Question about Sharp AR-M160 Black and White Copier
Error code H4 appear on display when voltage low in photo copier machine sharp AR-a61
    President:
  • 2,072 Answers
In order press P * C * or # * C *. the machine will go into diagnostics. Then enter the number 14 as if making 14 copies. Then enter 1 and press start. That should reset your machine.
PLEASE let me know if this fixes it.
Posted on Aug 19, 2010
Sharp ar-164 - Displays "h4"
this error means:
heat roller abnormally low temperature.
for reset:
clear key --> interrupt key --> "0" key --> interrupt key --> 14 --> start key
Jul 25, 2012 | Sharp AR-164 Copier
H4 Displays
H4 indicates "low temperature", possibly caused by a failure of the heater lamp or fuser. Sometimes this error is shown without an actual damage when the power cord is pulled without shutting down the copier first.
To cancel the error code, press [CLEAR], [AUTO], [CLEAR], [AUTO] in rapid succession. The display should go blank. Next, select 14 (clear low temperature code), press [START]. Finally, switch off and on the machine.
If there was no actual damage (i.e. power cord pulled), the machine should be OK again. If the error persists, immediately or after short time of operation, you will need to contact Sharp technical service for repair.
Jan 10, 2011 | Sharp AR-5316 Advanced Digital Imager...
The copier displays H4 What is the solution?
Jan 09, 2011 | Sharp AR-5316 Advanced Digital Imager...
Error h4 sharp ar-5316 can you help me ?
Jan 08, 2011 | Sharp AR-5316 Advanced Digital Imager...
Display panel h4 code any clues?
This error is displayed when the Fixing heater has not reached normal operating temperature after a specified time.
It is usually a blown heater element.
You will need a technician to repair this.
May 01, 2010 | Sharp AR-235 Copier
Irc2105
There is no such error 'E215-0000' in ar 5320, for H4 use "#, Interrupt, C, interrupt. Display goes off, Enter 14, Press Print key.
Apr 08, 2009 | Sharp AR-5320 Black and White Copier
Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
Oct 26, 2008 | Sharp AR-M160 Laser Printer
Sharp AR-M160 Black and White Copier Logo
149 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
