Question about Canon imageRUNNER 400S Copier
Cannon ir400 error e004 - Canon imageRUNNER 400S Copier
  • 1,219 Answers
Hi,for error code E004-001 or E004-002
Cause:
The SSR has a short circuit.
• The SSR has an error.
• The DC controller PCB has a fault.
The heater relay has an error.
• The heater relay has an error.
Description:
• The fixing heater remains
on.
• The fixing temperature has
increased abnormally.
The heater relay remains on.
FIRST TRY TO CLEAR ERROR:
Resetting Errors
1. The following error codes cannot be reset by merely turning off and then on the main power.
They require resetting in service mode:
E000, E001, E002, E003, E004, E032, E717
1) Start service mode, and select COPIER>FUNCTION>CLEAR>ERR.
2) Press the OK key.
3) Turn off and then on the main power.
2. Error codes other than the above may be reset by turning off and then on the main power.
n Detail Code
Some error codes offer detail codes, which may be checked in service mode:
COPIER>DISPLAY>ERR (3rd block from the right)
SERVICE MODE:
1) Press the asterisk key ' * ' on the control panel.
2) Press '2' and '8' on the keypad at the same time.
3) Press the asterisk key ' * ' on the control panel.
If these doesn helps, you need to call service to locate the fault, wich is probably bad thermistor.
Hope that helps!
Posted on Aug 19, 2010
2 Suggested Answers
SOURCE: eoo2 and e004 are the 2 errors are occurredin the
I NEED FOR THE RESET
Posted on Aug 01, 2009
How to fix a problem e014 in cannon ir400
Hi. that error indicates there is a problem with the fixing motor.
Feb 22, 2018 | Cannon Office Equipment & Supplies
Tip
How to resolve Cannon ir400 Error e004
<span>Hi,<br /><br />For error code E004-001 or E004-002<br /><br />Cause:<br />The SSR has a short circuit.<br />&bull; The SSR has an error.<br />&bull; The DC controller PCB has a fault.<br />The heater relay has an error.<br />&bull; The heater relay has an error.<br />&bull; The DC controller PCB has a fault.<br /><br />Description:<br />&bull; The fixing heater remains<br />on.<br />&bull; The fixing temperature has<br />increased abnormally.<br />The heater relay remains on.<br /><br />FIRST TRY TO CLEAR ERROR:<br />Resetting Errors<br />1. The following error codes cannot be reset by merely turning off and then on the main power.<br />They require resetting in service mode:<br />E000, E001, E002, E003, E004, E032, E717<br />1) Start service mode, and select COPIER&gt;FUNCTION&gt;CLEAR&gt;ERR.<br />2) Press the OK key.<br />3) Turn off and then on the main power.<br />2. Error codes other than the above may be reset by turning off and then on the main power.<br />n Detail Code<br />Some error codes offer detail codes, which may be checked in service mode:<br />COPIER&gt;DISPLAY&gt;ERR (3rd block from the right)<br /><br />SERVICE MODE: <br />1) Press the asterisk key ' * ' on the control panel.<br />2) Press '2' and '8' on the keypad at the same time.<br />3) Press the asterisk key ' * ' on the control panel.<br /><br /><br />If these doesnt helps, you need to call service to locate the fault, which is probably bad thermistor.<br /><br />Hope that helps!<br /></span>
on Feb 06, 2011 | Cannon i70 Printer
Error e805 ir 400
my cannon ir400 xerox machine is on but no working power supply is full but not run machine
Dec 21, 2013 | Canon imageRUNNER 400S Copier
Canon ir 400 error code e004
The error code E004 deals with the fixing unit. Odds are that you may have one or all of the following parts need to be replaced > the fixing lamps or thermistor or the thermal fuse or the upper fixing roller.... Just for starters... Good Luck
May 05, 2013 | Office Equipment & Supplies
My cannon immage400s printer error e004 switch main off and on please solution me
the SSR has a short circuit.
1. the SSR has en error
2. the DC controller PCB has a fault.
Description
- the fixing heater remains on
- the fixing temperature has increased abnormally
May 26, 2010 | Canon imageRUNNER 400S Copier
My cannon ir400 eror e220
this error is related to exposure lamp , does the the two end of the lamp is blackened. Otherwise the exposure lamp needs replacement
Jul 20, 2009 | Canon imageRUNNER 2270 Copier
Error code E803 on canon IR330
E-803 ON CANNON IR400, WHAT IS THE RESET PROCEDURE FOR THE SAME.
Jan 03, 2009 | Office Equipment & Supplies
Service manual
I want user manual for cannon imagerunner 400 / 330 series
Sep 19, 2007 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 400S Copier Logo
2,909 people viewed this question
old marine
old marine
