replace lamp.
4 times- fan failure. shuts down.
5 times- undiagnosed error. possibly ballast or colorwheel.
if the colorwheel won't spin, the lamp won't light. when you turn on the projector, do you hear a high-pitched whir? if not, the colorwheel needs replacing.
Aug 17, 2009 | InFocus SP-LAMP-017 Projector Lamp for...
Lamp doesn't light on SP 500, SP-Lamp-017. How do
you'd need the lamp on to get into the menu to reset the timer, so it's not that. if the door hits and activates the switch, it may be the ballast.
Aug 09, 2009 | InFocus SP-LAMP-017 Projector Lamp for...
InFocus LP540 Power Supply Problem
most of infocus parts are oem and made by a company in taiwan that no longer makes power supplies, and many of the parts have their stock numbers and not neccesarily a common stock. the power supply, however, is in stock at infocus for about $65.
Jun 23, 2009 | InFocus SP-LAMP-017 Projector Lamp for...
Infocus LP540
I haven't serviced an infocus projector before, But I have seen 3 or 4 Red cutting out display simptoms on projectors caused by bent or pushed in gold pins on the VGA leads. (it always seems to be red!) I won't comment on insides but do check this basic tip before delving in too deep. Good Luck
Sep 24, 2008 | InFocus SP-LAMP-017 Projector Lamp for...
Infocus LP540 --- display
It sounds like you may be feeding it with an HDMI source using an HDMI to M1-D adapter...
If this is the case, make sure the source in not set to a resolution higher than 720p.
However I really need more information to offer a definitive solution.
Take Care!
Sep 17, 2008 | InFocus SP-LAMP-017 Projector Lamp for...
Projector InFocus LP540
ask the guys at GOTABULB.com Through e-bay they are very good in america
Aug 29, 2008 | InFocus SP-LAMP-017 Projector Lamp for...
LP540 INFOCUS
good luck. not even the infocus authorized service centers get those. besides, they were made by another company that does not make power supplies antmore. and infocus doesn't have any new ones in stock. if you're getting no power at all, replace the mosfets. it works half of the time.
Sep 20, 2007 | InFocus SP-LAMP-017 Projector Lamp for...
InFocus SP-LAMP-017 Projector Lamp for LP540, LP640, C16 Logo
322 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
