Question about Fisher and Paykel Fisher & Paykel Washer
Fisher and paykel washing machine GW603 (14 years old) will not power up. When the power is turned on from the power point all the LEDs light up, the machine beeps and then all the LEDs turn off within 1 second. I plugged into another power point but the problem is the same.
    Scholar:
  • 83 Answers
What you describe is normal for the power on cycle. If if will not work after this, then you have a problem. If it will not turn on by pressing the power button, try one of the wash type buttons. If it responds to the power button or the wash type buttons and beeps with the start/pause button and the lid is closed, then the lid switch is faulty, if it does not beep and the lid is closed, then the button is faulty and can be replaced on it's own by anyone with some soldering ability.
Posted on Sep 05, 2010
I have a Fisher and Paykel IW811 Intuitive Eco washing machine on which I have recently replaced the pump motor and motor control board. I have reset the size for 650mm.
Switch power off at wall & unplug machine for a couple of minutes. Plug it back in and power on. See if it resets it, If not then you may have a faulty main board or it has been damaged somehow during fitting.
Jan 09, 2017 | Fisher and Paykel Washing Machines
Washing Machine stopped through cycle and now will not turn on
Check the wiring harness, connections, contacts, etc. Look for some corrosion and loose connections. Also, check the water inlet for anything that may cause a reduction in water flow.
Dec 02, 2007 | Fisher Paykel EcoSmart GWL15
Tip
Decoding Fisher & Paykel Electronic Washing Machine Fault Codes
The Fisher & Paykel Smart Drive and EcoSmart electronic washing machines are equipped with fault detecting software to help easily determine the cause whenever a problem occurs. Not like other electronic washing machines, these ones do not have displays to flash the code, but rather use the eight (8) light-emitting diodes (LED) of the Wash Progress indicators to indicate the fault code. The eight (8) LEDs stand as an 8-bit binary number (zeroes and ones) that must be decoded and then converted to the decimal number system to get the fault code.
The fault code can be decoded by determining which Wash Progress LEDs are lit. Once determined which of the LEDs are lit, write down the 8-bit binary code; 1 for lit LEDs and 0 for the off ones. For example; the final wash, rinse, and spin LEDs are lit; the binary code is 00001101. This in turn can be converted to the decimal number system by multiplying each digit with its corresponding place value then adding up the result. From left to right, the place values are 128, 64, 32, 16, 8, 4, 2, and 1 respectively. Therefore, the decimal equivalent of 00001101 is 128(0) + 64(0) + 32(0) + 16(0) + 8(1) + 4(1) + 2(0) + 1(1) = 8 + 4 + 1 = 13; the fault code is 13 which is a pump fault.
Once the code is determined, search the web for the meaning and indicate it when requesting for an online assistance to facilitate a quick and precise response.
on Apr 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
How do I reset my Fisher Washing machine size?
To set the size switch, turn the power on at the power point and off at the console. Press and hold
WASH TEMPERATURE UP then press POWER. EcoSmart will give 4 short beeps
and the pattern of LEDs will change.
To lock the size into memory.
 Press SPIN SPEED UP, the SPIN HOLD LED is on for 7.5 / 8.0kg (650mm wide).
 Press POWER to confirm the setting and also exit this mode.
Apr 15, 2015 | Fisher Paykel EcoSmart GWL15
F & P MW511 Washing Machine ... Driving me Mad ... Please Help!
Size setting
Action - Reselect the size of Smartdrive by using the SIZE SETTING MODE. Push and hold
the water temp up button, then press the power button to enter SIZE SETTING MODE. Three
LEDs are used to identify size.
The cold water temperature LED identifies 5kg.
The low water level LED identifies 6kg.
The hold spin speed LED identifies 7kg.
If the product has not been setup before all 3 LEDs will be on.
To set the size for 5kg push the wash temp up button then
the power button.
To set the size for 6kg push the water level up button then the power button.
To set the size for 7kg push the spin speed up button then the power button.
This locks the size
into memory. To check the size is set, start a cycle.
Aug 16, 2012 | Fisher and Paykel Fisher & Paykel Washer
We have a Fisher and Paykel washing machine model MW509NZ. it keeps going into error with Leds 3, 5, 7 and 8 illuminated and a beeping noise. What is the problem please.
this is a fault code 43 which mean the out of balance switch is either faulty or the switch isstuck in the on positionfree up or replace switch which is located just under the main board
Aug 06, 2012 | Fisher and Paykel Washing Machines
Cuts the power
hi usually it is the pump that causes most of the problems with these machinesdepending on where youiare these pumps are about $100
cheers grant
Jul 25, 2008 | Fisher Paykel EcoSmart GWL15
My fisher paykel eco smart is GWL11 not GWL15
00110001 CODE 49 COLD VALVE FAULTY
1 FILTER IN HOSE AT TAP END CLOGGED OR FILTER IN VAVE AT MACHINE END OF HOSE CHECK THESE FIRST .
2 SOLENOID OPEN CIRCUIT OR BECOMING OPEN CIRCUIT WHEN HOT.
3 CONTROLLER NOT SUPPLYING VOLTAGE TO SOLENOID.
TRY THINGS IN THIS ORDER AND GOOD LUCK
Jun 27, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
249 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
