I would like to know if my ht 3913 will work thru the TV sound, I have no problem with it working when I'm using the DVD player to watch movies, but I would like to hear the TV thru surround sound
  • 11,800 Answers
Directly , no, since the tv sound is always just on 2 channels. But you can convert it in the receiver to surround by activating either the SRS Surround or the DolbyProLogicII options on your receiver.
Posted on Aug 19, 2010
The sound goes on and of when watching a movie
see the cause and fix it: God bless you
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
Jul 21, 2012 | Wharfedale DVD-M3 DVD Player
I want to use my TV's speakers with Samsung ht320z not surround sound.How?
You have to hook up the audio cables to the TV from the DVD stand alone player. Red and White is audio and Yellow is Video. The player will play movies and the sound should go to your TV speakers. If not you will need to set it on the TV in the audio source to play from your speakers on the TV. John
Apr 15, 2012 | Samsung HT-Z310T Theater System
How do I watch a dvd movie on tv? I have the dvd
press the av or au bullon on remote until you get to the dvd "channel"
Feb 11, 2010 | GE 19GT243 19" TV
Surround sound does not come through my tv. Just
If your DVD player is a home theater system then the sound would come through the HT system, not the TV. On your TV you should have an 'AUDIO OUT' jack, plug that into your HT system where it has the 'AUDIO IN' or "AUX" AUDIO IN. Then when you are watching TV, just set your HT system to AUX mode or AUDIO mode.
Hope that helps.
Gary
Oct 31, 2009 | RCA RTD215 Theater System
Programming dvd player
It sounds like you may not be on the correct input selection on the tv to watch the dvd player. Ther are probably three or four inputs to choose from on your tv. whichever input you hooked the dvd player into on the tv is the same imput you have select using the tv's remote control in order to watch movies on the dvd player.
May 31, 2009 | iLO 3200 32 in. LCD Television
REGENT MODEL HT391 SURROUND SYSTEM
i need to know how to hook up my home theater to my TV and Dvd.
Oct 04, 2008 | Durabrand HT-3915 System
Samsung ht-tx72 Issue
GEnerally speaking that behavior suggests that the video signal is being lost for a second and returns. The easiest thing to try is to replace the connection cable (video). A bad connection there could cause this although moving the cable should make this happen at will. Check the DVd player on another TV if possible. If hte player is the cause, the "new" TV should show the same symptoms.
The only other possibility is that the DVD player is having a problem generating the video signal. This could be because the disc is not being read correctly (I would expect the sound to be effected as well) or the video processing section of hte DVD player is defective. This wil be a bit more difficult to find.
Can you try the cable and other TV and update this?
Thanks,
Dan
Jul 27, 2008 | Samsung 1200W 5.1-Ch. XM-Ready Home...
How do I get my tv to play through the surround sound
If you have direct cable into the television, you will need to use an audio output if available on the back of your set into your HT system.
If you are using cable w/ a cable box you have two options. You can still connect everything directly into the TV then reroute the audio to the HT system... or, you could hook only video to the TV and audio from the cable box to the HT system. Really up to you.
Mar 04, 2008 | Panasonic SC-HT680 System
Bad color when watching cable ok thru dvd player
If the power spike came in through the cable, I would suspect something in the tuning circuits -- unless you have the set connected to a cable box, in which case I would try the box on another TV first. If the problem is in the TV which was made by Symphonic-Funai by the way, I would check with my homeowners insurance if you can file a claim before I spent any money on it.
Jan 13, 2007 | Sylvania SST4322 32" TV
112 people viewed this question
 Grubhead
Grubhead
