Question about Zebra Z4Mplus Label Printer
Possible print head failure
Thermal transfer mode doesn't print. Labels and ink ribbon look good. Changed it to Direct Transfer (leaving the ink ribbon in, you get an error of course) But in Direct Transfer with the ink ribbon in I can print fonts and setup, looks good print quality. What is going on, looks like print head failure.
  • Zebra Expert
  • 285 Answers
To test , press pause botton and turn on (press 5 sec.)
he print a "pause test".
check if print, if stop on ich gap and if come some lines across the print (if apear some lines, need new print head.) this step just pause wen print some labels, and then still print until turn off.
Turn off and turn on the printer to work normal.
To calibrate media, go on the setings to "sensor profile" and/or "run manual calibration, follow the steps. (dont forget to take the ribbon from the sensor.)
let the test run until finish.
Posted on May 05, 2008
Warning ribbon in V53.16.7Z
The "ribon in" warning is because you set the printer to print DIRECT THERMAL insted THERMAL TRANSFER. The first mode is for printing directly on the thermal labels, not for using a ribon. The ribon sensor detects that a ribon is pressent and you get this message. You need to change the printing mode to Thermal Transfer from the printer Setup Menu, or from the Print Driver instaled on PC.
Jan 19, 2015 | Zebra Office Equipment & Supplies
Why would the printer not print appears like it has run out of ink(is a thermal)?
That printer will work in both direct thermal (no ribbon) and thermal transfer (ribbon) modes. If you are using media designed for thermal transfer printing and don't have a ribbon it won't print anything.
May 14, 2014 | Zebra GK420 Thermal Printer
I have a few Datamax-I-4206 printers and some of them have the Thermal Transfer ribbons and some do not....Do I need to have Thermal Transfers or cant I just print to them without it?
If the unit is set up for either(with the thermal trasnfer option- ribbon unwind and rewind assembly) you can use either ribbon- with thermal transfer stock, or direct thermal- with direct stock.
You can tell the stock by rubbing something across the stock to see if it will turn black, that is direct thermal stock.
If using direct, go into the setup and select media type- direct thermal.
If using ribbon- use thermal trasnfer option. But remember to install ribbon before calibration as ithe printer will error on out-of -ribbon.
Dec 31, 2010 | Datamax DMX I-4206 Printer
I'm getting a "ribbon in" error when printing Direct thermal, and there is no ribbon installed. Any ideas? The error occurred when the end users changed the label roll. Labels are loaded correctly, and...
Locate your printer driver under devices and printers Right click on it and select "Printing Preferences"
Choose the "Advanced Setup" tab
Change media type to "Direct Thermal"
Be sure that "use printer settings" is NOT selected at the top left
Click OK and you should be good.
Note that any labels created prior to this change will need to be changed inside each label under the label setup.
Oct 13, 2010 | Zebra 203DPI Printer
Changed rolls of labels on Zebra GX 420T and now nothing prints
Were the new labels thermal paper? Thermal printers need specially made paper to work right.
May 28, 2010 | Zebra LP 2844 Thermal Printer
Check the settings. If the printer is set for thermal DIRECT and you have thermal transfer labels, this will be the result. Thermal direct requires thermal sensitive labels. Thermal transfer requires a ribbon.
Hope this helps,
May 24, 2010 | Zebra LP 2844 Thermal Printer
Labels are "faded" looking when printed. looks like you need to change ink but obviously there is no ink
Is this unit in thermal transfer or thermal direct mode? Depending upon the usage of this machine, perhaps a new thermal head is required. If thermal direct, try a different roll of labels, it is possible to get a bad batch. In thermal transfer mode, the tape could be bad as well. Try a new one to test.
Let us know what you find.
May 12, 2010 | Zebra TLP 2844-Z Thermal Label Printer
The printer is set to Thermal Transfer mode (uses a ribbon). You need to set it to Direct Transfer mode, so that no ribbon is expected. You can do this in the control panel on the printer. Must also do this in Windows, in the properties of the printer (Control Panel-> Printers.)
Good luck.
Mar 23, 2009 | Zebra S4M Thermal Label Printer
Printhead light comes on
if you are using software that using printer please the s600 printer driver to direct thermal mode to solve the problem.
Aug 18, 2008 | Zebra Stripe S600 Thermal Label Printer
"warning Ribbon In" error message
Had the same problem with a ZM400. As stated in the User manual (can be downloaded, warning "Ribbon in" is usually caused by the wrong printing method (thermal direct instead of thermal transfer [which should be selected for ribbbons]). My error disappeared after choosing "thermal transfer" directly on the printer. For network printers this needs to be set by an admin in the network settings for the the printer to solve the problem permanently.
May 07, 2008 | Zebra 105SL Thermal Label Printer
Zebra Z4Mplus Label Printer Logo
404 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
