I have a Adler Royal Adding Machine Type R010 S/N 44890121 and I need the roll paper holder that snaps into the back of the machine
    Problem Solver:
  • 15 Answers
I did not know
Posted on May 02, 2008
Need power cord for above-named calculator. Where can I find?
I looked for that and find nothing listed but depending on what the output end looks like many would possibly fit . http://www.americord.com/power-cords.html?gclid=CL2_x_us5MQCFQEaaQod2ZIAiA
Apr 07, 2015 | Adler Royal Ta 1123pd Nova Adding Machine
My fd100 wont print but thinks it is. also some times it freezes
if you could check the paper that you are using. make sure thermal. also scratch the paper, if a black mark appears this is the side that goes down in the paper holder, if you don't see a black line you don't have thermal paper. also make sure it is credit card machine and not adding machine paper. if you have another roll try that one. if persist. make sure the paper is hitting the thermal reader. there is no ink
Jul 17, 2014 | FirstData First Data FD100 Thermal Paper...
Need a paper roll holder for a TA Adler-Royal 1011PD Nova
Good luck. They are JUNK. Go buy a Good Calc, Canon, Sharp etc.What do you use this for? Home, Company, School? A computor will do this better and faster.
Apr 07, 2014 | Royal Vintage Printing Calculator 1980s...
How do you put the adding paper into the machine? My machine is a EL-1197iv
Never insert paper roll if torn. Doing so will cause paper to jam.
Always cut leading edge with scissors first.
1) Insert the leading edge of the paper roll into the opening. (Fig. 1)
2) Turn the power on and feed the paper by pressing . (Fig. 2)
3) Insert the paper roll to the paper holder. (Fig. 3)
DO NOT PULL PAPER BACKWARDS AS THIS MAY CAUSE
DAMAGE TO PRINTING MECHANISM.
Jan 03, 2011 | Sharp EL-1197PIII Calculator
How do you put the adding machine tape into the Sharp EL-1801V Adding machine?
Put the leading edge of the tape into the the opening on the back of the machine. Turn the machine on and press the button with the up arrow, then lift the little metal paper holder and insert the roll.
Mar 08, 2010 | Sharp EL-2630P Calculator
Broken Paper Roll Holder
You must google to find the manufacture to find if anything is still available; but I have 2 ideas : 1. form a hard wire loop (from coat hanger or #12 guage steel wire) and attach this wire loopto the back of calculator case with screws (you'll need to make an eye loop at one end for the screw to go through). 2. make a small wood block that sits on the desk or table and make a wire loop that is held by the wood block and of course the paper roll is held by the wire loop. Goodluck, Macgivor.
Dec 07, 2009 | Victor 1430-3 Calculator
Label stuck under typewriter platen/roller of Adler Royal
Roll a new piece of paper the best you can. Dribble a little paint thinner on the paper, letting it run down under the roller. The thinner will disolve the adhesive on the label. After a couple minutes, you should be able to roll out the paper and the laber with no problem.
Aug 28, 2009 | Office Equipment & Supplies
Adding machine problems
Block yBob - did you ever get an answer to your problem. I'm getting ready to install an ink cartridge into the same machine.
Aug 20, 2008 | Office Equipment & Supplies
Adding paper
There is no manual available for this model online.
However, there are two basic methods. Always make sure you are puting in paper that has been cut cleanly with scissors, not torn, as this can ruin your printer. If you have a slot on the back of the machine, just under where the paper roller typically sits on the holder, with the calculator off feed the paper in that slot (rolling out from the bottom). Then turn the printer on, and hit the feed to advance the paper into the printer.
If there is no slot on the back, you will see that the opening where the paper comes out from the top is "subdivided", and when it has printed, it is coming out of the front partition of that slot. Make sure the printer is off, feed the paper into the back portion of the opening, rolling from the top. Then turn the printer on, and hit the feed to advance the paper into the printer.
Either method should solve the issue exactly, and once the paper has fed in, then place the roll onto the holder. You're set!
Please post back if you need more help, otherwise thank you for using and rating FixYa!
Jun 07, 2008 | Canon P23-DHV Calculator
41 people viewed this question
jasbo
jasbo
