Question about Gigabyte GA-8IPE1000 Pro-G Motherboard
Hi I have a p4titan GA8IPE1000pro and its does not start or restart continusely
    New Friend:
  • 4 Answers
Its your power supply,4pin socket problem...reconnet it..
Posted on Nov 11, 2013
Why won't it start?
It should automatically restart.....BUT what happened is that when you unplugged it, you cut off the blower at the same time you cut off the heat element(s). The way it is supposed to work, is the thermostat cuts power off to the elements and the fan continus to run for a per-determined amount of time to remove al the heat from the elements. Then another 'fan control switch' shuts off the fan once the 'residual' heat is removed from the heater. Without that 'cool down' cycle, the hot element had enough 'residual' heat in it to trip off the 'thermal overload' in the circuit. The 'thermal overload'... or...'hi limit'...or...'hi temperature control' is resposible for shutting power off to the element(s) in the event that the blower fails.
Sep 24, 2015 | Heating & Cooling
Why won't it start?
I copied and pasted this answer from your other question as I thought it was the same one Sherry.... Hope it helps you.
Continus short beep coming from mbd(mother bord) no display?
try removing the memory card then power on again without the memory card and see if you have a display now if so then replace the memory card.
Feb 27, 2012 | Gigabyte GA-945GCM-S2L Motherboard
My GMC Sierra's air conditioning works great but the driver side vents will spontaneousely start blasting out hot air. The passenger side continuse to blow cold air. If iI turn the truck off and...
  1. Air conditioner system is discharged. Have the system evacuated, charged and leak tested by an MVAC certified technician, utilizing approved recovery/recycling equipment. Repair as necessary.
  2. Air conditioner compressor clutch not engaging. Check compressor clutch wiring, electrical connections and compressor clutch, and repair or replace as necessary.
May 24, 2011 | 2005 GMC Sierra
My motherboard GA-8GGEM800 no display and cpu fan continus restarted .I have try with new cpu & ram. promblem not solve
my motherboard 945gs no display and cpu fan continus restarted .I have try with new cpu & ram. promblem not solve
Oct 28, 2010 | Intel Motherboard
I hav a mazda protoge 1999. when i turn on ac everything runs except compressor, after a long while the compressor kicks in and starts cooling and continuse to cycle with out problems. But when the car is...
have you physically seen that the ac compressor is not running immediately the ac is turned on
first check
if it is then the problem may be in the climate control module so have that unit checked for operation
Nov 14, 2017 | 1999 Mazda Protege
Fix restarting computer
Press F8 repeatodly as the computer boots-try selecting safe mode from the menu, if you can get that far- Let me know if you can get into safe mode
Apr 18, 2009 | Computers & Internet
Question
you may by a new motherboard
Feb 08, 2008 | Computers & Internet
Gigabyte GA-8IPE1000 Pro-G Motherboard Logo
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
